Corroded battery terminals
Discussion in '1st Gen. Tacomas (1995-2004)' started by tgtech570, Jan 12, 2011.
  1. Jan 12, 2011 at 1:21 PM
    tgtech570
    tgtech570 [OP] Member
    Canton, OH
    2017 Tacoma TRD Sport 3.5L V6 4x4
    Ok so I decided to eliminate the corrosion on the posative battery terminal leads. I would like to cut the old lugs off and crimp new lugs on rather than just try and clean the corrosion off. Trouble is I'm not sure what guage I'm dealing with? On my 02 Tacoma there are two posative wires. One looks to be 2 or 4 guage and the other that goes to the fuse box is maybe 12 guage? Does anyone know for sure? The local Toyota dealer was no help : (
  2. Jan 12, 2011 at 3:25 PM
    ChewbacaTW
    ChewbacaTW My progeny will be awesome!
    Sam
    Flagstaff, Arizona
    02 Xtra Cab TRD off road
    K&N air intake, custom exhaust, Powerslot Brakes, urethane steering rack bushings
    The smaller wire powers the outer fuse box i believe. As for the corrosion, just give the terminal and the cable a good scrubbing and keep an eye on it and there shouldn't be much of a problem anymore.
  3. Jan 12, 2011 at 3:27 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    This ^^^
    Give it a good scrubbing with a wire brush and some sandpaper. Then spray them with some dielectric grease or white lithium grease to keep the corrosion from coming back.
  4. Jan 12, 2011 at 3:30 PM
    N.GA Taco x3
    N.GA Taco x3 Well-Known Member
    Kevin
    Georgia
    11 Pre DC Sport- 02 Pre DC OR- 12 DCSB 4x4
    the same thing happened to my '02. I ended up getting a new positive battery cable end terminal and red boot, about $30. The factory end was the only one i could find that had the bolt on top for the factory wires to connect to. The positive post terminal/connector was so corroded, i could not get it tight enough to make a good connection. Didn't want my 16 yr old soon or wife stranded, so i sucked it up and ordered one from an online Toyo parts dealer, used some dielectric grease around the positive cable , hooked it up and no more problem.
  5. Jan 12, 2011 at 4:12 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If your cable is corroded, replace it with the dealer cable. If not, clean posts and cable ends with baking soda and soapy water, flush with clean water, dry and spray battery terminal protector on posts and cable ends. What acid leaks out of the battery won't be able to get in the connection with the spray there. Grease doesn't work as well, and is harder to remove.
  6. Jan 12, 2011 at 9:44 PM
    surfermatt
    surfermatt Well-Known Member
    CA
    04 prerunner, ext cab
    Front long travel custom: king 10" CO, solid lowers, fabbed spindle, heimed everything ect. Rear still in progress, waiting to be put on: bilstein 9100s, T100 axle. Stock 3.4 engine, 4.30 gears.
    ^^x2
    pour half a bucket of water, then some baking soda or soda ash to neutralize the acid, then scrub then the other half bucket
  7. Jan 13, 2011 at 6:23 AM
    tgtech570
    Canton, OH
    Well I would still prefer just to replace it. Does anybody know how to determine what guage the 2 wires are? All of the electrical diagrams I've seen are simple flow charts. Thanks
  8. Jan 13, 2011 at 7:15 AM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Have you tried just replacing the positive terminal? I had the same problem and ordered a factory Toyota and there really is no need for a new cable most of the time.
