Cost Effective Tips to Make your new 2nd Gen last forever
Discussion in '2nd Gen. Tacomas (2005-2015)' started by junkman, Dec 10, 2012.
  1. Dec 10, 2012 at 11:22 AM
    junkman
    junkman [OP] Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    Yeah, I think the idea is to pull the bolts. Have to mark the cams and even then may screw your alignment.
    There is some discussion about what to use - never sieze or grease or synthectic grease with graphite mix.
  2. Dec 10, 2012 at 11:24 AM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Hm... I have lifetime alignments at firestone, I may do my best and then let them get it back in line again.
  3. Dec 10, 2012 at 11:31 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    I used neverseize and the dealership wasn't happy with me. I caked it on pretty good and I could see all the silver handprints on the LCA from the stuff smearing and getting on their hands :eek:
  4. Dec 10, 2012 at 11:32 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    Yup that is the reason I will use it that shit sticks to everything
  5. Dec 10, 2012 at 11:33 AM
    Jared
    Jared A Bad Ass Member
    Jared
    Porterville, Ca
    2011 Toyota Tacoma DCAB LBED 4WD
    Current Mods: -Viper Alarm System -Covered up seat belt buzzer -WeatherTech Floor Mats -Fog lights turn on with Bright Lights -17 inch Chrome Tacoma rims (off a 2012) -Line-x'd the front skid plate -USB charger that plays music via Mediabridge -Window Tint: Front-20%, Back-5% -Front Toyota License plate logo -2 Extra D Rings in front -Bright Reverse Light Bulbs -6,000K Head light bulb -6,000K Fog light bulb -LED Dome & MAP light bulbs -Trailer brake controller -Escort 9500 Radar Detector (hardwired) -BendMount Mirror Radar mount -C.B. Radio with a built in Mic Plug in by Aux -LED Bed lights with an extra fog light switch -30 inch LED light bar under front grill wired to an extra fog light switch
    X2
    I'm a frequent spray painter to! Prevents rust, looks good, and gives me something to do!
  6. Dec 10, 2012 at 11:56 AM
    junkman
    Erik
    Louisville
    What paint do you use?
  7. Dec 10, 2012 at 11:58 AM
    Oscarbob
    Oscarbob Well-Known Member
    Bob
    Central New York
    '10 DCSB 4X4 OR, Pyrite Mica
    WeatherTec floormats and rainguards, Scanguage, LR UCA, 265/75/16 Duractrac's
    You could do an engine oil analysis every so often to monitor the "health" of your engine. I'm about to do my first here shortly at 30k miles. It's 25 bucks for some solid information about what's going on inside your engine
    http://www.blackstone-labs.com/
  8. Dec 10, 2012 at 11:59 AM
    BostonBilly
    Easton
    Black
  9. Dec 10, 2012 at 12:02 PM
    junkman
    Erik
    Louisville
    No shit
  10. Dec 10, 2012 at 12:03 PM
    BostonBilly
    Easton
    :rofl:Whatever I have on hand
  11. Dec 10, 2012 at 12:15 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    The a/c drain hose extension is a good idea. I used wire mesh on the end to keep critters out. Also, do the wire mesh mod over the cabin air filter...
  12. Dec 10, 2012 at 12:23 PM
    OffroadToy
    4X4 Offroad
    For rust prevention check here once in a while for wet leafs and crap...
  13. Dec 10, 2012 at 12:25 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    '11 TRD Off Road
    Hellwig Rear Sway Bar, AFE Air Filter
    I am going to make a habit of inspecting the frame and suspension in the springtime, removing rust, and touching it up with undercoat spray. I undercoated the frame as soon as I got the truck, and so far so good after a year. The axel started developing some areas of surface rust after last and I immediately took care of it. It also helps to make a weekly habit of heading to the spray&wash to spray off the frame during the winter months that salt is present on the road.
  14. Dec 10, 2012 at 12:32 PM
    DJSPEC
    DJSPEC 808 Zombie Outbreak Tactical Response Team K9 Unit
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    debadged Viper Alarm Diehard Platinum 31M Battery Pelfreybilt Battery Cage OEM roof racks, step sides LED HI/LO Headlights 35W 6000k HID Fog Lights 20% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Dueler A/T REVO2 265/70R17 SCS Stealth 6 Wheels Wet Okole Seat Covers Reese Tow Hitch 33090 Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Kobalt Slim Tool Box Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar 3" Lift Light Racing Ball-Joint Upper Control Arms (LR8-25470) OME Front Nitro Shock(900021) with 885 Springs OME Nitro Rear Shocks (ARB8-60091) Revtek Add-A-Leaf (REVAALT5B)
    sub'd for good to know info!
  15. Dec 10, 2012 at 12:37 PM
    #35
    SitkaSpruceMica
    SitkaSpruceMica Well-Known Member
    TC
    SE Alaska
    2013 SR5 4x4 I4 Auto AccessCab
    I use paint made for BBQ Grills for lots of stuff. It holds up way better than engine paint when used in high temps areas imo and is cheaper too. Painted some brackets and the exhaust manifolds on my boat quite a few years ago and they still look great.
    TC
  16. Dec 10, 2012 at 12:43 PM
    #36
    claymore
    claymore Well-Known Member
    Clay
    ABQ New Mexico
    2012 Offroad
    TRD cat back exhaust, console vault(for my little friend),Pop and Lock, Bak Flip G2, Weather Tech window covers, LED inside and out, DTRL Anytime, Grillcraft Grill, BAMF Light Bar with Hella 500s and Blitzpro 15D, Eibach with 5100's all around set at .85 and top plate spacers, LR UCA's, toytec 2" add a leaf, Duratrack 285 75 16, ABS kill switch, Aux reverse lights, Blue Sea Aux fuse block, ImMrYo Bracket, LED Bedlights, Ultra Gauge,
  17. Dec 10, 2012 at 12:43 PM
    #37
    WheelinJ91
    WheelinJ91 Well-Known Member
    Edmonton,AB
    2012 TRD DCSB
    Airaid Intake, MBRP Exhaust, Toytec OME 3" lift w/AAL, Flip-kit, LR UCA's, Weathertech Floor mats, hood and window deflectors.
    I'm sure where i live the engine will outlast the body (RUST). With basic maintinance and fixing thing when they start to go and a yota will last you for as long as you want it.
  18. Dec 10, 2012 at 12:54 PM
    #38
    Zombie Runner
    Kevin
    Wichita Falls, TX
    Tundra, double cab.
    LED interior lights, stubby antenna, Pioneer in dash screen, good driver mod.
    that area of my truck ALWAYS has crap stuck in it. :mad:
  19. Dec 10, 2012 at 1:16 PM
    #39
    Pugga
    Massachusetts
    F-150 Mod
    x2. I check there now whenever I wash my truck thanks to a thread on here saying to check it out. It's a nice leaf/dirt collection area.
  20. Dec 10, 2012 at 1:30 PM
    #40
    junkman
    Erik
    Louisville
