Cost Effective Tips to Make your new 2nd Gen last forever
Discussion in '2nd Gen. Tacomas (2005-2015)' started by junkman, Dec 10, 2012.
  1. Dec 13, 2012 at 8:15 PM
    #61
    Larry
    Larry CARL
    CARL
    with age...comes wisdom ;)
  2. Dec 15, 2012 at 3:23 AM
    #62
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Grease the front wheel bearings before failure.
    I have already added a remote trans filter and powers steering filter.
    Plan to add an easily replaceable fuel filter.
    Constantly keep the headlight lenses clean and waxed or similar protection.
    PK
  3. Dec 15, 2012 at 5:06 AM
    #63
    SkullTaco2012
    SkullTaco2012 Well-Known Member
    2012 DC TRD Off Road
  4. Dec 15, 2012 at 7:29 AM
    #64
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    I have seen alot of guys on here do the oil collector
  5. Dec 15, 2012 at 7:31 AM
    #65
    Nixinus
    Nixinus Well-Known Member
    I was skeptical as well but after some research I decided to purchase one. After 5k miles I drained the catch can and was amazed how much oil came out. The thread is here and my results are page #13: http://www.tacomaworld.com/forum/2nd-gen-tacomas/231227-oil-catch-can-install-guide-13.html
  6. Dec 15, 2012 at 7:33 AM
    #66
    junkman
    junkman [OP] Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    Added - Thanks
  7. Dec 15, 2012 at 8:13 AM
    #67
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    I thought you had to diassemble the hub, press the bearings out, and replace the seals to grease them. Seems a lot of trouble to go through to reuse bearings.
    I'll look at the catch can thread later, but without UOAs showing improvement, it's not a project I'll likely do.
  8. Dec 16, 2012 at 5:41 AM
    #68
    PMK
    Florida
    10 DCLB TRD Sport
  9. Dec 30, 2012 at 7:49 AM
    #69
    junkman
    Erik
    Louisville
    Still looking for more tips
  10. Dec 30, 2012 at 8:02 AM
    #70
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    Still wondering about replacing the clutch every 2 years as the dirt post suggested?
    Seems crazy to me
  11. Dec 30, 2012 at 8:16 AM
    #71
    DoorDing
    Bodie, CA
    yes
    I'm not sure what post you're referring to, but the suggestion was to change the hydraulic clutch fluid every two years, along with the brake fluid.
  12. Dec 30, 2012 at 1:23 PM
    #72
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    The forward cab mounts seem to hold alot of mud in them that could turn into a bad rust problem. The previous owner of my truck did alot of off roading and when I bought the truck, the mounts were packed full of mud. I cleaned them out with a screwdriver and compressed air followed by a good rinse. Some fluid film inside would be a good idea
  13. Dec 30, 2012 at 2:39 PM
    #73
    DoorDing
    Bodie, CA
    yes
    Good idea. I FF fogged mine already, but that's one of those spots worth flushing well in the Spring, blowing out, and re-fogging.
  14. Dec 30, 2012 at 2:57 PM
    #74
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    ^ Nods. Would think after 8 years on the same model there would've been a solution. :cool:
  15. Jul 25, 2013 at 2:47 PM
    #75
    junkman
    Erik
    Louisville
    Just looking for more tips......
  16. Jul 25, 2013 at 3:40 PM
    #76
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    nice info thx
  17. Jul 25, 2013 at 4:35 PM
    #77
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) It is a good idea to lubricate all your rubber gaskets with a Silicon spray. I do mine every other oil change. I also spray my window channels and any other rubber items on the truck.
    It is a good idea to apply di electric grease to your plug wires connectors at the spark plug and at the coil to keep water from shorting out your plug wires.
  18. Jul 25, 2013 at 4:42 PM
    #78
    ChiveOn
    ChiveOn City Slickin' Redneck, I wear a suit with a mullet
    A BC Boy in Calgary
    2013 MGM DCSB TRD Sport 6spd
    Plasti-Dipped Emblems, Tonnopro Tri-fold toneau cover (for winter use only), AVS in-channel visors, Ultra Gauge, Tepui Kukenam RTT, Muteki Trail Hog 285/70/17, Pop N' Lock, Bilstein 5100's in the front set at .85 with Eibach coils, Bilstein 5100's in the rear with a Toytec AAL. Toytec drivers side spacers, Toytec diff drop kit. All Pro u-bolt flip kit, TJM Compressor (permanently mounted), Custom rack for the RTT over the bed, Tepui Kukenam RTT, Toyota Bed Mat, Cobra 75 WX ST CB Radio, and a lot of gear behind the seats.
    #6....Brakes, ok maybe but the clutch? Shifting smoothly is what saves clutches.
    :confused::confused:
  19. Jul 25, 2013 at 5:27 PM
    #79
    mr2mki
    mr2mki Well-Known Member
    The question in my mind is, what tangible value does it add. Two things come to mind that could happen as a result of oil mist running through the intake:
    1) Some oil collection in the intake
    2) Some extra carbon in the combustion chamber
    Neither of these things are "good", but do they actually matter on a truck seeing normal service? Just about every car in the world recirculates crank fumes the same way, and none that I know of have oil catch cans.
  20. Jul 25, 2013 at 5:55 PM
    #80
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    Sooner or later, your gas fill door hinges will start squeaking. A shot of WD40 cured mine.
