Cost Effective Tips to Make your new 2nd Gen last forever
Discussion in '2nd Gen. Tacomas (2005-2015)' started by junkman, Dec 10, 2012.
  1. Jan 16, 2014 at 7:45 PM
    #101
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    I regularly wash my truck due to CT winters and the salt and chemicals for snow/ice melt, I lube the hinges, keep the paint waxed, shampoo the interior every few years, I also recently applied AMSOIL metal protectant on the undercarriage. It comes in a spray can and applies wet and dries to a light sheen. Nothing sticks to the frame such as mud and salt for example. Cost me $50 for six cans and took me about 2 cans to coat undercarriage, it suppose to last a few years. Good stuff.
  2. Jan 16, 2014 at 8:02 PM
    #102
    BradyT88
    BradyT88 Well-Known Member
    Hawaii, Florida, Cali just to name a few places that have salt without snow.
  3. Mar 1, 2014 at 10:11 PM
    #103
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I can attest to the greasing driveshafts. Mine were not greased when I got the truck brand new. Had one of my rear ujoints begin to squeek after a week or two. That's pretty bad. Didn't need to be replaced, but was in desperate need of grease. Greased them all really well. They last a LONG time if you grease them.
  4. Mar 2, 2014 at 6:14 AM
    #104
    jaymoussy
    jaymoussy Well-Known Member
    Eastern MA, US
    '12 AC Base 2.7l 4a
    I can see that.
    What is the best way to grease them (method, product(s))?
    Great thread, very useful.
    Frame: New to Taco, I just did my first informal frame rinse after snow storm: U shape of frame members trap lots of crud inside the U. Thinking of making/using a small wand to get rinse water in there.
  5. Mar 2, 2014 at 7:18 AM
    #105
    BradyT88
    On 2nd gens the 4wds have 5 zerks to grease. 3 on the rear driveshaft and 2 on the front.
    Prerunners have sealed joints on them so you can't grease them... not sure if you can swap in a greasable joints or if you have to swap in a whole new driveshaft to get greasable joints.
  6. Mar 2, 2014 at 7:23 AM
    #106
    Willie B
    Willie B Well-Known Member
    Brad
    Lilburn, GA
    14 TRD Sport Access 4x2
    Just crawled under my 2014 AC PreRunner and there do not appear to be any grease fittings on the UJ's.
  7. Mar 2, 2014 at 7:35 AM
    #107
    BradyT88
    The access cab and the double cab shortbed are identical underneath. Same frame and all. They just bolt on a different sized cab and bed.
  8. Mar 2, 2014 at 7:38 AM
    #108
    BradyT88
    Yep. Like I said in my post above. Prerunners have sealed non greaseable joints. They will last longer than greaseable ones that don't get greased but they won't last as long as greasable ones that are regularly greased. The magic number seems to be around 70k to 80k miles when the Prerunner driveshafts grenade but I'll bet they make a lot of noise before that happens.
  9. Mar 2, 2014 at 7:54 AM
    #109
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I've wondered that, good to know. Thanks.
  10. Mar 2, 2014 at 2:25 PM
    #110
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    one of the best things you can do is oil/undercoat the inside of your panels. easy to do the doors by taking off the door panels but to do the cab corner and rockers you can drill holes in them *one or two 1/2 holes will be fine* then when your done plug the holes with 1/2 inch rubber plugs. and added benefit is by oiling the frame/underside/suspension all the bolts come out very easily after many years.
    did this to my last jeep and it was 100% rust free under and inside.. not a spot of rust on any panel
  11. Mar 2, 2014 at 2:37 PM
    #111
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
