Cost of an oil change? 10K service interval
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Still Stoked, Jan 30, 2019.
  1. Jan 30, 2019 at 6:21 PM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    back to the OP question "what the brain trust feels is a fair price for an oil change" You can also do it this way:
    Labor time: .4 (20 min) see shop rate
    Material cost (oil) $4.50 a quart (bulk rate) X 6 = $27
    Material cost (filter) = $6.00
    Shop labor (dealer) rate = $100-150 hr.
    If I take the first shop labor rate ($100) I come out to $53.00 + tax ) your local tax may vary.
    You do the math for your area.
    Anything far and above that base, is how much the stealer thinks his expertise, services and value are worth.
    Question you need to ask yourself is, how much do you think are those last three (expertise, services and value) are worth and are you good with it?
    Hope that helps
    Cheers!
    tonered and Inferno! like this.
  2. Jan 30, 2019 at 6:29 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
  3. Jan 30, 2019 at 6:53 PM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
    I’ve never paid to have my oil changed. I would guess $50-60 would be a fair deal considering the cost of oil and labor.
  4. Jan 30, 2019 at 7:11 PM
    ferntr33
    ferntr33 Well-Known Member
    Don’t forget you are also paying for them to check a bunch of other stuff. Washer fluid. Check brake pads etc.
    That said my buddy just took his back in cause they impacted the filter housing on so tight he couldn’t break the seal with the aluminum tool he bought (from Toyota) he changes it in between Toyota care.
  5. Jan 30, 2019 at 10:47 PM
    Rockoma5
    Rockoma5 Well-Known Member
    St Louis
    2019 TRD Sport Lifted
    Supertech synthetic and mopar oil filter on wife’s Pacifica and yeah will be doing on my Tacoma as well...meets specs and is cheap. I change every 5k for easy math and I was/am a Mobil one guy...
  6. Jan 30, 2019 at 10:50 PM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Um. The Tacoma is SOOOO easy to change the oil urself. Save the money, takes 15 minutes.
    Rockoma5 likes this.
  7. Jan 30, 2019 at 10:58 PM
    picturethis
    picturethis Well-Known Member
    Billy
    Issaquah, Wa
    2001 and 2016 Silver Tacoma DCLB TRD Sport
    BAMF Grille CBI Sliders Victory4x4 roof rack Cali Raised fog lights FNFX wheels Falken Wildpeaks tires
    Had it done at the dealer for about $90, then I bought a special they were offering, $200 for 5 oil changes, which I think is a good deal.
    Always changed my oil on my 2001, but have yet to change it on my 2016, I'm 5 changes in, getting lazy I guess :)
  8. Feb 25, 2019 at 7:23 AM
    Cardsallday13
    Cardsallday13 Well-Known Member
    2017 DCSB TRD Sport 4x4
    Dealer here does a prepay option. 6 tire rotations and 3 oil changes for $150
  9. Feb 25, 2019 at 8:16 AM
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
  10. Feb 25, 2019 at 8:27 AM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    Amazon basics oil actually tested as well as mobil 1. i may try it.
    once my freebies are up i'll do 5k filter changes and 10k oil changes.
  11. Feb 25, 2019 at 8:43 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    You can get $12 Rebates a few times a year on Mobil 1, runs about $23 at Wal-Mart, I usually buy a couple jugs and keep them stashed away and it's half the cost of Amazon oil.
  12. Feb 25, 2019 at 8:49 AM
    Rockoma5
    St Louis
    Amazon Oil is made by Warren....same as SuperTech...I can tell you I have used it and I cannot tell difference from Mobil One...which I have used for 18 years! I have made the switch
    commbubba19[QUOTED] likes this.
  13. Feb 25, 2019 at 8:52 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    I am a big fan of DIY, but these quick lube places have made it so easy and cheap that I can't justify the time to do it myself for a marginal cost savings. Even that savings I question because if you do it yourself you lose that valuable Carfax stamp showing you changed the oil.
  14. Feb 25, 2019 at 8:53 AM
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    sub'ed
  15. Feb 25, 2019 at 9:02 AM
    #35
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    My Tacoma will be the first vehicle I've ever owned that I won't change the oil in myself, due to not wanting to fall into a gray area with my warranty.
    Local dealership charges around $55 with tax.
  16. Feb 25, 2019 at 9:05 AM
    #36
    Rockoma5
    St Louis
    I could care less about the CarFax....doesn't add any more or less value than the guy DIY and keeping receipts and a record. I like doing it myself. I use a Mityvac oil extractor and while that is draining the oil I drain the oil filter canister and change the filter. Add in new oil...pump the old oil back into the oil canister's I used and done. Easy peasy and clean. Plus when using the Super Tech oil or Amazon oil I use now I can do a full synthetic change for about $25....
    I do agree the quick lube places can be cheap with the right coupon or sale.
  17. Feb 25, 2019 at 9:08 AM
    #37
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I write every oil change in my manual, with mileage, date, and brands used.
    I guarantee you this is worth more to a potential buyer than Carfax oil changes. I know for a fact that this practice has yielded more $$ on motorcycles I've sold.
  18. Feb 25, 2019 at 9:08 AM
    #38
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    That's actually a killer deal. $41.25 per oil change is worth it if you value your time and convenience. Oil changes are a easy DIY job. But you gotta factor in buying 2x 5 quarts the first time. Oem tacoma filters in bulk to save money and a toyota specific oil filter wrench. Then it's a messy job and you have to recycle your oil afterwards. If you live in an apartment or condo that doesnt let you wrench then your sol. Sometimes the dealership or mechanic is the way to go.
  19. Feb 25, 2019 at 12:03 PM
    #39
    Sungod
    St Augustine
    If I were buying from an individual, I agree. The problem is in this internet world that you won't get the look. People scan the internet and Carfax reports are prominently displayed. I would probably pass by a car that has no history showing in the report because there are too many cars to consider that is an easy exclusion. That is the same mindset a sales manager or someone looking at auction will think as well. There is no way to tell if it is a person that cares so much that they do the work themselves or someone that is just to lazy to get the work done at all. Considering there are probably more people in the later category, it wouldn't be worth the risk.
  20. Feb 25, 2019 at 1:08 PM
    #40
    LS14ME2
    LS14ME2 Kind of a big deal
    In hiding, CA
    2017 SSM Sport DCSB 4x4
    Center console divider thingy, rubber bed mat and side steps for the wife.
    I have just done the second freebie for my truck, at a whopping 9K miles. I have always been a big DYI and still do my own OC's on the Corvette and Avalon. I think due to the fact the Taco will only need yearly OC's, this may be the first new vehicle that goes to the dealer for the OC's and the included tire rotations etc.
