Cost of regear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LuckeyTRD, Oct 10, 2010.
  1. Oct 10, 2010 at 8:03 PM
    LuckeyTRD
    LuckeyTRD [OP] rIDIN wHEELIEz!!
    Cole
    Evans, GA
    2010 PreRunner ALL TERRAIN
    BHLM, Blacked out tails, window tint 5%, tinted windshield , 8000k hids hi/lo and fogs. Black side badges, debadged tailgate, camburg 1.25" uniball UCA's, Camburg 4" spindles, ext. brake lines, Fox remote resi coilovers. Fox 2.0 Pro series rear piggybacks, 3" Allpro Leaf pack, OEM roof rack, Brush guard. Custom TRD allterrain decals. UWS low profile black toolbox
    going to be installing the ARB air locker with diff gears 4.11's if thats possible.... i dont know too much about rear ends so id appreciate the help. also if anyone knows the best gears and how much they will cost as well. THANKS
  2. Oct 10, 2010 at 8:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Figure about $500 to $650 per axel for parts and labor. Price of the locker will add to the total cost.
  3. Oct 10, 2010 at 8:16 PM
    LuckeyTRD
    Cole
    Evans, GA
    its a prerunner so thats not too bad and thanks. are 4.11's possible to run with our trucks? im running 33's so what kind of mpg and power increase should i be looking at?
  4. Oct 10, 2010 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Power should be very close to that of a stock truck with 31" tires. MPG should be the same as stock, maybe just a little less depending on how you drive.
  5. Oct 10, 2010 at 8:23 PM
    LuckeyTRD
    Cole
    Evans, GA
    thanks chris
  6. Oct 10, 2010 at 8:24 PM
    BGrutter
    BGrutter Well-Known Member
    Baron
    Kansas City, MO
    2010 4x4 DCSB TRD OR
    Rear-View Camera Mod, Anti-theft Tailgate, No Mud-Flaps, Diff Breather Mod, Color-matched Mirror/Handle covers, Front Valance mod, Phone/GPS/Camera mount, and Illuminated 4x4 Switch ToyTec Ultimate Lift Light Racing UCAs
    Instead of posting a new topic, I suppose I'll just Hijack ;)
    What about re-gearing a 09+ TRD OR? Does the locking rear differential, Auto-LSD, or A-TRAC have any impact on the change over? If so, what else needs to be done? New locker? Additional parts? Additional labor?
  7. Oct 10, 2010 at 8:25 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    You should be able to get the right size gears for the differential.
  8. Oct 10, 2010 at 8:38 PM
    BGrutter
    Baron
    Kansas City, MO
    Is that a response to my question? Do you mean that the gears would just swap out without affecting any of the things I mentioned?
  9. Oct 10, 2010 at 8:39 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Yes it was toward you. Sounds right.
  10. Oct 11, 2010 at 5:35 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Why not go 4.56 instead of 4.11?
    I'm doing a good bit of research myself and after I pay for my insanely expensive driveway I may go that route myself.
  11. Oct 11, 2010 at 8:45 PM
    LuckeyTRD
    Cole
    Evans, GA
    well i do a good bit of highway driving and id rather keep stock rpms instead of running 3200 at 70 mph.
  12. Oct 11, 2010 at 8:56 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Iv said it a hundred times ill say it once more, its NOT the rpm that will kills you its ENGINE LOAD! So you might be at 3.2k rpms on the freeway with 4.56 and 2.6k with 4.11 at 70, you might actually be making your engine work a lot less increasing fuel.
    Right now im 33.1" and 4:11 gears on a 4 banger. 8 get better mileage driving 70 with 33.1 then i did at 60 with 265 75 16
    raydenking likes this.
  13. Oct 11, 2010 at 9:08 PM
    LuckeyTRD
    Cole
    Evans, GA
    which is why im going with 4.11's and i have 33's. i didnt ask for info on 4.56's bc ive already made up my mind about that.
  14. Oct 11, 2010 at 9:22 PM
    08pretaco
    az
    Labor is about 4 to 6 hours anyplace i called. So labor is about 450 to 550 for install of just the rear locker and gear.
  15. Oct 11, 2010 at 9:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek: Thats alot more than I ever paid.....
  16. Oct 11, 2010 at 9:27 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i got a quote of 800 for front and rear plus parts
  17. Oct 11, 2010 at 9:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IIRC, I paid $1150 for the front and rear of my Dodge, including gears.
  18. Oct 11, 2010 at 9:38 PM
    Yoytoda
    Roland
    completely stock
    that sounds about right...
    400 per diff labor
    200 for parts
    the issue i see with 4.56s in a 4 banger is getting the front carrier out of a 3.73...
  19. Oct 11, 2010 at 9:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My gears were 300 for the rear, and about 280 for the front....but yeah......close enough. :eek:
  20. Oct 12, 2010 at 8:20 AM
    08pretaco
    az
    HEY chris 450 was from sierra expeditions for gear install, arb install and the wiring and whatnot that might be involved with it. First i called desert rat and they said 550. So if 450 is too high where do you suggest i go ask?
