Cost of regear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LuckeyTRD, Oct 10, 2010.
  1. Oct 12, 2010 at 10:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ok....That sounds about right for all that.
  2. Oct 12, 2010 at 10:06 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Which if i read correcly the OP is also installing an ARB with gears..
  3. Oct 12, 2010 at 10:45 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    ECGS.com (east coast gear supply). i was quoted $175 plus cost of install kit to install an LSD and do a master rebuilt.
  4. Jun 19, 2014 at 12:16 PM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    shop in austin texas quoted me at $2300. that is for an 2009 4x4 with e-locker
    (old thead i know, just trying to help people who use the search button)
  5. Mar 26, 2019 at 2:50 PM
    Rpurdy2.7
    Rpurdy2.7 Member
    Bobby
    2011 2.7 Reg Cab Tacoma 4x4 5 speed
    285R16 bfg all terrain tires Guardian level 8 wheels 3" toytec lift Tuff country uca's LCE header K&N cold air intake Aries grill gaurd Sterling equipment roll bar KC's Ionic tonneau cover Tow package with brake controller
    Sorry to post to an old thread, but I just had my 2011 Tacoma with 33s re-geared from 4.10s to 5.29s. I love the power but hate the fact my speedo is off by 15mph. Anybody heard of someone, some product, or some dealer that will recalibrate the speedo?
  6. May 4, 2019 at 11:02 PM
    gbit18
    gbit18 Member
    LA
    Tacoma 09
    Just curious how much you ended up spending on install and any recommended brand you went with?
    Had no clue that re-gearing should have been considered when changing tire sizes. How big of a tire would an 09 Taco be able to go with? Stock.
  7. May 5, 2019 at 11:09 AM
    Rpurdy2.7
    Rpurdy2.7 Member
    Bobby
    I got screwed, ended up paying a little over $4000 for 5.29 Yukon gears and a Yukon cone locker... The gears are great but I wouldnt get a cone locker again. Doesn't work for crap and it creaks and ticks all the time. I should have researched the 4x4 shop I went to better. Definitely like the power of the 5.29s but with 33" tires, 65mph puts me at 2800rpms... So if you do highway stuff a lot and don't tow, I would go 4.88 gears. I did buy a speedo calibrator so my speedo is perfect now. With no lift you can run 31" tires. Next for me is to get ARB air lockers.
  8. May 8, 2019 at 7:50 AM
    gbit18
    gbit18 Member
    LA
    Tacoma 09
    Thanks for sharing and sorry to hear about your experience.
    I’ll be towing a military trailer with camping gear, RTT, the full setup. Plus I’m still expanding on the body armor mods. I’m wondering if I should focus on the lift or the re-gear first. Truck has gotten heavy with the skid plates, sliders, and front bumper.
