Cost of Transfer Case Fluid
Discussion in 'Technical Chat' started by grubburg, Aug 17, 2020.
  1. Aug 17, 2020 at 3:47 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
  2. Aug 18, 2020 at 11:44 AM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    That's a good deal!
    and
    No.
    There have been multiple threads on this, on this site and others. Short answer is it's complicated.
    There is nothing else on the market with anything close to the same additives package as in LF. Not even Ravenol. So just take the hit and get it.
    grubburg [OP] and Gaper like this.
  3. Aug 18, 2020 at 11:50 AM
    Gaper
    Gaper Active Member
    Katie
    North East Tennessee
    2019 TRD Off Road DC
    I went down this rabbit hole when changing out our 4Runner's T case oil. After a month of research, what I demised is that the dealer is going to put whatever they have in the barrels in the shop in it and not follow the Toyota recommendation, but if you want to do it correctly, drop the money on the factory recommeded stuff and just be mad about it for awhile. I had to order 2 for the 4Runner only using about 4 oz of the second can. I will also say that I used AmSoil for the diffs and reused the bags the diff fluid came in to get to the T-case fill port. It worked well. YMMV.
  4. Aug 18, 2020 at 11:57 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I think the concensus is using RAVENOL 75w instead of the Toyota branded
    Vjtrey1 and whatstcp like this.
  5. Aug 18, 2020 at 11:59 AM
    VirusCage
    VirusCage Not currently contagious
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 1995 Landcruiser 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener!
  6. Aug 18, 2020 at 12:04 PM
    nudavinci64
    nudavinci64 Taco Outlaw
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Same went through it and there are several very close ones to use but no one has an exact. Toyota does not disclose the formula they use. Many use others like ravenal. I used amsoil last time but went with the Toyota for peace of mind. It’s pricey but figure there’s something thru out in it and if it keeps the truck going running and I feel better why not.
    I still can’t believe it’s $60.
    Gaper likes this.
  7. Aug 18, 2020 at 12:11 PM
    whatstcp
    whatstcp Professional incoherent spammer
    Ed
    Fontana, CA
    2006 Tacoma Regular Cab 2.7l 4x4
    King + Archive Relocation Wheeler's bumps +hydros
    Me over here knowing I put Valvoline transfer case fluid in mine
  8. Aug 18, 2020 at 12:13 PM
    tirediron
    tirediron Well-Known Member
    2018 4x4 Sport, Auto, BBP
    There's fluid in transfer cases???????????????????????????? :duh:
  9. Aug 18, 2020 at 1:27 PM
    VirusCage
    Allison Park, PA
    maybe, maybe not, Schrodinger's Gear Box
    Rockefelluh, tirediron and whatstcp like this.
  10. Aug 18, 2020 at 5:06 PM
    tirediron
    Serious question: What is so special about these transfer cases that they need fluid this specialized? I can sort of buy off on it for the transmission, but a transfer case is a relatively simple mechanism....
  11. Aug 18, 2020 at 5:55 PM
    pinem56
    NE
    2018 TRDOR DCSB AT
    Bob is the oil guy forum has independent lab tests on the additives in both LF and Ravenol. They are not equivalent.
    Others up north have indicated that in sub zero temps, LF is the only reliable option.
  12. Aug 18, 2020 at 6:07 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '98 Ext Cab V6 5speed, '16 DC OR M/T V6 Locked F/R
    KM2's, shocks
    There's a gerotor pump that probably prefers pumping the thinner fluids and the shift on the fly 4wd places demands on the one set of syncros much greater than what the transmission sees. Those syncros are asked to spin up and speed match a lot of inertia from rest up to the equivalent of 60 mph.
    There's nothing to suggest traditional oils won't work but something closer to what it was designed to function with helps some of the unique demands.
    I run Redline MT-LV.
    Greg.Brakes.Tacos likes this.
  13. Aug 18, 2020 at 6:49 PM
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    The Redline MT-LV is very good.
    https://www.redlineoil.com/mt-lv-70w75w
    Many people are also using the Ravenol and are pleased with that oil as well.
    https://www.amazon.com/Ravenol-J1C1003-Manual-Transmission-Fluid/dp/B00QPCL7ZE/
  14. Aug 18, 2020 at 7:54 PM
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    I did the ravenol about 20k ago, haven't had any issues, I switch to 4hi almost weekly on my short 8mis of back roads to the interstate (if not more) and vice versa heading home.
    I'll be doing it again likely with ravenol in another 10k. I tow firewood intermittently year round, live off a dusty dirt road and put 400mi/work week for driving perspective.
  15. Aug 20, 2020 at 8:13 PM
    6 gearT444E
    6 gearT444E CEO & CFO @BPF
    Deep South
    Herculiner Hootus
    I use redline MT90 in mine, haven't had any issues. That snake oil toyota is selling you is the same types of services they try and bend you over for at the dealership. Any oil is better than no oil
