Could I BE that stupid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DrRabbitFurHead, Apr 10, 2010.
  1. Apr 10, 2010 at 6:40 PM
    DrRabbitFurHead
    DrRabbitFurHead [OP] Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    What a day... Started off at 9am to install my new leaf springs, All Pro 8 way adjustable shocks and reinstall the u-bolt flip kit. Got the front wheels chocked, jacked up the back end the way I "thought" I should with a jack stand under each side of the rear axel and a jack under the frame rail of the side I was working on.
    Removed the shock, no problem.
    Removed the u-bolt flip kit, no problem.
    Removed the break line bracket, no problem.
    Removed the drivers side rear leaf, BIG PROBLEMS...
    First I couldn't get the bolts out of the bushings on the leafs.
    Second, I realized that I needed the frame of the truck up higher and the axels lower, but didn't have enough travel on my junk auto hydraullic jack. SO BEING SO SMART... I grabbed my hi-lift jack, jacked up my slider and tried to "help" get some separation to unload the rear springs and BAM! The unstable jack fell, truck slid a good 12" to the side, one jack stand fell over, the drivers side drum landed on the garage floor and the hydraullic jack was wedged under the truck. Somehow I got the hi-lift out, got the truck back up and got the truck stable.
    Went to the autoparts store, purchased a 2.5 ton Larin hydraullic jack and two 6 ton jack stands (24" high) and placed those under the frame rails. I've got the truck stable and now I've got a "tweaked" rear axel.
    I managed to remove the other leaf spring so that the rear axel "floats" as far as the brake lines and drive shaft will allow, I've gotten one of the OME rear leaf packs partially installed (it's sitting on the center pin and one end towards the front of the truck has the bolt through the leaf) and I called it a day.
    Does anyone have any advice for me? The back of the leaf springs (where the shackle is) is way up in the air. The passenger side of the axel is WAY too far forward and I'm going to have to find a way to move it into the correct position w/o killing myself.
    Anyone have some good tips or pointers?
    Thanks GOD the truck didn't fall on me while I was under it. I didn't know that I'd need FOUR jackstands to do this job safely, but now I do!
  2. Apr 10, 2010 at 6:41 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    yikes! glad to hear that you are okay!!
  3. Apr 10, 2010 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should be able to move the axel into the correct position with everything undone. Just be carfull.
  4. Apr 10, 2010 at 6:44 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Chris beat me. Glad all is well and wishing you luck for tomorrow. I suggest getting a friend over to help complete the job or help with whatever else may happen.
  5. Apr 10, 2010 at 6:45 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    In my best Tommy Boy accent, that was AWESOME!
    For future reference, PLEASE USE A VIDEO CAMERA FROM NOW ON.
  6. Apr 10, 2010 at 6:52 PM
    DrRabbitFurHead
    Salem, VA
    Any advice on a SAFE way to move the rear axel?
    I'm such a dork... I was taking pictures and writing down the directions with the intent of posting a How To... from beginning to end.
    (It turned out to be a How To... Almost Crap Your Pants...) :D
  7. Apr 10, 2010 at 6:54 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Glad you're ok!
    Still could be a "How Not To..."
    Those are often as valuable, maybe even more valuable, than a walkthrough showing everything going smoothly.
  8. Apr 10, 2010 at 6:56 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Glad you are OK , I worked with a guy that had a boat fall on him he had jacked up to work on the bottom , he broke his back ,
    OZ
  9. Apr 10, 2010 at 7:00 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I say it would still make a great how too. I often learn way more when I have trouble as opposed to when the porject goes perfect.
  10. Apr 10, 2010 at 9:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ummm....Dont let the truck fall on ya? :eek:
  11. Apr 10, 2010 at 9:22 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Not recommended by the Surgeon General!
  12. Apr 10, 2010 at 9:22 PM
    desertdude59
    Glad you're ok and didn't get smashed
  13. Apr 10, 2010 at 9:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. May also cause temporary blindness, and anal seepage.
  14. Apr 10, 2010 at 9:35 PM
    desertdude59
    :crapstorm::crapstorm:
  15. Apr 10, 2010 at 9:45 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Damn, bet that scared the shit outta ya! I recommend doing one side at a time, frame on jackstands, jack on pumpkin. This way you can lower the axle and work on getting the old leaf pack out and the new one in. Then you can kind of pivot the axle to get the pin lined up and jack it up into place.
  16. Apr 11, 2010 at 6:39 AM
    DrRabbitFurHead
    Salem, VA
    A good friend stopped by this morning (I skipped church) and we got things squared away. The trick was to get the bolt through the bushings towards the front of the truck on one side, set the leaf spring over the pin in the middle, install 'loosely' the u-bolt then jack up the drive shaft next to the pumpkin. This gave enough slack so that we could man handle the other side of the axel and get the 2nd spring into place. As of now I have both leafs installed, torqued properly, both u-bolts installed and torqued properly, the brake lines reconnected, torqued properly and I'm off to install the shocks tires and go for a test drive to see if the carrier bearing spacer is needed.
    Now off to see posts of rear resi's installed for pointers.
    All that WITHOUT further anal seepage... NICE!!!
  17. Apr 11, 2010 at 8:38 AM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    Phew!
  18. Apr 11, 2010 at 4:54 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Well now that it all turned out okay, I'm sure I speak for all of us based on your quote:
    :worthless:
  19. Apr 11, 2010 at 4:58 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    So the question is, if you were making a how to and documenting your progress by camera, did you get any pictures of the truck on the ground?
  20. Apr 11, 2010 at 5:23 PM
    DrRabbitFurHead
    Salem, VA
    Are you kidding? I was shaking like a leaf on a tree in a hurricane. I did get some pics up to the point where I struggled with the leaf springs and can post them up but they are all WRONG!
    Edited: here is what I managed to capture...
    Starting out wrong:
    Removing the rear shock:
    The tools needed to remove the rear shock:
    Removing the u-bolts:
    U-bolts removed:
    Trying to remove the rear shackle:
    One more of the rear shackle:
    I took several more and had 1/2 of a page written up with the 12mm socket to remove the brake line clip and all of the other dimensions but that made its way into the garbage at some point...
    Maybe when this is all done I'll do a write up w/o pics...
