Could I run a basic 6inch BDS lift with 5100s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bknelson, Jul 31, 2015.
  1. Jul 31, 2015 at 11:36 PM
    Bknelson
    Bknelson [OP] Member
    Toytec 3inch lift
    Hey everybody, I got a 3 inch lift on my Tacoma now, I wanna get some more out of it. I was looking at the basic BDS lift, the one with the ugly spacer and I was wondering if I have my 5100s in there already because of the lift I have now, would I need to even run the spacer? Or would I get to throw that in the garbage where it belongs? Thanks for the input and If anyone has pros and cons on the BDS that they have go ahead and share. Thanks guys, it's my second post on here hope to get to know you guys better
  2. Jul 31, 2015 at 11:39 PM
    Bknelson
    Toytec 3inch lift
    Those fox coilovers is dropping some serious dough haha
  3. Jul 31, 2015 at 11:45 PM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    Completely worth the money though for fox/icon/king coil overs
  4. Jul 31, 2015 at 11:47 PM
    Bknelson
    Toytec 3inch lift
    I just got the bilsteins about 5,000 miles ago so I was gonna keep them til they died then upgrade to coilovers and all that fancy smancy stuff
  5. Aug 1, 2015 at 12:21 AM
    Bknelson
    Toytec 3inch lift
    Would my 5100s work without the coil spacer?
  6. Aug 1, 2015 at 6:26 PM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    I'm pretty sure your gonna need to run the spacer. 5100 just compress the springs to get the lift.
  7. Aug 1, 2015 at 6:31 PM
    Bknelson
    Toytec 3inch lift
    I forgot to mention I have eibach coils as well that provide the lift
  8. Aug 1, 2015 at 6:34 PM
    Doak110
    Doak110 Well-Known Member
    Doug
    Howell , NJ
    2015 white Tacoma trd
    6in bds lift with Fox 2.5 factory coil overs and shocks Fuel rims 20x9 Toyo open country MT 33x12.50 Flow master cat back K&n cold air intake Bp fab grill 20in lightbar 2 3x3 Kc cubes 1.25in spider track wheel spacers HIDs headlights and fogs Red line hood struts Weather Tec mats
    They are deff worth the money and they look bad ass what more can you ask for
    Bknelson[OP] likes this.
  9. Aug 2, 2015 at 8:34 PM
    Bknelson
    Toytec 3inch lift
    Is that a BDS lift?
  10. Aug 2, 2015 at 9:11 PM
    Doak110
    Doug
    Howell , NJ
    Yes it is
  11. Aug 2, 2015 at 9:37 PM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, 18 x 9 -12 Weld Racing Ledge 6 wheels w 275/65r18 Toyo AT III tires
    You can run the adjustable 5100's with the stock coilovers with that kit but you will still need to run the top hat spacer. What I would recommend if wanting to run the bilsteins is run the F4-BE5-E122-T0. Basically it is a longer non adjustable 5100 shock for up front that is used with the rcd kit. I ran this on my truck and so did radtaco914. This eliminates the need to run the top hat spacer that comes with the basic kit.
    http://cppdiesel.com/RCDF4-BE5-E122-T0/
  12. Aug 2, 2015 at 10:39 PM
    Bknelson
    Toytec 3inch lift
    Was that a bitch to install?
    Even if I had the eibach coils It still wouldn't work?
  13. Aug 3, 2015 at 3:16 AM
    BORNWILDGUY
    Rich
    Florida
    The lift itself isn't bad to install at all. Yes but then you would be getting additional lift from the coils. The coils aren't going to give you the height necessary to avoid running the spacer. Remember on a db kit it lowers your crossmembers and that is what the top hat spacer does is makes up that difference on the factory length shock. If you run the longer bilsteins like I recommended you can avoid the top hat spacer.
    On the ebiach's you are running are they the 1.5 or 2.5 ones?
  14. Aug 4, 2015 at 11:46 PM
    Bknelson
    Toytec 3inch lift
    I believe I have the 1.5s and the top plate spacer from toytec
