Could it be a problem with the alternator or do I need a new battery?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomajules07, Jun 27, 2014.
  1. Jun 27, 2014 at 2:43 PM
    tacomajules07
    tacomajules07 [OP] New Member
    Sacramento
    07 TRD Sport
    I have a 2007 tacoma with 173k miles. About 2 weeks ago I had a full service done- oil change, transmission flush, alignment, new air filter, and drive belt replaced. I've never had any issues with a dead battery or truck not starting until today. My truck turns on- AC blows, radio, headlights, but my truck won't turn over and there is a clicking noise. The battery was last replaced in 2010. Could it be a problem with the alternator or do I need a new battery?
  2. Jun 27, 2014 at 2:48 PM
    stan23
    stan23 Well-Known Member
    stan
    Santa Clara, CA
    2022 DCSB TRD Sport 4x4
    Sounds like it's the starter.
    You can get your battery load tested, but i'm sure it will be fine.
    One test you can try is tap the starter with a mallet. If it starts, then you there's a strong chance it's the starter.
  3. Jun 27, 2014 at 8:56 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    I would put a bet on the battery.
    3 years is good. (I'm lucky to get 3 due to the heat).
    Do a load check.
    Yuma Taco,
  4. Jun 27, 2014 at 9:06 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Remove the terminals from the battery, clean the terminals and posts until they are shiney. Reinstall the terminals making sure they are both tight. If that doesn't solve the issue. Get a jump start and have the battery tested and or replaced.
    I'm betting it is the battery.
  5. Jun 28, 2014 at 2:33 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What kind of battery did you put in it back in 2010?
    Not all batteries are created equal and some are gonna last longer than others.
    I replaced my OEM battery after 5 years and there was nothing wrong with it. I did it as a precautionary measure. Because the OEM battery lasted so long, I put another OEM battery in it.
    Check all your connections and clean your terminals. But - it's probably the battery. The clicking sound means your battery doesn't have enough power/amps to start the truck. Or a cell went bad, etc.
  6. Jun 28, 2014 at 7:32 AM
    Ebg18t
    Ebg18t Member
    I 2nd cleaning and tightening the terminals, and put the battery on the charger. Then get the battery load tested.
  7. Jun 28, 2014 at 10:24 AM
    Nutzo333
    Nutzo333 FreakShow333
    Cory
    Canada
    Lifted 06 SR5
    6" Fabtech Lift, 315/70 r17 Duratracs, TRD Cold Air Intake MBRP stainless with duel side exit rear exhaust
    Is it a maintenance free battery? If not, make sure its topped up with distilled water. If you hear clicks when you turn the key, thats the solenoid barking for power, means low power (dead batt) If it was an alternator issue, truck wouldn't stay running after a boost.
  8. Jun 28, 2014 at 12:28 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    ^^ This is the answer.
  9. Jun 28, 2014 at 6:00 PM
    JDawg562
    JDawg562 Derp.
    Justin
    Long Beach, CA
    2007,TRD Off-Road, Access Cab
  10. Jun 28, 2014 at 7:13 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Im gonna agree with mostly everyone else here and say its the battery. Batteries are not created equal for sure. I've had several Toyota oem batteries last over 5 years, but i've had autozone or walmart batteries last 2 years and they are shot.
  11. Jun 28, 2014 at 9:18 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    charge battery fully, if you can not start it use a battery charger. then get a digital volt meter, they are $5-$10 at autozone or radio shack.
    put meter on it after charged, it should say 13.8 volts. now leave meter on it for several minutes, if battery is going bad in a few minutes you will see voltage slowly drop.
    also check water level in battery.
  12. Jun 28, 2014 at 9:31 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    Battery. My 07 appearently developed a parasitic drain that I can't find. So, if I don't drive it for two days, it does that exact same thing.
  13. Jun 28, 2014 at 9:36 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    do you have hi-amp draw accessories, amps, lights, inverter, etc? check your power and ground lines CAREFULLY!
    thats a sign of a line with a poor contact, maybe fraid or corrosion inside the plastic coating. it is constantly changing continuity which causes a small draw, i dealt with it before when EVERYTHING tested good and i still had a phantom draw. turned out that the 2ga power wire i had run inside the cab from battery started to get corrosion like you see on batt terminal on the inside some how.
  14. Jun 29, 2014 at 8:21 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    If the battery is fully charged, the terminals are all making good contact (no corrosion) and there is a click sound when you attempt to start you engine, the most probably cause are the solenoid contacts. Could also be worn stater motor brushes. Sometimes a tap on the starter with a hammer will reseat the contacts (or brushes) enough to start the engine.
