Could we revisit the sticky throttle issue?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rachelsdaddy, Mar 14, 2019.
  1. Mar 14, 2019 at 11:26 AM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I realize this has been brought up, I’ve read the threads but found no solution. My 99 2.7 auto does the same friggen thing occasionally. Almost like the throttle plate is wedged shut, gotta give the pedal a pop to free it up which is interesting in traffic. The throttle is clean, the cable is clean and free, the pedal mechanism is free and clean. I do have cruise but never use it. This is driving me nuts, some one suggested the cab has become insufficiently grounded and the truck is grounding itself through the throttle cable, I suppose that could be but seems to me like it would be a more frequent problem. This happens every other day or so and I really hope someone with the same problem, who corrected it could share some insight. Thank you
  2. Mar 14, 2019 at 11:29 AM
    tcjacado
    tcjacado Well-Known Member
  3. Mar 14, 2019 at 12:21 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    What part of the country you in? I had my throttle freeze shut on my 99 once.
  4. Mar 14, 2019 at 12:26 PM
    Rachelsdaddy
    Southern NH
    It’s not temp related. Happens year round. It’s the oddest and most aggravating thing. It actually takes quite a bit of force to pop it free from idle, then it’s fine for awhile then begins again. It’s just at the throttle closed position, like as you wait for a light. You put your foot on the pedal but it doesn’t move unless you quickly pop it. driving me absolutely batsh*t
  5. Mar 14, 2019 at 12:29 PM
    Rachelsdaddy
    Southern NH
    I should mention that the issue can not be duplicated by just grabbing and twisting the throttle. It doesn’t stick. Please help
  6. Mar 14, 2019 at 2:42 PM
    Bebop
    Nick
    Are you fly by cable or fly by wire? I know it came both ways but the cruise has a cable
  7. Mar 14, 2019 at 2:49 PM
    Rachelsdaddy
    Southern NH
    It’s an old fashioned cable to the cruise controller, old fashioned cable from there to the throttle. Free as a bird too. I’m beginning to think I need to burn some sage.. lol
  8. Mar 14, 2019 at 2:53 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I don't think '99 is by wire on any Toyo. engine.
    Maybe a worn bushing on some kind of roller mech.?
  9. Mar 14, 2019 at 2:54 PM
    Bebop
    Nick
    My 99 was fly by cable on the v6
  10. Mar 14, 2019 at 2:55 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    My '00 also.
    I would be really looking for a worn bushing under the dash since under the hood works so freely,
    cruiserguy likes this.
  11. Mar 14, 2019 at 2:58 PM
    Rachelsdaddy
    Southern NH
    You would think but I have been through everything a couple times now. The best way to describe it (just for discussion purposes...) is that the plate is under too much vacuum, once it’s cracked open it returns to normal. Obviously, that ain’t the problem but just a description. Im interested in hearing more about the possible grounding issue. I will entertain any suggestions at this point
  12. Mar 14, 2019 at 2:59 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I don't see how grounding to a non electric activated component is the problem.
    The only thing electric in there is the TPS. ANy codes?
  13. Mar 14, 2019 at 3:03 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    I don't mean to say a TPS can't cause an issue but you specifically said it feels bound up then releases and only at off idle.
    It sounds like a mechanical problem.
    12TRDTacoma and Wsidr1 like this.
  14. Mar 14, 2019 at 3:06 PM
    Rachelsdaddy
    Southern NH
    No, no... it was suggested that the throttle cable was actually providing a grounding path for the cab due to a deteriorated ground elsewhere... and was getting warm, creating resistance
  15. Mar 14, 2019 at 3:20 PM
    Rachelsdaddy
    Southern NH
    *mechanical resistance, lol
    cruxofthebisquit likes this.
  16. Mar 14, 2019 at 3:31 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Run a temp ground and see if it goes away.
    You should be able to see the ground strap going to the body if you look around the back. There is always one going to the firewall.
    I really don't know how this occurred to him but hey, if he;s right he's right.
    If you want like solutions maybe search for 'ground problems on 2.7'
    I really doubt anyone had the exact same problem as a ground can be goofy as hell in diagnosing but maybe similar and maybe in electrical forum also.
    My vote is a cable fray or fulcrum bushing Seen it lots from motorcycles and going looking for grounds would not be high on list.
  17. Mar 14, 2019 at 3:37 PM
    Bebop
    Nick
    You could undo the cable off the throttle and off the pedal and see how well it slides. If it feels binding there is cable lube they sell for motorcycles that will work. If the cable is internally frayed it will need to be replaced.
  18. Mar 14, 2019 at 3:42 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Everyone of them I've seen break (and wasn't on the fulcrum) was right at the inside edge of the sheathing, hiding it from sight.
    Bebop[QUOTED] likes this.
  19. Mar 14, 2019 at 4:00 PM
    scocar
    scocar hypotenoper
    Does this only happen when at idle position (foot off gas), or any time you apply throttle in any range? The vacuum concept is interesting. Does the 2.7 have anything like the idle air control valve (IAC) on the 3.4 throttle body? My 01 3.4 had this, and I didn't not have a problem with it, but it does provide a sort of air bypass around the throttle plate. If the 2.7 is similar, maybe this passage could be blocked or malfunctioning to some degree causing too much suction against the back of the plate on the plenum side.
    On 3.4, note hole in bottom before the plate
    This is the back side, area at bottom.
    Same side, better angle though, after cleaning.
    IAC attaches here (green plastic block, with sensor wires and coolant ports).
    Basically this thing (internet pic)
    43972d1304617551-starting-issue-not-star_a0353319f9bcba43bef83ced1650527e73309aef.jpg
  20. Mar 14, 2019 at 4:30 PM
    Bebop
    Nick
    Could be.
