Couldn't getOil filter to come off
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco_mike73, Jan 14, 2022.
  1. Jan 23, 2022 at 4:30 PM
    #101
    Taco_mike73
    Taco_mike73 [OP] Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    That's chilly for Georgia. Here it was 40 when I was messing with it last. Next day went in to the deep freeze.
  2. Jan 24, 2022 at 1:20 PM
    #102
    kapn
    kapn Well-Known Member
    Annapolis, MD
    2016 TRDORLB Blue
    I had a heck of a time with mine after my last dealer change. Used the Motive tool and a breaker bar. When I got it off I found the filter was crushed down a bit. They had put a filter in that was too tall and then cranked it down super tight to get it to fit. Replaced the housing with the metal one and now do my changes so no more problems.
    tacotoe likes this.
  3. Jan 24, 2022 at 2:01 PM
    #103
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i wonder if a little grease around the perimeter would do better than the thin 0w20 oil
  4. Jan 24, 2022 at 8:35 PM
    #104
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    This is what I did, I used a Ryobi Mid-Torque Impact. I have done this on both my Tacoma and a friends Camry. It came out easy with no damage to the housing. The plastic took it like a champ.
    I replaced it with the Aluminum housing, but I'm pretty sure the plastic housing can be used indefinitely.
    tacotoe and auskip07[QUOTED] like this.
  5. Jan 24, 2022 at 8:48 PM
    #105
    Montana_Actual
    Montana_Actual ;)
  6. Jan 25, 2022 at 10:05 AM
    #106
    Taco_mike73
    York, PA
    Do you use the Lithium spray lube and do you put it on the plastic threads and the o-ring or what?
    tacotoe likes this.
  7. Jan 25, 2022 at 1:16 PM
    #107
    saint277
    saint277 Vigilo Confido
    The problem with the plastic filter housing is that it has much less friction than the aluminum housing. The wrench has a very hard time grabbing the material if its over torqued. A good trick is to put a piece of paper inside the filter wrench, paper is an abrasive material and will help the wrench grab the slippery plastic. That said if your have trouble getting the housing off, its been over torqued. The housing is o-ring sealed and has a locking tab, and so requires very little torque to seal and stay in place. Plastic has naturally high lubricity (this is what makes them hard to get off) and should not need a lubricant on the threads. If you are tightening the housing without a torque wrench and are using any muscles past your elbow you are going to hard and will have trouble getting it off. FYI the dealers wouldn't know a torque wrench if it hit them on the head and ALWAYS over torque these housing like 4 or 5 times what they need to be at, don't use there torque as a metric for how tight it should be. Aluminum housing are much better, its much easier to tell when the threads have bottomed out and the filter wrench has a much easier time grabbing the housing.
    Junkhead, tacotoe and Taco_mike73[OP] like this.
  8. Jan 25, 2022 at 2:01 PM
    #108
    Montana_Actual
    Montana_Actual ;)
    Never used the spray before. And it just goes on the o rings. I've always used it on the rubber parts and outside of traditional filters. If the housing was totally metal I'd put a tiny tiny amount of anti seize on the threads. Being plastic, white lithium won't hurt it but it's not necessary. Just don't over torque. A little bit of white lithium/anti seize goes a long way. It's like thread locker... No need to use a ton.
  9. Jan 25, 2022 at 2:20 PM
    #109
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    This is not how the wrench works on 3rd gen filter housing and other toyotas.
    There are notches on the wrench that you line up with ridges on the housing.
    skidooboy likes this.
  10. Jan 25, 2022 at 2:40 PM
    #110
    saint277
    The ridges don't carry any load, all the work is done by the flats in the bottom part of the wrench.
  11. Jan 25, 2022 at 3:10 PM
    #111
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
  12. Apr 13, 2022 at 12:42 PM
    #112
    urbanplanner
    urbanplanner Well-Known Member
    washington state
    Yep. I just did my first oil change coming off Toyota Care. I used an aftermarket tool that leverages the ridges and cracked the overtorqued housing. The right factory cup from Toyota and a 1/2 breaker bar got it off. My SA bought the new housing for me which was awesome of him. +1 on the right tool for the job.
  13. Apr 13, 2022 at 1:30 PM
    #113
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    A buddy that runs his repair shop thats done these filter changes told me to spray the housing threads with heavy duty silicon.
  14. Apr 13, 2022 at 1:33 PM
    #114
    saint277
    shouldn't need any kind of spray, just the correct torque and you shouldn't have any problems. when was the last time you saw a lube tech with a torque wrench?
    AZ Pete, shakerhood and Junkhead like this.
  15. Apr 13, 2022 at 1:37 PM
    #115
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
  16. Apr 13, 2022 at 1:37 PM
    #116
    saint277
    true
    Junkhead likes this.
  17. Apr 13, 2022 at 1:39 PM
    #117
    zoo truck
    None
    Whats a torque wrench? Only time i ever saw it used was on one of these youtube video's.
  18. Apr 13, 2022 at 1:40 PM
    #118
    saint277
    I know right?
  19. Apr 13, 2022 at 1:51 PM
    #119
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    100%.
    I never let the dealer do any maintenance and so far had zero issues with the housing. It really takes 5 extra minutes versus the old school oil filter.
    shakerhood and hfjeff like this.
  20. Apr 13, 2022 at 1:58 PM
    #120
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Threads like these make me just want to do the Baxter oil filter adapter + Toyota OEM Spin on filter and just be done with it. Pricey up front but long term I think it would be worth the hassle.
