couple nonTSB AAL insall questions
Discussion in 'Suspension' started by KingMoo, Dec 3, 2011.
  1. Dec 3, 2011 at 8:52 AM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    today my buddy and I are about to install the AALs on a my 2011 tacoma. Just have a couple questions before we start.
    1) there were no U-bolts provided. The vehicle has 10,000 miles on it. Do I need to pick up new U-bolts or longer U-bolts?
    2) I was told previously that rear end work doesn't affect alignment. However; reading through the AAL install thread I noticed some people stating the opposite. Do I need to get re-aligned after the install?
  2. Dec 3, 2011 at 8:56 AM
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    You will use the factory u-bolts. It should have came with new center leaf pins. I wouldn't worry about getting it alligned.
  3. Dec 3, 2011 at 10:28 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    I lifted the rear of the truck from the differential.
    do I take the shocks off while the load is still on the jack or do I let the jack stands take the load before removing the shocks?
  4. Dec 3, 2011 at 10:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your choice. Makes no difference.
  5. Dec 3, 2011 at 10:35 AM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    I promise you that if you touch the rear end it Will change your thrust and you Will need to align your wheels. there is such a small chance it wont but Id always check out. My new leafs pushed my LR toe out and my RR toe in, I had to loosen it on the rack to correct it. and after doing the springs I would of bet you the alignment was fine. but the Alignment rack said otherwise.
  6. Dec 3, 2011 at 10:40 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    thanks. I still dont really understand how this shock would come off nicely if it's under pressure...
  7. Dec 3, 2011 at 10:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You can remove them without jacking the truck off the ground. They come off easy.
  8. Dec 3, 2011 at 11:13 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    why do the bolt threads also rotate while the top nut is being removed from the shock?
  9. Dec 3, 2011 at 11:22 AM
    berg2065
    berg2065 Well-Known Member
    Phoenix
    11 reg cab 4x4
    5100's set at .85,eibachs, LR uca's, toytec 1.5" aal, ride rite bags, receiver hitch, ARE cap with bedrug, Thule rack, wet-okole cover, ultragauge, kenwood dnx5180 navi/receiver, ss rubi404 running factory doors and JL8
  10. Dec 3, 2011 at 11:34 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    yeah i'm using that sticky....
    I understand why it's turning. I just cant find a place to put a wrench on the other side to prevent it from turning. vice grips is what I was considering...
  11. Dec 3, 2011 at 11:36 AM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    is there not a flattened part of the very top of the bolt? above the threads?
  12. Dec 3, 2011 at 11:38 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    no there isnt
    i'm thinking it's likely under the boot. I guess the boots need to be lowered...
  13. Dec 3, 2011 at 11:40 AM
    Maverick904
    Kameron
    Northeast Florida
    well once you get the nut off. you should be able to compress the shocks by hand to get them below the mount and remove. It takes a bit to get it moving but once it starts it should start compressing relatively easily
  14. Dec 3, 2011 at 11:41 AM
    berg2065
    Phoenix
    11 reg cab 4x4
    i am not sure what shocks the sport uses....it might take an allen wrench in the top of the shaft
  15. Dec 3, 2011 at 11:42 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    sorry. these are bilstein 5100s
  16. Dec 3, 2011 at 11:46 AM
    berg2065
    Phoenix
    11 reg cab 4x4
    yeah, then it takes an allen wrench
    Good luck with install
  17. Dec 3, 2011 at 11:57 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    oh i see now. thanks. i never would have figured that out
  18. Dec 3, 2011 at 1:02 PM
    KingMoo
    Calgary
    Tacoma TRD Sport
    from the picture i'm not exaclty sure which bolt needs to be removed that's holding the brake lines to the axel. If it's the one i think then there's only one bolt on the driver's side...
  19. Dec 3, 2011 at 1:44 PM
    KingMoo
    Calgary
    Tacoma TRD Sport
    im not sure if the axel should be as loose as it is right now. this is sketchy business...
    does the long side of the AAL go towards the front or back?
  20. Dec 3, 2011 at 1:58 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
