Courtesy and Rock Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bstrange, Nov 13, 2017.
  1. Nov 13, 2017 at 2:13 PM
    bstrange
    bstrange [OP] Well-Known Member
    2017 Tacoma Off Road
    Four “courtesy lights”, one for each door, that come on and off with the dome light.
    Four “rock lights”, two each on the front and rear bumper, that come on manually with a switch. When I turn the rock lights on I want the courtesy lights to come on as well (for a total of 8 lights).
    The lights I chose pull about 200-300mA each. I didn’t want to draw this from the dome circuit so I had to put in interposing relays.
    My first stab at this did not include the timer. When S1 is set to “dome” and the dome light comes on R2 is engaged and powers L1-L4. However, there was a major problem. Since the dome lights are auto dimming the signal gets to a point that the relay rapidly opens and closes. When the lights are coming on or off theres a point where the “fading” signal is enough to engage the relay but not hold it so you get a burst of on-off-on-off-…… The lights flash and its pretty but a relay will not last long under these conditions.
    So I had to add the timer. This timer is really cool. There are several functions you can program it for. I used this on my bedlights. I programmed it to come on immediately when power is applied, turn off immediately when power is removed, and turn off after about 10 minutes if the power is left on. I didn’t want to shut the bed cover with the bed lights on and have it run down the battery.
    I had to program it differently for the dome light though. I put it for a delay on / delay off with inverted trigger. So as the dome light is pulling the signal low it gets to the point that it triggers the timer. At that point there is a delay before it drives the output high. This delay is programmed for just a split second, long enough to ignore the dome light signal until it gets fully charged / discharged. In other words there will be a point when the timer is triggered, a split second where it doesn’t care what the trigger is doing, and the output goes high. The same time delay is in place when the light turns off as well, except the lights stay on for a bit to let the dome circuit settle.
    This timer was programmed with function 10 and trigger 4.
    The final problem was that the timer trigger was “leaking” enough that the dome lights would never turn off. Adding D1 prevented this.
    The middle position of S1 turns off all the lights (dome lights still works but no exterior lights)(incognito mode).
    D2 allows the rock lights and the courtesy lights to both come on in the “rock” position.
    L1-L8 Lights
    https://www.amazon.com/gp/product/B01M0T8DT5/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
    S1 Switch
    https://www.amazon.com/gp/product/B01LZK50VO/ref=oh_aui_detailpage_o07_s01?ie=UTF8&psc=1
    D2 BIG Diode
    https://www.amazon.com/gp/product/B011CP4EFS/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
    R1 and R2 Relay
    https://www.amazon.com/gp/product/B00RV9ZUEO/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
    D1 Small Diode
    https://www.amazon.com/gp/product/B00W17LOBO/ref=oh_aui_detailpage_o05_s02?ie=UTF8&psc=1
    T1 Timer $20
    https://www.amazon.com/gp/product/B00PD65UGA/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
    MyTaco07, lpfe42, Kheiron and 9 others like this.
  2. Nov 13, 2017 at 2:32 PM
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    Awesome. Great write up. The schematic takes me back to my C-130 Avionics days.
    How did you mount the lights and run the wires?
    Pictures of the undercarriage.
    Side note..If Melissa McCarthy was involved in the Hollywood sex scandal... I'm never watching any movie again.
    Kolache007 likes this.
  3. Nov 13, 2017 at 2:59 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Looks awesome! I think the white works well without looking all “fast and the furious”
    Disclaimer: I love those movies lol.
    bstrange[OP] likes this.
  4. Nov 13, 2017 at 3:03 PM
    Rosewood
    Rosewood Well-Known Member
    Southern California
    2016 Magnetic Gray 2x4 Sport
    Really nice job.
  5. Nov 13, 2017 at 3:06 PM
    OSUTacoma
    OSUTacoma Well-Known Member
    OHIO
    2023 Lunar Rock TRDSport DCSB
    Looks great . I have gotten some LED strips from Matt Gecko , they arent istalled yet. I was also looking at LUXlighting system , theyre magnetic . Thats a great look you have there .
  6. Nov 13, 2017 at 4:52 PM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    I'm in the process of doing the same thing. I am going to be using 4 for the doors then 1 for each wheel well and finally 2 in the front and 2 in the back. Also using white.
  7. Nov 14, 2017 at 9:50 AM
    Corneeeeelius
    Corneeeeelius AMERICA!
    Cory
    MIssion Viejo, CA
    2017 TRD Sport 4x4 DCLB W/Tech
    What a fun truck!
    @bstrange Where did you tap the dome light circuit?
  8. Apr 29, 2018 at 7:06 PM
    KTJO 4x4
    KTJO 4x4 Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    I’m hoping you can help. I hooked up my wiring for my 4 Rock Lights and my 2 LED Strip Lights on each side. I used the following wiring diagram
    Everything is working just how I want it except for one thing...the Switch is not activating the side LED Strips to come on with the Rock Lights. So the Dome triggers the LED Strips on the side just like I want and the diode is preventing the Rock Lights and Switch to activate. So I know that’s done correctly. The Switch triggers the Rock Lights in the Front and Rear to come on just like I want and the diode is preventing the back feed into the Dome Light to activate. So I know that’s done correctly. However, I have the diodes in a location so that when I hit the switch it should power on all the lights: Rock/Coutesy Lights without backfeeding into the dome, but it’s not. My question is, what am I missing? I’m not really sure what I’m missing or maybe it’s just not possible without a timer or something.
    I feel like I have the flow going correctly for it all to work but it’s not
    My goal is to do the same as you. Have the switch turn on all the lights and have the dome just turn on the side lights.
  9. May 29, 2018 at 10:01 AM
    Corneeeeelius
    Cory
    MIssion Viejo, CA
    What a fun truck!
    Finally hooked this up last night. This is so awesome!
    KTJO 4x4 likes this.
  10. Jun 7, 2018 at 12:43 PM
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    following
  11. Mar 18, 2022 at 5:20 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Resurrecting this thread.
    The Amazon link for the timer doesn't work any more. Is there an alternative?
  12. Mar 18, 2022 at 8:03 AM
    COSTCOHOTDOG
    COSTCOHOTDOG Well-Known Member
    2018 TRD OR DCSB 6MT
  13. Nov 1, 2023 at 8:14 PM
    Dorf on Tacos
    Dorf on Tacos Member
    J
    Las Vegas
    2019 TRD Sport
    Throttle controller, air horn, I know, im just getting started
    Hi, i know this thread is 5-6 years old but the timer you posted doesnt seem to exist anymore. Could you elaborate on what it is? Like is it a type of a pcb module?
    And btw, awsome thread. Helping me tremendously,
    J
    T1 Timer $20
    https://www.amazon.com/gp/product/B00PD65UGA?ie=UTF8
  14. Nov 2, 2023 at 7:14 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
  15. Nov 3, 2023 at 2:46 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I used the Toyota kit I got from Sparks. It has four nice outside LEDs and two LEDs for under the dash that slowly dim to a nice dim light that stays on. It's a nice kit, comes on automatically when approaching your truck provided the key fob is on you and lights up the sides and under the truck some very nicely.
    OBXPaul likes this.
