Cowl Removal / Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gooch, Jun 3, 2012.
  1. Jun 3, 2012 at 7:41 PM
    Gooch
    Gooch [OP] Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Has anyone replaced the cowl (plastic piece under the windshield wiper arms) or possibly removed it and repainted it? I searched the 1st Gen forum but didn't find anything.
    Mine is badly faded but new ones are close to $400! I was thinking about trying to polish off the oxidation or maybe lightly sand it and then paint it (after removing it, of course).
    http://www.toyotapartszone.com/oem/toyota~panel~sub~assy~cowl~55700-04240.html
  2. Jun 3, 2012 at 8:13 PM
    Madjik_Man
    Colorado Front Range
    Somewhere in the "what have you done" thread is both TacoMX and I doing it.
    For an abbreviated visual, check my build. Here: http://www.tacomaworld.com/forum/1st-gen-builds/98326-madjik-mans-laugh-him-build-3.html#post4979728
    Mine was so faded it was light gray. It's simple to remove, take your time with the clips, they tend to break. I cleaned mine first, dried it, lightly sanded it with 320 grit, wiped it down with a duplicolor prep wipe, then primed and painted it.
    I painted my wiper arms too while I was at it.. .they were a bit faded and chipped.
  3. Jun 4, 2012 at 5:54 AM
    Gooch
    Orange County CA
    ^Thanks.
    Surprisingly, my wiper arms are in perfect shape. But my cowl piece looks like yours did before you painted it.
  4. Jun 4, 2012 at 6:51 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    I have always had good luck with Krylon Fusion paint for plastic. It's like $5 a can. No sanding or primer is needed. Just scrub it down with degreaser and dry it first. Satin black would make it look the most original.
  5. Jun 4, 2012 at 7:18 PM
    Gooch
    Orange County CA
    Thanks. I'll take before & after pictures and post them here.
  6. Oct 26, 2012 at 9:08 PM
    Gooch
    Orange County CA
    Before
  7. Oct 28, 2012 at 8:26 AM
    Gooch
    Orange County CA
    The bulk of this project was cleaning this thing. What a pain getting the crud off between the louvers.
    Anyway, I used Krylon Fusion Satin Black. No sanding or priming. We'll see how long it holds up.
  8. Oct 28, 2012 at 9:04 AM
    Madjik_Man
    Looks good.
    Mine just went through a brutal Colorado summer, read: intense UV, and it still looks like the day I painted it.
  9. Oct 28, 2012 at 9:18 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I would have used an adhesion promoter before the krylon, but looks good.
  10. Oct 28, 2012 at 11:23 AM
    Gooch
    Orange County CA
    Cheers.
    Has anyone tried painting their faded mud flaps? I was thinking of doing that next with the Satin Black. After that, maybe my fender flares.
    One of my side mirrors needs painting as well, but I'll use gloss black for that.
