Cracked Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raycie, May 21, 2008.
  1. May 21, 2008 at 11:44 AM
    raycie
    raycie [OP] Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Thought I would ask "actual" users for some input. About two months ago, I picked up a '07 tacoma from a co-worker. 2 days ago, I mounted a snugtop "superport" on it. Yesterday when I went out to the truck, I noticed a crack on the side composite bed on the drivers side rear. The crack looks to be "stress point" where ther bed rails attach to composite bed. of the three mounting points for the snugtop, the rear ones just happen to be above a rivet holding the rail to the side of the bed..
    Any ideas? Will be taking it in today or tomrrow, and have the service department look at it.. The guy on the phone said it may not be a warranty item, and I was like, "why not".. anyway, they may be very cool, or give me the runaround.. In any case, if they do not replace it, I need to patch it in such a way that it will not crack more..
  2. May 21, 2008 at 11:46 AM
    Phi Kai
    Phi Kai Active Member
    O-Town, FL
    2005 BSP DC LB TRD Sport 4x4
    Painted Wheels, Debadged Tailgate, Soon 5100s
    It kind of sounds like when you mounted the snugtop that you might have tightened something too much and it pulled on the rails cracking the bed...probably not covered under warranty...PICS?
  3. May 21, 2008 at 11:55 AM
    raycie
    Oahu, HI
    In need of $$$
    Possible, but I have cranked Kayak's down harder than when I mounted the snugtop.. Probably has something to do with the attchment point (for the side rail) being right there as well. The others are off to the side of the rivet. Will see what toyota has to say.. will post pictures later today..
    Q: If they don't fix it, how can I reinforce it?
  4. May 21, 2008 at 5:58 PM
    dbbd1
    dbbd1 Well-Known Member
    Pic's would help...
  5. May 31, 2008 at 12:16 AM
    TRDGRL
    TRDGRL My Toys.....
    TRDGRL
    RainForestVille, Honolulu, Hawaii
    '11 BLK Tacoma PreRunner TRD SR5 Access Cab
    See Signature.....
    So what did TOYOTA say ?
  6. May 31, 2008 at 9:53 AM
    gmwelder86
    gmwelder86 Member
    if they are just like C type clamps liek that are on my dads truck you could use a couple peice of 1/8 flat stock cut into like 6 inch lengths to put the weight onto a larger section of bed.
  7. May 31, 2008 at 11:18 AM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    How do you plan to fix the crack?
  8. Jun 3, 2008 at 8:05 PM
    Ranger275
    Ranger275 New Member
    05 Tacoma Pre-Runner Long Bed
    Stock
    I also have a cracked bed Driver side, next to the rear window. What did Toyota say,
