Cracking Noise from Windshield
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jjweber4540, Jan 17, 2011.
  1. Jan 17, 2011 at 8:57 PM
    jjweber4540
    jjweber4540 [OP] Member
    Sioux Falls, SD
    11 DC LB Sport
    Hey,
    So everytime I hit a bump at low speeds (5-30mph) and the suspension flexs even a little, around the windshield makes a laoud cracking noise. I did a search but only found articles about the cricket chirp motor noise, but this is different. I only know this because I also have this problem. I was wondering if anyone else had this problem? I have a 2011 DC LB Sport and have only had it for 3 weeks and the speedometer is off, Blower motor squeaks, and windshield cracks. I thought Toyota was suppose to be known for its quality. Oh well it is gonna be the Dealerships problem Saturday.
    Thanks guys.
  2. Jan 18, 2011 at 4:26 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    This happened to both the front and rear windshield of my subaru wrx. In the back there was a tab broken off of the glass on the edge, and on the front, the seal had broken and the glass was shifting when I went over bumps.
    either way have the dealership show their glass people and replace the windshield.
  3. Jan 18, 2011 at 5:20 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    Aim-ish country PA
    2008 P71
    Yes
    Mine has done it from day one. Seems to get worse when it is cold out. So far so good I have not had any I'll effects (knock on wood).
  4. Jan 18, 2011 at 5:33 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    I lubed up the rubber seal under the hood up by the windshield with 10w30 and that quieted mine down. Not sure if that's the source of your problem though. May be something simple like that??
  5. Jan 18, 2011 at 3:27 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Cedar Park / Austin
    2013 DCSB MGM TRD OR 4x4
    Fox 2.5 c/o, Camburg UCA, OME Dakar, Fox 2.0 rear, LED interior light kit, LED fogs, LED headlights, Nitto G2, MB black wheels, diff breather mod, All AMSOIL syn fluids, XRXS bed cross bars, full debagged, shortened OEM antenna mod, Wet suit seatcovers, and fog light any time mod.
    I have heard the same noise it sounds like some one tapping on the glass. I can't tell if the sound in from inside or outside of the truck. It is louder on colder days and happens when driving over rough roads or bumps. It makes no noise on smooth roads. Any known fixes?
  6. Jan 18, 2011 at 7:12 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    In my old toyota.. the steering column would contact the plastic shroud in temps below say.. 10F
  7. Jan 18, 2011 at 7:21 PM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
    My truck was doing that...it is the dash and the windshield hitting each other on the passenger side. I had a notepad shoved in between it, but now I have a cut piece from a rubber window tint squeegy shoved in there. Hope that helps...
    My dealer "can't hear it," and supposedly there is a TSB for it....
  8. Jan 18, 2011 at 7:56 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
