craigslist welder smoked my main wiring harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nomis88, Jul 8, 2020.
  1. Jul 8, 2020 at 7:04 PM
    #61
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    What welder worth his salt,doesn't take 10 seconds to look behind a frame for electrical BEFORE welding or cutting off hangers,etc.
  2. Jul 8, 2020 at 7:07 PM
    #62
    Nomis88
    Nomis88 [OP] Well-Known Member
    max
    17 taco
    ill show it off after I get my relentless bumper in
  3. Jul 8, 2020 at 7:08 PM
    #63
    Nomis88
    max
    17 taco
    welllllll about 30 minutes into the job he said he just bought the welder last week. I shat myself then and there
  4. Jul 8, 2020 at 7:15 PM
    #64
    CountofQ
    CountofQ Well-Known Member
    Duluth, MN
    2017 'Old Man Tan' AC OR
    NO!!!! Those wires can and will short to each other, eventually. I am an electrician by trade, and that is an F'd up mess you have. One wire at a time, replace the burnt sections. Solder the connections and heat shrink over them each individually. Stagger them so that one spot does not get to big for the loom, where all the splices and heat shrinks will be.
    Drive at your own risk, until the job is complete.
  5. Jul 8, 2020 at 7:20 PM
    #65
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Cut and splice one at a time. Use solder and marine grade heat shrink that is adhesive lined. Put new split loom over it and you will be done in an hour. It will last as long as the rest of the wiring.
    20tacoma17 and michael roberts like this.
  6. Jul 8, 2020 at 7:31 PM
    #66
    lynlan1819
    Tacoma
    Lifted
    Wow so he thought he was good enough to do welding for customers a week after getting into welding.
  7. Jul 8, 2020 at 7:40 PM
    #67
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Properly splice in replacement wire for the burnt section. That is a correct repair. Heat shrink and wire loom and it will be fine.
    Electricity is not magic. It just has to have a path, and the path has to be controlled.
  8. Jul 8, 2020 at 7:42 PM
    #68
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    What did you think you needed a welder for on the hanger install?
  9. Jul 8, 2020 at 7:54 PM
    #69
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    Shrink wrap the wiring, tuck up the wiring and quickly trade it for another Tacoma before the wiring problems start.......
  10. Jul 8, 2020 at 7:57 PM
    #70
    MikeyD.25
    MikeyD.25 Well-Known Member
    What CountofQ said! :thumbsup:
  11. Jul 8, 2020 at 7:59 PM
    #71
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Did you pay the " welder " ?
    Chew likes this.
  12. Jul 8, 2020 at 8:05 PM
    #72
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Hit this guy up. I bet you could get his harness for next to nothing.
    https://www.tacomaworld.com/threads/k-who-dunnit.674991/
    VirusCage likes this.
  13. Jul 8, 2020 at 8:06 PM
    #73
    slowtacotruck
    17 offroad
    stuff
    Unless there is a CAN twisted pair in there there won't be any issues.
  14. Jul 8, 2020 at 8:08 PM
    #74
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    The technicians I work with in the power industry would horse laugh me if I asked them to splice small gauge wires with solder. Insulated Butt splices are what they use, with the proper crimp tool it’s fast and secure. And they are right, I used to be one of them.
    Pyrotech likes this.
  15. Jul 8, 2020 at 8:10 PM
    #75
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Cut, splice, solder, and heat shrink. cheap and effective.
  16. Jul 8, 2020 at 8:17 PM
    #76
    Nomis88
    max
    17 taco
    All sorts of people bitching about spending 5 hours grinding and drilling out the rivets. Burning them out is recommended and I thought I’d save some effort. WRONG
  17. Jul 8, 2020 at 8:31 PM
    #77
    hoarder23
    Shay
    NJ
    Scratches
    That requires a plasma cutter, not a harbor freight welder
  18. Jul 8, 2020 at 8:34 PM
    #78
    Nomis88
    max
    17 taco
    hahah clearly. I asked the guy about that and he said it didn’t matter. At that point I didn’t know he was full of shit
  19. Jul 8, 2020 at 8:43 PM
    #79
    svdude
    svdude Well-Known Member
    jonathan
    For small jobs, you can crank the heat up on a welder and burn through metal. So in this case a welder would work for that. Checking behind your work is still mandatory. Haha.
  20. Jul 8, 2020 at 8:49 PM
    #80
    slowtacotruck
    17 offroad
    stuff
    That's great until you have some salt or contaminants get in there. Then you start getting corrosion, then the resistance goes up, then it starts heating up which causes more resistance. I don't like having to redo other people's work in wiring, but if there's an electrical issue and I see previous wiring fixes that's the first place to look and usually the culprit.
    Edit
    A proper repair will work just fine and last forever.
    HisDad likes this.
