Crank seal leaking, so do cams and kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, May 24, 2019.
  1. May 24, 2019 at 11:23 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    Well after spending $750 on OEM parts and labor to replace my oil pan 2/3 weeks ago, I just saw another leak on the ground. I just got back from the guy who did my pan and said the leak is from the front crank seal. The guy I bought the truck from said he changed the timing belt with the kit, but I have no proof. I need the front crank seal changed and the 2 front cams seals too. I wonder if I should just do the whole kit, but he wants $500 labor to do so. I put 3 new belts on last year (AC, Alt, Power Steering)
    If I do so, I would go with the following kit + below bolt:
    https://www.ebay.com/itm/NEW-GENUIN...G-BELT-KIT-15-PCS-4RUNNER-TACOMA/231280476672
    https://www.ebay.com/itm/Genuine-To...-Bolt-90105-16031/372536703848?epid=657976027
    GQ7227 likes this.
  2. May 25, 2019 at 4:09 AM
    vettehigh
    Jon
    Upstate, NY
    I just woke up and remember being told it was $370 to do the timing kit, but if I wanted the water pump changed too, that would be an additional $130 ($500 total). Does not sound right. Isn't the water right there are simple to remove? The same guy did a great job on my oil pan replacement and only charged me $350 for that considering he had to drop everything also.
    BTW, he is $65 per hour
    cruxofthebisquit and GQ7227 like this.
  3. May 25, 2019 at 4:20 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    That doesn't sound unreasonable. One thing I can say, based off many guys experiences here, if you find a mechanic that actually does good work you keep him. He sounds trustworthy to me. Is there a warranty on the parts and labor?
    CS_AR likes this.
  4. May 25, 2019 at 4:28 AM
    vettehigh
    Jon
    Upstate, NY
    I buy my own OEM parts and bring them to him...not sure of labor warranty, have to ask. Being a sound Toyota tech, how long hour wise should it take to complete the 15 part kit?
    GQ7227 likes this.
  5. May 25, 2019 at 4:29 AM
    cruiserguy
    Elijah
    SLC
    Not sure what book time is but that doesn't sound out of line
  6. May 25, 2019 at 4:32 AM
    vettehigh
    Jon
    Upstate, NY
    I also told him, before he does any work to check first where the leak is coming from. Believe it's the front crank seal, but I want to know for sure. It could be the oil switch, oil pump etc... Don't want to go through all this work and $$$ to later find out another part was causing the leak
    GQ7227 and CS_AR like this.
  7. May 25, 2019 at 4:39 AM
    cruiserguy
    Elijah
    SLC
    Yeah, definitely make sure he diagnoses the leak first. That way the leak is actually fixed lol I mean I'd imagine that doesn't require saying to him but you better to be safe
  8. May 25, 2019 at 9:11 AM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    When my driver's side cam seal leaked, it went to the top of the oil pan. Looked like this.
  9. May 27, 2019 at 4:43 AM
    vettehigh
    Jon
    Upstate, NY
    Just a thought, would about changing the oil pump and seal while everything else is apart? Do these even go bad?
  10. May 27, 2019 at 5:05 AM
    cruiserguy
    Elijah
    SLC
    Can't be a bad idea to at least do the oil pump seal I'd think
  11. May 27, 2019 at 5:10 AM
    vettehigh
    Jon
    Upstate, NY
    Is that simple to do so?
  12. May 27, 2019 at 5:18 AM
    cruiserguy
    Elijah
    SLC
    Wait I confused you with a different thread. I thought your engine was pulled. Yeah your mechanic just needs to diagnose your leak first and depending on what needs to be done for that, than you can see about the well since you're doing that might as well do these things, etc
    vettehigh[QUOTED][OP] likes this.
  13. May 27, 2019 at 5:21 AM
    vettehigh
    Jon
    Upstate, NY
    Wish it was pulled, but no. First will be finding the exact cause of the leak...then go from there. Thanks
    cruiserguy and GQ7227 like this.
