Crank won’t turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nickj67, May 9, 2018.
  1. May 22, 2018 at 6:56 PM
    #241
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    Not necessarily it depends on the degree of separation between the Pistons.
  2. May 22, 2018 at 6:56 PM
    #242
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    nah, I'm seeing wrong.
    I'm having a hard time seeing straight lines anywhere, which just means I'm not good at perspective this way.
    Edit: Can we get a pan out of all 6?
    Edit2: #3 close ups at least. Something just doesn't seem right.
  3. May 22, 2018 at 7:11 PM
    #243
    cruxofthebisquit
    Orange Texas
    2000 TRD
    That thing should roll over unless jammed. I see no sign of rust being the culprit.
    Bearings.......eh, maybe. Never seen one "welded". Seen them spun to nothing left but I haven't seen everything....yet.
  4. May 22, 2018 at 7:13 PM
    #244
    Nickj67
    Nickj67 [OP] Well-Known Member
    2007 Tacoma trd prerunner
    Stock
    You guys just tell me what more pics/how/ of what and I will get them for you. Also if you want more taken off what tools I may need so that way I don’t have to grab/buy a ton of tools to bring home fro work that I don’t have to. By the way thanks for all the help!
    desertrunner24 likes this.
  5. May 22, 2018 at 7:16 PM
    #245
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    When you try to crank it it is in neutral right? It wont crank in gear...
  6. May 22, 2018 at 7:17 PM
    #246
    cruxofthebisquit
    Orange Texas
    2000 TRD
    It's about as neutral as it can be. It's sitting on it's ass.
  7. May 22, 2018 at 7:19 PM
    #247
    Jcyr
    Jack
    North east
    What do you mean as it can be? It’s either in gear or neutral
  8. May 22, 2018 at 7:20 PM
    #248
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Engine's out.
  9. May 22, 2018 at 7:25 PM
    #249
    cruxofthebisquit
    Orange Texas
    2000 TRD
  10. May 22, 2018 at 7:27 PM
    #250
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Does #3 have room to swing there?
  11. May 22, 2018 at 7:28 PM
    #251
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    DSCN0547.jpg Myself, I would pull the cap off this piston. If it's the problem rotating one way or the other should turn fairly easy. Piston looks scored but could be imaging tricks..should just need 12pt socket and breaker bar.
    TomTwo likes this.
  12. May 22, 2018 at 7:30 PM
    #252
    cruxofthebisquit
    Orange Texas
    2000 TRD
    There's def. a couple don't seem kosher.
  13. May 22, 2018 at 7:31 PM
    #253
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    @Nickj67, look at the connecting rod cap #2. There looks like something wedged between the connecting rod and main cap.
    Boneretreiver likes this.
  14. May 22, 2018 at 7:32 PM
    #254
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    I've got a klx 300 in my shop now that wouldn't turn. It ended up having a rust ring on top of the piston from sitting with water in it for an extended period. I've seen the same thing with jet skis. I think pulling the heads is a good idea. If that's not possible maybe stick a borescope down a plug hole to see what's up.
  15. May 22, 2018 at 7:32 PM
    #255
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I am starting to think this engine had a piston go bad and was running rough when it was turned off and seized up from sitting after that.
    20tacoma17 likes this.
  16. May 22, 2018 at 7:34 PM
    #256
    cruxofthebisquit
    Orange Texas
    2000 TRD
    If you pull caps and push pistons around, put some tubing on threaded studs so you don't scratch the crank.
  17. May 22, 2018 at 7:35 PM
    #257
    20tacoma17
    2017 DCLB Sport AT
    Well I think this Is OP's first time into an engine this far? Doing great so far.
  18. May 22, 2018 at 7:38 PM
    #258
    Nickj67
    Stock
    There is a lot of info here now. What do you guys think I should do next more pics or pull more stuff off?
  19. May 22, 2018 at 7:40 PM
    #259
    20tacoma17
    2017 DCLB Sport AT
    Well caps or heads. One or the other to find problem.
  20. May 22, 2018 at 7:42 PM
    #260
    cruxofthebisquit
    Orange Texas
    2000 TRD
    caps, if he pulls the heads and sees nothing he still has to go back to this. If he pulls caps and the crank moves, he knows it's the cylinders.
    TomTwo, Bobby18 and 20tacoma17 like this.
