Crank won’t turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nickj67, May 9, 2018.
  1. May 24, 2018 at 7:26 PM
    #401
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You could do it.....but price a shop to
    clean it
    flux it
    mic it
    heads just cleaned and looked at
    that's just to get started
    Slashaar[QUOTED] and TomTwo like this.
  2. May 24, 2018 at 7:30 PM
    #402
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Really do need to make sure it was a HG and not some other prob. though.
    Like "Why did it overheat"?
    So what did the coolant look like?
    Was the radiator as clean as the engine? What happened here.
    Even if you drop in anew one, you don't want the same thing to happen again.
    A heater core could have went out.
    TomTwo likes this.
  3. May 24, 2018 at 7:31 PM
    #403
    Nickj67
    Nickj67 [OP] Well-Known Member
    2007 Tacoma trd prerunner
    Stock
    What if I clean up the top of the Pistons and take new pics. Maybe they might clean up a bit
  4. May 24, 2018 at 7:34 PM
    #404
    Nickj67
    Stock
    Coolant was fine and full.
    TomTwo likes this.
  5. May 24, 2018 at 7:35 PM
    #405
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    I must have missed some posts. But it looks like you have the ability to rebuild it. Suggest have the block n heads taken to a good machine shop though.
    cosmicfires likes this.
  6. May 24, 2018 at 7:36 PM
    #406
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Sure, you're in no hurry now. Try anything you can to save whatever you can.
    BUT......taking them out and honing....even if you re use the rings.....is more gooder.
  7. May 24, 2018 at 7:37 PM
    #407
    Nickj67
    Stock
    Still don’t see a flood car and this kid wouldn’t have gone and done all that work to clean it. The only thing I could see is that the front end damage was it. It has a new rh headlight so maybe he drove with the busted on and rain/ water got in to the intake behind that light:notsure:
  8. May 24, 2018 at 7:39 PM
    #408
    cruxofthebisquit
    Orange Texas
    2000 TRD
    that's weird.
    A previous poster is right to say they don't just rust up from sitting. Mine sits A LOT.
  9. May 24, 2018 at 7:39 PM
    #409
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    Did you ever take the fuel sample? You need to get a sample from a fuel rail to see accurately what the engine last saw(clean clear glass jar)
    cruxofthebisquit and TomTwo like this.
  10. May 24, 2018 at 7:43 PM
    #410
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I would to try and move those pistons a little after you clean up the walls and spray in lube really well. Need to see what the rest of the cylinder walls look like and if you can get the crank to move at all? I think and hope the crank is fine after seeing everything else and its just a stuck piston or a few?
  11. May 24, 2018 at 7:44 PM
    #411
    cruxofthebisquit
    Orange Texas
    2000 TRD
    hmmm. I don't know.
    Did he drive it into a ditch?
  12. May 24, 2018 at 7:46 PM
    #412
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    @Nickj67 This is good advice.
    Slashaar and cruxofthebisquit like this.
  13. May 24, 2018 at 8:06 PM
    #413
    Nickj67
    Stock
    Agreed! That’s my plan clean them up then take the Pistons out.
    TomTwo[QUOTED] and Slashaar like this.
  14. May 24, 2018 at 8:08 PM
    #414
    20tacoma17
    2017 DCLB Sport AT
    Great, just keep them in order and match them up with the caps you removed. Keep us posted.
    TomTwo likes this.
  15. May 24, 2018 at 8:11 PM
    #415
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Rings will re seat easy if you hone. Did it on bikes a lot (rings are outrageously expensive for those) and you will be able to see if there is any heavy scoring.
    TomTwo likes this.
  16. May 24, 2018 at 8:16 PM
    #416
    Nickj67
    Stock
    You guys have been a great help! I know rust dose bad things but there is nothing broken/ bent so is that good thing?
    cosmicfires and TomTwo like this.
  17. May 24, 2018 at 8:25 PM
    #417
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Like seriously, I couldn't see myself NOT buying another Tacoma down the road when I'm due, just because of the community!
    Wishbone Runner, Scott B. and PzTank like this.
  18. May 24, 2018 at 8:32 PM
    #418
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Sure, it's buildable. In fact it looks good so far.
    Since it's not your daily you can learn in this thing at your leisure no matter what kind of bizzaro world type crap storm this thing had.
    edit: you're doing great, not directed at you. I just can't figure out what went on here. Bumper gone, sat up, fuel pump, rust.
    Nothing adds up.
    This is coming from someone who's tractor was 10 ft under the Gulf of Mexico, didn't get cleaned out for a month and ran fine after blowing out everything.
    TomTwo and 20tacoma17 like this.
  19. May 24, 2018 at 8:34 PM
    #419
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Is there any way to test out other components, like the trans, so he doesn't do all this work to find out the tranny is screwed up too or something?
  20. May 24, 2018 at 8:39 PM
    #420
    Nickj67
    Stock
    I towed it to my place with a strap so it went in neutral. Seems to go in and out of gear just fine
