Crank won’t turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nickj67, May 9, 2018.
  1. May 11, 2018 at 8:38 PM
    #41
    Nickj67
    Nickj67 [OP] Well-Known Member
    2007 Tacoma trd prerunner
    Stock
    I will get some more pics for you guys. Thanks for the help. Just wonder what is wrong with it after this much work
  2. May 11, 2018 at 8:38 PM
    #42
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    We are too, we're with ya brothah.
  3. May 11, 2018 at 9:51 PM
    #43
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    I'll give you 1200 for the truck lol
    PapaBear likes this.
  4. May 11, 2018 at 9:54 PM
    #44
    Nickj67
    Stock
    Sorry man the truck isn’t for sale. I’m hope to get it running and fixed up to give to my son.
    TomTwo and wilcam47 like this.
  5. May 11, 2018 at 10:01 PM
    #45
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Post picks from underneath looking up at the crank and the rods. Will the bore scope fit down the spark plug hole? If so, you need to inspect each cylinder.
  6. May 11, 2018 at 10:14 PM
    #46
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Subbed, I'm Interested
  7. May 11, 2018 at 10:26 PM
    #47
    Nickj67
    Stock
    I put it down the spark plug hole the camera wasn’t that good to show a picture. But the mystery oil was still on top of the rings. The camera came out wet.
  8. May 11, 2018 at 10:41 PM
    #48
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 TRD/ 2004 / 2019 SR5 4x4… now awd sprinter
  9. May 11, 2018 at 10:42 PM
    #49
    Tayoflor
    Tayoflor Well-Known Member
    Taylor
    Woodinville
    2013 DCSB MGM
    Leer topper BAMF weld on sliders BAMF LCA skids Icon stage 4 SCS F5s wrapped in 285/75r16 Cooper Stt Maxx
    We got a joker here
  10. May 11, 2018 at 10:53 PM
    #50
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    Does the truck still roll in neutral? Clutch seem to be operating fine, shift through all of the gears fine? I’d completely eliminate the tranny and even jack up the rear end. Starter gear break off and get stuck on the flywheel? So far it sounds like a locked up motor.
    wilcam47 likes this.
  11. May 11, 2018 at 11:06 PM
    #51
    Pork Chopper
    Dallas, TX
    07 DC 4x4
    Ethanol is a type of alcohol, and I believe ethanol is a product of making whiskey..... moonshine...
    Could somebody have known it was locked up and already tried pouring a ton of gas down it? Then blamed it on the starter?
  12. May 12, 2018 at 12:13 AM
    #52
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no timing belt. It has a timing chain.
  13. May 12, 2018 at 6:14 AM
    #53
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    7
    Ethanol is alcohol, the kind we can drink without dying immediately. Found in all alcoholic beverages maybe someone tried to make your taco run on moonshine
    Maticuno likes this.
  14. May 12, 2018 at 6:27 AM
    #54
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Have you checked the flywheel.
  15. May 12, 2018 at 6:28 AM
    #55
    Maticuno
    2011 Suburban 2500
    What did the old starter look like when you pulled it out? Was the bendix missing teeth?
  16. May 12, 2018 at 7:26 AM
    #56
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    Why the interest? Trying to get another DD cause the beast has to rest every once in a while?
  17. May 12, 2018 at 7:45 AM
    #57
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Previous owner filled it with E85. E85 ate the internals of the injectors and caused the fuel pump to over feed the cylinders. The engine hydro locked on fuel and bent atleast one connecting rod and/or washed out the cylinders and bearings.
    Thats my guess with the symptoms and smell of the oil over the interweb.
  18. May 12, 2018 at 7:46 AM
    #58
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    I think the only question that hasn't been asked is....
    can you post a picture of where you are putting the breaker bar to turn the crank?
    wilcam47 and cruxofthebisquit like this.
  19. May 12, 2018 at 7:49 PM
    #59
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Man, that's Carnac the Magnificent type diagnosis if it turns out to be correct.....and it certainly could.
    I can't see an engine locking that tight w/o something being bent and sometimes a connecting rod against a counterweight is hard to see.
    Slashaar likes this.
  20. May 12, 2018 at 7:55 PM
    #60
    Jimmyh
    SC
    2012 Prerunner SR5
    This theory can be put to rest as it is not possible. There are no rubber seals or soft parts to get eaten inside of a gasoline fuel injector. The injectors use a metal needle to metal seat as a sealing surface. E85 isn't going to eat that.
    Note: I'm not saying there couldn't have been a hydro lock from a leaking injector as it does happen rarely. But the E85 theory don't work.
