Crank won’t turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nickj67, May 9, 2018.
  1. May 15, 2018 at 6:14 AM
    #81
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mines been through plenty of "flood" water. Still runs great. :cool:
  2. May 15, 2018 at 6:28 AM
    #82
    Clearwater Bill
    Billy
    Largo Florida
    Huge difference in coolant quench from a blown head gasket and being submerged in a flood, or even hydrolocked from scooping water via the intake.
    I'm not saying @badneighbor is wrong. I just want to know what he's basing his internet guess on.
    And 'guess' (right or wrong) is all it is until we know what is preventing the motor from rotating. Or see it with a head off.
    ausfahrt likes this.
  3. May 15, 2018 at 6:55 AM
    #83
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    @Nickj67, have you tried a big ass 1” drive on that crank? Soak the cylinders, slap a pipe on the wrench, get a bud and bust it loose.
  4. May 15, 2018 at 8:41 AM
    #84
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Just curious, say you do that, and it doesn't turn, could it like, break your transmission?
    verynearlypure likes this.
  5. May 15, 2018 at 8:42 AM
    #85
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    It's been mentioned, just seems drastic not knowing what is holding.
    fast5speed likes this.
  6. May 15, 2018 at 8:43 AM
    #86
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Stranger things have happened.
  7. May 15, 2018 at 8:44 AM
    #87
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Nah, manual transmission are pretty tough. The rear tires will slide before the transmission let's loose. Now if you put it in 4wd, 1 st gear, and dump the clutch at 70 mph........Yeah, I would say metal will be removed from the truck somewhere
  8. May 15, 2018 at 8:47 AM
    #88
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Probably make some awesome noise though!
    cosmicfires and verynearlypure like this.
  9. May 15, 2018 at 8:47 AM
    #89
    Nomad_Pilot
    Clay
    Ft Collins
    It would be so loud.
  10. May 15, 2018 at 9:08 AM
    #90
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    How does the timing chain look on the other cylinder head not pictured. I wonder if the chain broke and is jammed around the sprocket at the crank.
    Seems there has to be something that is physically jammed at the ends of the crank. I've thrown bearings and busted rods before and I could still turn the motor. Even if it made a ton of noise. I would pull the front off to inspect the chain area and look around the flywheel as much as possible before you pull a head.
    Larzzzz and cruxofthebisquit like this.
  11. May 15, 2018 at 9:51 AM
    #91
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Since the timing components had to be disassembled (unless he has a torch) to pull the head I kind of was thinking along those lines, that he would find the problem on the way there or once there.
    It's just me but I don't think I've ever changed an engine w/o seeing what was wrong on the old one.
    EDIT: I guess he could just drop the driver's side sprocket. Plus it's good to know what you got. may find a block in a junkyard cheap that just needs what you have that is savable. i.e. Someone has taken a head.
  12. May 15, 2018 at 10:10 AM
    #92
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    I once got a old frozen outboard motor running again after soaking the cylinders for a few days.
    I'm looking forward to the outcome here and I keep coming back to read this thread to see how it ends.
    :confused:
    randd likes this.
  13. May 15, 2018 at 10:13 AM
    #93
    Clearwater Bill
    Billy
    Largo Florida
    No, he hasn't. That's why I keep saying 'it's time'
    See post 72
  14. May 15, 2018 at 10:18 AM
    #94
    Nomad_Pilot
    Clay
    Ft Collins
    He said he soaked them, just didn't fill them up to the tops of the spark plug holes like someone suggested
    Clearwater Bill likes this.
  15. May 15, 2018 at 10:21 AM
    #95
    kimo
    Knuckle Head
    Kauai
    A good soak and a 4' to 6' breaker bar and some elbow grease would have solved this by now.
  16. May 15, 2018 at 10:28 AM
    #96
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Even if there was some sort of mechanical binding?
  17. May 15, 2018 at 10:29 AM
    #97
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Yea, if it still is motionless, something is jammed. Even a 150# man standing on a 4' bar is 600 pound foot of torque.
    kimo[QUOTED] likes this.
  18. May 15, 2018 at 10:56 AM
    #98
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    I don't think that's how math works.
    EatSleepTacos and 4drtaco03 like this.
  19. May 15, 2018 at 10:58 AM
    #99
    ericd
    ericd Stuff
    Eric
    las vegas
    2013 DCSB 4x4 OR
    The pistons do not sit on a horizontal plane. A small amount of oil in the cylinder would only come in contact with the lowest area of rings. Even filling the cylinder up to the spark plug would only apply oil to half of the piston.
  20. May 15, 2018 at 11:02 AM
    #100
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
