Crank won’t turn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nickj67, May 9, 2018.
  1. May 15, 2018 at 7:40 PM
    #121
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Did Dad do all the oil changes for him?
    Yea, after a flood a person better get on it right away or mildew city.
  2. May 15, 2018 at 7:45 PM
    #122
    Nickj67
    Nickj67 [OP] Well-Known Member
    2007 Tacoma trd prerunner
    Stock
    Haha no I hope not. I have been doing collision work for about 20 years now. His dad was a writer for us. He says he had been writing for 25+ years. When I give him a outside door handle for a Range Rover and he says what’s this. Really man it’s a door handle. Now I see where the kid gets it!
  3. May 15, 2018 at 7:49 PM
    #123
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Well........it would help solve the mystery to know then laughs. Like maybe somebody said "Hey, Marvel Oil is good in the crankcase right? So let's put 3 quarts in it so it'll fool the VVT to rev higher".
    Can you get to a cap?
  4. May 15, 2018 at 8:00 PM
    #124
    Nickj67
    Stock
    With the pic you put up I see what you are taking about. If I can get on them / angle is another story but maybe. I should fill the cylinder with marvel ?
    cruxofthebisquit likes this.
  5. May 15, 2018 at 8:01 PM
    #125
    cruxofthebisquit
    Orange Texas
    2000 TRD
    yea, give it another shot. Still have some?
    Rod caps definitely look easier. One of them is bound to be handy.
  6. May 15, 2018 at 8:44 PM
    #126
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    If you do take any caps off see if they are marked. If you need to put them back on you need to make sure they go back on the way they came off. If not mark them somehow so you dont flip them around.
    fast5speed and PzTank like this.
  7. May 15, 2018 at 10:32 PM
    #127
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    Since your on hold for some quality soaking time I would take a fuel sample from the fuel rail in a glass jar and see what you have.
    VirusCage and fast5speed like this.
  8. May 15, 2018 at 11:19 PM
    #128
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Why waste time and effort trying to pull a bearing cap with the engine in the truck when you can just check for end play of the crankshaft and the rods?
    But whatever.
    wilcam47, zimmmtaco and Jimmyh like this.
  9. May 16, 2018 at 8:02 AM
    #129
    cruxofthebisquit
    Orange Texas
    2000 TRD
    He can do both if he's playing around trying to nail it down. He said he's just learning about internals at this point. If it were a daily and had to be fixed pronto, you're right.
    I knew an old machinist growing up that had some kind of contraption that enabled him to turn a rod journal in place from underneath. Used to take a day of sanding/polishing/checking for clearance. I think he just enjoyed it.
  10. May 16, 2018 at 9:18 AM
    #130
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    In these first two pictures, did you clean the oil off of the timing chains and out of the valleys for the lifter buckets?
    If not, combined with the oil in the bottom of the pan, then I'd say it was run low on oil until seized.
  11. May 16, 2018 at 9:21 AM
    #131
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pretty much. Could part out components of the engine which are good, as well. More or less depending upon what all the replacement engine comes with.
  12. May 16, 2018 at 10:08 AM
    #132
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    He can drive to southern NJ and pick my 05' engine up for cheap. Has 140k on it, although, if I was swapping I'd want a 08+ (IIRC, head gasket fix) with low mileage.
  13. May 16, 2018 at 11:27 AM
    #133
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Another possibility. It's looking bad for OP. Well, except the deal he got on the body. It will make a good truck again no matter the remedy. I wish I had the patience to do body work but well, I don't. Add to it I hate paint, any paint.
  14. May 16, 2018 at 11:49 AM
    #134
    Sandyman
    Sandyman Well-Known Member
    Sandy
    Los Anchorage
    '12 DC Sport Limo
    Just me
    I wonder? Back at beginning of previous presidential administration there was an auto buy back program. We were told that any vehicle bought back by the gov'ment would have a chemical pored in the oil and run to seize the engine so it couldn't ever be used again. Maybe somebody used that on this engine as a prank revenge.
    Just a thought, it looks way to clean for a natural death. Even at that you would suspect some discoloration on bearing caps if they seized.
    OP, have you tried to rotate engine backwards a little? Maybe something dropped inside a sparkplug hole (though I don't know what).
  15. May 16, 2018 at 12:00 PM
    #135
    cruxofthebisquit
    Orange Texas
    2000 TRD
    It was the stuff used to 'fix' blown head gaskets. It hardens like concrete would have shown up in the pictures.
    I know the oil pan look/smell doesn't add up to what the engine itself looks like. It does look like someone ran something besides oil in it.
  16. May 16, 2018 at 12:06 PM
    #136
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
  17. May 16, 2018 at 1:12 PM
    #137
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He has a point. Although I doubt the OP is that naive.
  18. May 16, 2018 at 1:19 PM
    #138
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Get the mother of all breaker bars and turn that motor over. When I get hydrolocked engines I can usually turn the crank a little in both directions. If it’s completley stuck then you more than likely have a frozen bearing. Lack of oil may have welded that crank still.
    04doublecab and kimo like this.
  19. May 16, 2018 at 1:22 PM
    #139
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    No school like the old school!
    Bebop[QUOTED] likes this.
  20. May 16, 2018 at 1:53 PM
    #140
    TNTermite
    TNTermite Member
    2010 SR5 4x4 Access Cab 6Spd long bed
    Any signs of wheelin':bikewhoops:? Just a hypothesis:confused: here after reading all the posts and evidence presented thus far… Perhaps the kid went wheelin to impress some girls :muscleflexing:, it was cold out… he stopped at a car wash and left the engine running (to keep his girl warm) and sprayed too much water into the intake ducts. Any signs of mold/mildew on the air filter? Any signs of water in the intake ducts? The plug pictures are pointing to some type of moisture.
    Like everyone else, I’d like to know what is happening inside :sawzall:. Start a go fund me… I’m thinking some of us would contribute just to know…:cheers:
