Cranks but won’t fire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ole one pice, Sep 9, 2020.
  1. Sep 14, 2020 at 8:27 PM
    #41
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well all I got now is maybe you have bad gasoline.
    RedWings44 likes this.
  2. Sep 14, 2020 at 8:28 PM
    #42
    Bishop84
    Bishop84 Well-Known Member
    But how can the fuel be bad if it ran prior to repairs?
    Ole one pice[OP] likes this.
  3. Sep 14, 2020 at 8:31 PM
    #43
    Jimmyh
    SC
    2012 Prerunner SR5
    Good question.
    It will run on starting fluid as he said 30 seconds. So it has spark.
    Checked fuel pressure via gauge and he has fuel pressure.
    Checked Injector signals with a Noid Light. All come on.
    Cranks but will not run without starting fluid.
    And he says that the plugs are wet after an attempted start.
    That is what I get from reading the thread.
    The only variable I see would be the starting fluid it runs with it and without starting fluid it doesn't.
    Logic indicates a fuel problem.
    I really need to know the final outcome of this... It's killing me and the OP must be losing his mind.
  4. Sep 14, 2020 at 8:34 PM
    #44
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did you have anything done to the valvetrian when the head was off?
  5. Sep 14, 2020 at 8:41 PM
    #45
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    This - even if the gas went off, I would still expect a few coughs, pops and farts. I've never seen gas go so bad that it wouldn't make any noise unless it's VERY (years) old, and even then, you usually get something.
    wilcam47 and SR-71A like this.
  6. Sep 14, 2020 at 9:08 PM
    #46
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How much gas is in the tank anyway?
    SR-71A and Jimmyh like this.
  7. Sep 15, 2020 at 6:28 AM
    #47
    Jimmyh
    SC
    2012 Prerunner SR5
    He says he has fuel pressure ( although a bit high ). Maybe someone filled the tank with water...
    :notsure:
    CurtB likes this.
  8. Sep 15, 2020 at 6:38 AM
    #48
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    None of this makes sense to me. Especially if the gas was fine before this repair. Even if water got into the tank or something, it should still pop a little and run rough or at least sound like it wants to fire. He said the plugs were wet with gas (definitely a difference between that and water). Initially it made me think there was a computer issue causing the plugs to not fire for a security or safety reason. But it running on starting fluid tells me something different.
    Unless it is firing from compression like a diesel. However, I don't believe these engines get anywhere near enough compression to self ignite even something like starting fluid. But, if that was the case, spark would then be your issue still.
    wilcam47 and Ole one pice[OP] like this.
  9. Sep 15, 2020 at 7:08 AM
    #49
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Just curious if there is room to add a few gallons of fresh gas..
  10. Sep 15, 2020 at 7:42 AM
    #50
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I read through this thread this morning and now Im curious of the outcome as well.
    Does the I4 have the same fuel pressure requirements and check procedure as the V6? Almost 20 PSI over recommended seems odd
  11. Sep 15, 2020 at 8:42 AM
    #51
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    FWIW I was just listening to a pod cast from my favorite mechanic(Agco automotive)and he mentioned in his trouble shooting methods is that the fuel pressure should be read while cranking/running. Good head pressure is not always a sign of a good fuel pump. I guess he is saying dont forget volume. However I would think some fuel would be passed to give u a cough or sputter....
    maxtherat and SR-71A like this.
  12. Sep 15, 2020 at 7:25 PM
    #52
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes the fuel pressure for the 2TR-FE engine is the same as the V6 1GR-FE.
  13. Sep 15, 2020 at 8:20 PM
    #53
    Ole one pice
    Ole one pice [OP] Ky Cook
    Sheldon
    Kentucky
    2nd gen tacoma
    Custom front bumper Custom spare tire mount Custom skid plate Custom roof rack Custom spare tire an jerry can mount
    Yes it’s killing me and I have a half tank of gas
    wilcam47 likes this.
  14. Sep 15, 2020 at 8:21 PM
    #54
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    I put a half tank in 2 days before it went down I’m right at half tank
  15. Sep 15, 2020 at 8:23 PM
    #55
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    Yeah it won’t hit a lick I’m going to take the timing over back off tomorrow which I don’t want to do but I’ve got to see if the Crank sensor sprocket reader thing is in there correct
    SR-71A and TnShooter like this.
  16. Sep 15, 2020 at 8:24 PM
    #56
    Jimmyh
    SC
    2012 Prerunner SR5
    I wish I had more advice for you.
    Did you get any gasoline from the supply line to the rail, like squirt it into a bucket. Then pour a bit on the ground and see if it burns well?
    I know that is really grasping at straws.
  17. Sep 16, 2020 at 1:47 AM
    #57
    RedWings44
    Michigan
    Yes, but then then it makes no sense that it would still fire on starting fluid if timing is bad.
  18. Sep 17, 2020 at 5:27 AM
    #58
    SR-71A
    Zack
    Southern Maine
    So it doesnt bother anyone else that OPs pressure is reading way higher than the standard pressure - in which case Toyota recommends a new fuel pump? Per your post #11 on Pg 1
  19. Sep 17, 2020 at 5:35 AM
    #59
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    If the pressure is too high will it flood the engine?
  20. Sep 17, 2020 at 5:49 AM
    #60
    SR-71A
    Zack
    Southern Maine
    I really dont know, but almost 40% over the specified fuel pressure range doesn't seem insignificant.
