Cranks but won’t fire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ole one pice, Sep 9, 2020.
  1. Sep 22, 2020 at 4:34 PM
    #81
    Ole one pice
    Ole one pice [OP] Ky Cook
    Sheldon
    Kentucky
    2nd gen tacoma
    Custom front bumper Custom spare tire mount Custom skid plate Custom roof rack Custom spare tire an jerry can mount
    I had a local shop test the sensor with their meter and they got ohms they also ran a bunch of tests with a Zeus snap on scanner and couldn’t get anything
  2. Sep 22, 2020 at 6:23 PM
    #82
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    At this point... make sure your theft insurance is topped up, and leave it at the curb with the keys in it... oh... wait, that won't do any good either.
  3. Sep 22, 2020 at 8:06 PM
    #83
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The Cam Position Sensor should not read < 1 Ohm. As per the posted sheet it should read as follows:
    Cold - 835 - 1,400 Ohms
    Hot - 1,060 - 1,645 Ohm
    The < 1 Ohm is for reading the wires between the Cam Position Sensor connector and the ECU Connector. Zero would be perfect for a wire.
    It then checks each wire for a ground to body and it should read greater than 10,000 Ohms or 10K Ohms.
  4. Sep 22, 2020 at 8:20 PM
    #84
    tirediron
    Whoops... my mistake. I didn't read the whole thing, and missed the "disconnect from the ECU" bit; thought it seemed odd, but I was reading that as a pin-to-pin measurement through the ECU should be <1ohm. Going back to sleep now
  5. Sep 22, 2020 at 8:29 PM
    #85
    Jimmyh
    SC
    2012 Prerunner SR5
    It's all good. Just clearing it up.
    Ole one pice[OP] likes this.
  6. Sep 23, 2020 at 4:45 AM
    #86
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Confirm its getting gas. Pull all plugs, dry them off completely, put back in. Crank for thirty seconds, pull all plugs. Are they wet?
    wilcam47 and Ole one pice[OP] like this.
  7. Sep 26, 2020 at 9:58 AM
    #87
    sprucetrees
    sprucetrees Well-Known Member
    Ontario, Canada
    '̶0̶9̶ ̶D̶C̶S̶B̶ ̶T̶R̶D̶ ̶S̶p̶o̶rt̶ (RIP) '13 DCSB TRD Sport
    OME suspension, flippac, more to come...
    Bumping thread because I want to know what the problem is with this truck...
  8. Sep 26, 2020 at 9:08 PM
    #88
    Jimmyh
    SC
    2012 Prerunner SR5
    Any updated information?
    maxtherat and wilcam47 like this.
  9. Sep 28, 2020 at 8:37 AM
    #89
    jimmy c
    jimmy c Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
    I'm interested to find out also.
  10. Sep 28, 2020 at 3:24 PM
    #90
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    No not really I had it back at that shop we checked continuity on all the grounds and cleaned them Are use the clutch cancel to try and start it in gear at first second with no luck the normal Roll starting in first and second gear then I had a friend tell me around the neighborhood repeatedly dumping the clutch in first and second it was practically running I just didn’t do anything when I gave it gas
  11. Sep 29, 2020 at 7:44 PM
    #91
    Ole one pice
    Sheldon
    Kentucky
    2nd gen tacoma
    So all my injectors are pulsing with a noid light and each injector has Continuity at the harness and on the actual injector prongs I pulled the fuel rail out hooked everything up and the injectors are not spraying
  12. Sep 29, 2020 at 7:55 PM
    #92
    Jimmyh
    SC
    2012 Prerunner SR5
    Now we are back to fuel pressure...
  13. Sep 29, 2020 at 9:24 PM
    #93
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Is there a chance that it’s some kind of security fuel cutoff?
    RedWings44 and wilcam47 like this.
  14. Sep 29, 2020 at 10:27 PM
    #94
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    How? OP changed the head gasket, not the keys...
    it’s got to be something with the assembly. Makes no sense that the fuel pump would suddenly act up after a HG repair when it was fine before
    wilcam47 likes this.
  15. Sep 30, 2020 at 7:04 AM
    #95
    tirediron
    Pretty much all that's left. Keep walking back until you find fuel under pressure.
  16. Sep 30, 2020 at 7:11 AM
    #96
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I'm thinking maybe a security feature done by the computer, or perhaps a kink in the fuel line somewhere.
    maxtherat likes this.
  17. Sep 30, 2020 at 9:39 AM
    #97
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
    You say the fuel lines are different sizes. I believe that to be true. you say you have noid light on ALL injectors while cranking. you have fuel pressure. lifting the fuel rail up and crank motor and NO fuel comes from the injectors. With noid and fuel you should have spray while cranking. If not did you put something in the line to keep dirt out while doing gasket? Did you disturb the fuel rail to much and disturb dirt in the rail and clog up the injectors? I would remove injectors and have tested somewhere or replace them and clean the fuel rail out. This is starting to bother me, and its not mine.
    maxtherat and RedWings44 like this.
  18. Sep 30, 2020 at 9:41 AM
    #98
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
    remove fuel inlet and hold away from you. have someone crank the engine for a brief second and see if fuel sprays out. No open flames or smoking material around.
  19. Sep 30, 2020 at 10:28 AM
    #99
    tirediron
    Way to take out all the entertainment value! :bananadead:
    SR-71A likes this.
  20. Sep 30, 2020 at 3:16 PM
    #100
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I have to think you still have a timing issue either mechanically out of time or issues with timing signals. Maybe you are timed right, but the crank and cam position signals aren't reaching the ecu for some reason. Have you tried to verify timing signals by logging them during cranking? I never had to deep dive the 1GR-FE but it's SFI so it may require these signals before firing the injectors.
