Cranks but won’t fire
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ole one pice, Sep 9, 2020.
  1. Sep 30, 2020 at 3:45 PM
    #101
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    So we have
    57 psi of fuel pressure
    A new Fuel Pressure Regulator
    Noid Light that pulses on the injectors
    And still the injectors fail to fire?
    I don’t want to think that 57 psi is to much pressure for the injectors to over come, but at this point you have to think it is a very likely possibility.
    Me, being the type I am, might try to find a way to make an injector fire MANUALLY. Since you already have the fuel rail setting there.
    Just to be certain they don’t work, BEFORE I replaced the fuel pump.
    I won’t tell you that you should do that, I just don’t like doing fuel pumps.
    This has me baffled, I’ve never seen a fuel pump go bad by creating too much pressure.
    Then again, I don’t do this on a daily basis.
    Jimmyh likes this.
  2. Sep 30, 2020 at 7:48 PM
    #102
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Same here. I guess it is possible that too much pressure will prevent the injectors from opening...?
    He could use clips and connect an injector momentary to the battery to cycle it. Just don't leave it energized for extended periods of time the coil will fry. The coils should read about 12 Ohms across the terminals.
    SR-71A and TnShooter like this.
  3. Oct 1, 2020 at 6:57 AM
    #103
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    It will fire and run momentarily on happy-sniff, so that pretty much rules out timing issues.
    RedWings44 likes this.
  4. Oct 1, 2020 at 7:17 AM
    #104
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    I'm not to sure that rules out timing. I think it will run on starting fluid with the timing off a bit. Yes no?
    wilcam47 and SR-71A like this.
  5. Oct 1, 2020 at 7:38 AM
    #105
    tirediron
    You can get some flames and farts with starting fluid where you wouldn't with gasoline, but as the OP describes it as, "Starting right up and running for a second", I was interpreting that as normal running. If it starts and runs normally on ether, unlikely (IMO) to be a timing issue.
  6. Oct 3, 2020 at 9:42 AM
    #106
    Ole one pice
    Ole one pice [OP] Ky Cook
    Sheldon
    Kentucky
    2nd gen tacoma
    Custom front bumper Custom spare tire mount Custom skid plate Custom roof rack Custom spare tire an jerry can mount
    All right so finally figured out the fuel lines on the rail are different sizes a friend pointed out that normally the fuel in is the bigger of the two I had them switched where they come in to the engine bay it now runs but won’t go over 2000 RPMAnd the check engine light is flashing but not pulling any codes
    RedWings44 and dk_crew like this.
  7. Oct 3, 2020 at 10:28 AM
    #107
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Sounds like the ECU is in limp mode
    TnShooter likes this.
  8. Oct 3, 2020 at 11:19 AM
    #108
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Yes this! Try resetting the ecu to see if it’ll clear the fault.
  9. Oct 3, 2020 at 11:20 AM
    #109
    TnShooter
    Deogee
    STOCK
    Looks like Jimmy called this early.
    maxtherat, SR-71A, NCAmother and 3 others like this.
  10. Oct 4, 2020 at 10:33 AM
    #110
    Jimmyh
    SC
    2012 Prerunner SR5
    Yes, like in post # 25...
    Even a blind squirrel finds an acorn every now and then
  11. Oct 4, 2020 at 10:34 AM
    #111
    Jimmyh
    SC
    2012 Prerunner SR5
    Isn't a flashing CEL indicating a gross erratic misfire situation...
  12. Oct 4, 2020 at 10:36 AM
    #112
    Jimmyh
    SC
    2012 Prerunner SR5
    Glad you found it. Now for the flashing CEL and misfire.
    gearcruncher, dk_crew and TnShooter like this.
  13. Oct 5, 2020 at 5:12 AM
    #113
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Flashing CEL generally indicates an issue with the catalytic converters, but I'm not so sure that's the case here. Not going over a certain RPM also is an indication of a catalytic converter issue. I don't know if that was caused by using the starting fluid (I doubt it, but it is possible). I'd attempt resetting the ECU by unhooking the battery for a few minutes and then see what happens.
  14. Oct 5, 2020 at 11:33 AM
    #114
    maxtherat
    Inland Northwest
    Usually when CEL is on it means some sort of emissions fault and it needs to be checked out but not immediately. When CEL is flashing that means the condition is more serious and needs to be addressed immediately. I read this somewhere along in one of my many owners manuals.
