Crankshaft pulley removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ibdoubled, Apr 13, 2012.
  1. Apr 13, 2012 at 8:00 PM
    Ibdoubled
    Ibdoubled [OP] Active Member
    Dave
    Deming, nm
    1999 Tacoma
    Been fighting with the crankshaft pulley on my99 Tacoma, soaking prying etc, the nut came off easy but the pulley is being a bear. Any ideas?
  2. Apr 13, 2012 at 8:03 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    crank pulley puller? try "tapping" it with a hammer. spray lube into "keyhole". try get a long screw driver/pry bar behind the pulley to yank it forward little at a time (shimmy it off) ---- be carefull when removing not to yank it into the radiator!!! put some cardboard in between rad and pulley or put crank bolt back on a few threads.
  3. Apr 13, 2012 at 9:01 PM
    Ibdoubled
    Dave
    Deming, nm
    1999 Tacoma
    I probably will see if I have a puller but for some reason the manual I borrowed says not to use one, don't know why? The radiator is already out
  4. Apr 13, 2012 at 9:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Probably because they can damage the crankshaft which would be very very bad.
    If worst comes to worst you could use a puller with a nice big flat piece of metal between the puller and actual crank, spreading the load so you don't damage it.
  5. Apr 13, 2012 at 9:04 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I have found that a puller helps. A couple of times I have used the puller but only had to spin it by hand to get the pulley off. For some reason sometimes it won't pull off by hand, I don't know why.
  6. Apr 13, 2012 at 9:05 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Mine came off easily by hand FYI, so it can't be on there that tight.
  7. Apr 14, 2012 at 3:56 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yeah its not a tapered fit so just smack it a few times w/mallet & it should jar loose, but if ya had to use a puller it'd be a non event probably, it just needs to come off evenly...
  8. Apr 14, 2012 at 7:06 AM
    Ibdoubled
    Dave
    Deming, nm
    1999 Tacoma
    After fighting with that pulley last night I went out this morning hit it a few more times with the mallet and never thinking it would move, reached behind it and it slid right off and onto the shop floor. Actually chipped the inner edge of the pulley about an inch long piece peeled off. I'll probably make sure it doesn't have any burrs that would tear up the belt and give it a they. I don't think it would be enough to through it out of balance but I guess I'll find out
  9. Apr 14, 2012 at 7:13 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Funny how years of heating & cooling puts a death grip on shit huh....
    You're probably ok on the pulley.... glad it worked out & it's now off !! good job !:thumbsup:
  10. Apr 14, 2012 at 4:21 PM
    tacobo670
    Ray
    Las Vegas
    y was the radiator removed?
  11. Apr 15, 2012 at 9:12 AM
    Ibdoubled
    Dave
    Deming, nm
    1999 Tacoma
    Already took out the radiator because it's got a crack in in, looking for one of those too. I guess eBay is the place for that
  12. Sep 16, 2013 at 5:53 PM
    alpha beta
    alpha beta New Member
    Tacoma
    was the chankshaft pulley bolt standard or reverse thread?
  13. Sep 16, 2013 at 7:18 PM
    Tmiller3063
    Tmiller3063 Active Member
    04 Prerunner Limited
    Just did my timing belt and had to replace crankshaft pulley. Had to heat mine up to get it off so it ruined the seals. Replaced those as well and now all is good
