Crankshaft pully installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twiclo, Nov 30, 2020.
  1. Nov 30, 2020 at 5:37 PM
    twiclo
    twiclo [OP] Member
    I took my crankshaft pulley off to replace the seal but can't seem to get it back on all the way. My theory is that I haven't lined up the key on the inside diameter of the pulley with the key on the shaft. Problem is there's no key on the shaft that sticks out and I have no way of seeing where a key might be beyond the seal. Any tips for getting this thing to go on fully?
  2. Nov 30, 2020 at 5:37 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    What engine are you running ?
  3. Nov 30, 2020 at 5:39 PM
    twiclo
    twiclo [OP] Member
    V6
    (2006)
  4. Nov 30, 2020 at 5:42 PM
    twiclo
    twiclo [OP] Member
    Also, why does the keyway on this pulley run the entire length if there's no key on the shaft?
  5. Nov 30, 2020 at 6:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    There should be a key, it’s probably back in the timing cover?
    “Note: The Key notch is very hard to allign since it's inside the crank case. What I did was use an allen wrench as a guide. Also made a mark so I could line up. If done correctly the pulley will start to turn when contacting the case and will eventually slide right on to the knotch. You will know it worked once the pulley stays set.”
    https://www.tacomaworld.com/threads/nst-lite-weight-crank-pulley.17144/
    henryp and po35042 like this.
