Crap battery or is something wrong with my Taco?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Jun 10, 2012.
  1. Jun 10, 2012 at 8:03 PM
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    Earlier Today I swapped my headlight bulbs out, and to do it I removed the battery to gain access to my driver headlamp. It was pulled out for maybe 15 mins. It's about two years old and from Walmart. This leads me to dead battery...
    When I went to start the truck earler on the way to get dinner, I put the key in the ignition, turned it to start and it made one click and went completely dead. All electronics, everything. So I hooked it up to the jump started and a few mins later I was able to get it to start after a few unnecessary tries (during which I would bassicly see the interior lights come back on, give it 30 seconds and try to start it, which would once more kill everything).
    I get it to start, drive to get pizza. Same damn thing happens when I go to leave (granted, its a 1 mile drive so that wasn't much charge time). However when I jumped it at the pizza joint, it started to fire up, then kinda act like it was dying and slowly start, but the tachometer read as 0RPMs for about 5 or 6 seconds before jumping back up to about normal idle.
    I've been having some rough luck, so Idk if I'm just paranoid, but usually when a battery starts to go from my experience it'll atleast try to turn over or have difficulty starting before just completely going dead.
  2. Jun 10, 2012 at 8:08 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This isn't so much true anymore. I would get it load tested at Autozone ( for free ). Sometimes batteries just die.
  3. Jun 10, 2012 at 8:13 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i’m going to say battery. i had a prob with mine. i would not even try and start. or had a hard time when i had the jumper hooked up. new bat fixed.
  4. Jun 10, 2012 at 8:18 PM
    evanwile
    evanwile Canadian Pomp
    Evan
    Canada
    2018 TRD Sport 6M
    What I do to when I have a charging issue to tell if its either a dead battery or a cooked alternator is as follows. Start the truck and then disconnect the neg battery terminal. If the truck continues to run then the alternator is fine and it's most likey your battery. If the truck shuts off of sputters and spits then it could be just your alternator, or a combination of your alternator and battery.
    I'm not reccommending that you do this.. but it works for me. Best bet is to take your battery to a shop and have them test it, then go from there.
    Good luck!
  5. Jun 10, 2012 at 8:20 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Did you set the battery on concrete? I did this and the battery was dead afterwards...
  6. Jun 10, 2012 at 8:21 PM
    Khaos
    Bryant
    I got an AutoZone about a mile from me and on the way to work. Looks like I'll be getting up early, hopefully the battery is toast and I have to find a way to get some cash to get a new battery.
    This battery has done the same damn thing to me once before, but I may have left an interior light on that time, and it was six months ago. Should have forked over the extra cash for an Optima....
  7. Jun 10, 2012 at 8:22 PM
    Khaos
    Bryant
    Yeah, I did. Never would have crossed my mind that could even cause an issue... Anyone heard anything like this before?
  8. Jun 10, 2012 at 8:27 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    if i were you, i would spray a shitload of terminal cleaner on the terminals, use some steel wool or other abrasive and scrub the shit out of the terminals, hook the wires back on as tight as your biceps will tighten them, start it up, and run it for a solid hour. go out and feed her a hot supper somewhere, and see if it still persists. I hate fuckin battery/electrical issues.
  9. Jun 10, 2012 at 8:32 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    In my opinion if ur dome light and everything went dead then then I think it's the connection because a dead battery would usually power lights and radio unless it's completely gone which I don't think it is
  10. Jun 10, 2012 at 8:33 PM
    Beers
    Beers Well-Known Member
    Colorado
    12 TRD OR
    How old is the battery? The original in my Taco lasted 7 years before it died. Most batteries don't seem to last that long though.
    Another thing to check is that the battery terminal connections are solid. I recently replaced a battery in another pickup and the new one had a slightly smaller negative terminal that the previous. I was able to get the connector on snug but it could still rotate a little by hand. We started having similar problems with what you are describing that were intermittent and didn't make any sense. I ended up going back and readjusting the connectors so they made a solid contact and could not be moved on the battery. Truck has been fine ever since.
  11. Jun 10, 2012 at 8:38 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    mine did a few months ago. hadn't had any problems with it at all and one morning it was just done. jumped it off but the whole 40 mile drive to where i was going it was just running off alternator. tested the battery and got nothing, wouldn't start after that long drive either. jumped it off, drive to Advance, bought a new battery and changed it in the parking lot. no more problems. just one of those things OP.
  12. Jun 10, 2012 at 8:40 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    The cement thing is a load of crap! (Unless your whole battery is covered by acid)
    If you had power for the light then you turned over and it killed it then you did not get a good connection on the terminals or the terminal to wire connection is bad. Use a wire brush terminal cleaner on the battery and wires, reconnect.
    Make sure it is all good and tight. If you can turn it at all on the terminal you will have problems.
  13. Jun 10, 2012 at 8:42 PM
    lowrange
    lowrange Supreme Commander of the Army of the Tacoma
    Joe
    Are Can Saw
    15 TRD Sport
    Setting your battery on concrete will NOT harm or drain the battery.
  14. Jun 10, 2012 at 8:46 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    if you don't have 12v at the ecm, weird things happen. Sounds like a battery problem. Yes, I don't know why but I have seen concrete drain a battery before.
    get a brand new battery, not the kind of thing you want to cross your fingers over.
  15. Jun 10, 2012 at 8:48 PM
    landphil
    landphil Wishin' I was Fishin'
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    X1234567890, except for the "as tight as your biceps will tighten them"
    Most likely a poor connection the way it happened, disassemble, clean to bright metal, and reassemble snugly. Don't be too rough, don't stike the terminals either. That can break the lead internaly, and cause trouble.
    If the problem persists with nice, clean terminals, then charge (if needed) and load test the battery, and get a warranty replacement if necessary.
    The concrete draining a battery thing is a myth, and pure coincidence. Not a good idea anyway, battery acid will damage concrete.
    Edit, man, this thread is busy. Wasn't trying to repeat so many times.
  16. Jun 10, 2012 at 8:51 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Old wive's tale.
    Used to potentially be a problem with the old rubber cases back in the 50s, but it's no longer an issue with modern plastic cases.
    What happens us someone pulls their battery and puts it in the garage for 6 months, then blames the concrete for it being dead. Batteries will self-discharge within a couple of months.
  17. Jun 10, 2012 at 8:57 PM
    Khaos
    Bryant
    Plan for tomorrow is to hit Autozone on the way to work and get them to test the battery. I work at Lowes so I can grab some steel wool (and what else, baking soda I believe?) at work and clean the terminals Tuesday morning. I'm working till 11pm, worked a 10 hour day on 3 hours of sleep today, I'll be in a coma as soon as I hit the pillow.
    Say the battery is a goner, anyone wanna recommend a good yet cheap battery? I know cheap and good are usually antonyms in the auto world, but I'm completely broke and at the max on my credit card.
  18. Jun 10, 2012 at 9:06 PM
    nammer
    Nam
    Bradenton, Florida
    :rofl: agreed
  19. Jun 10, 2012 at 9:10 PM
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    Setting batteries on concrete will certainly drain them. Not sure about car batteries, but other types do.
    About your restart, that is normal when you disconect you battery. Every time I have on both of my tacomas they start up then immeadiatley shut off. Another start and everything is fine.
  20. Jun 10, 2012 at 9:17 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    did ya give the terminals a good tightening? Not gorrilla tight but you're talking major ampage here and upon starting could've jumped a terminal.
