Crap!!!!! I'm rubbing with brand new tires!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by comicnut25, Mar 1, 2010.
  1. Mar 1, 2010 at 5:44 AM
    comicnut25
    comicnut25 [OP] Well-Known Member
    Rob
    Stanwood Wa
    09 TRD 4X4
    Alright guys just got my set up put on yesterday . Let's start with the lift it's a 3 inch leveling kit from rough country. My tires are 275/55r20. Im gonna post pictures once the sun comes up because my truck looks awesome ! So I barely rub on the inside not the mud flap but right below the coils. Any suggestions? Seems like the only way is wheel spacers ! And I didn't want to do that !
    Thanks
    rob
    here are the photos
  2. Mar 1, 2010 at 5:48 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What rim? Backspacing?
  3. Mar 1, 2010 at 5:54 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    It's a boss 20x8.5 330 rim offset 108.2
    Does that sound right? I'm not a wheel guy but my shop said they would fit!
  4. Mar 1, 2010 at 5:57 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    5.4 inch backspacing
  5. Mar 1, 2010 at 6:00 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You have a backspacing of around 5" according to my calculations. It should be 4.5" or less. The 20mm offset is what is hurting you. It should be negative.
  6. Mar 1, 2010 at 6:00 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    Also I have to be allllll the way cranked to rub
  7. Mar 1, 2010 at 6:03 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    Ahhhh should have checked with you guys before I did anything ! So what can I do to help this? 6 inch lift? New shocks?
  8. Mar 1, 2010 at 6:03 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Wheel spacers. The lift isn't going to do anything for that rub.
  9. Mar 1, 2010 at 6:07 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    I assumed that would be the answer ! Didn't want to though what do you reccomend ? I had spidertrax on my jeep!
  10. Mar 1, 2010 at 6:14 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    Says all sales are final on the invoice but it's worth a shot I guess ! My prob is I already sold my stock wheels/tires :)
  11. Mar 1, 2010 at 8:08 AM
    comicnut25
    Rob
    Stanwood Wa
    09 TRD 4X4
    here we are
    if i'm turned all the way if rubs there
  12. Mar 1, 2010 at 8:10 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yep, gonna need spacers.
  13. Mar 1, 2010 at 8:16 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    All of the aftermarket upper control arms give you more clearance between the tire and the arm. If that's the only place you're rubbing, UCA's or wheel spacers will fix your problem.
  14. Mar 1, 2010 at 8:18 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    If you had Spidertrax on your Jeep and had a good experience with them then get some for your Taco! :)
  15. Mar 1, 2010 at 8:19 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Depending on the jeep, they may even fit the taco.
  16. Mar 1, 2010 at 8:22 AM
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    Or get the right offset and not use any spacers! ;)
    Damn 20" rims gotta ruin things.
  17. Mar 1, 2010 at 8:23 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    If the wheel shop told you that they would fit and they don't I would be taking this conversation to them. You were the customer and the "experts" told you to get a certain size rim/tire you should hold them to their advice.
    Tell them to make it right!
  18. Mar 1, 2010 at 8:25 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Technically the wheel does fit, if he were running stock width.
  19. Mar 1, 2010 at 8:25 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Yeah go to the shop first, but if all else fails then throw the wheel spacers on! I had mine for a while and had no issues at all! :D
  20. Mar 1, 2010 at 8:26 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    This...
