Crappy ride
Discussion in 'Suspension' started by matt1381, Jul 20, 2013.
  1. Jul 20, 2013 at 2:19 PM
    matt1381
    matt1381 [OP] Well-Known Member
    Independence, KY
    05 4x4 SR5 TRD
    OME 885 Front Coils All Pro 3 inch Leaf Springs 285 75 16 Pro Comp All-Terrains
    I have a 2005 DC and have bilstein 5100s all around, OME885, and all pro 3 inch rear leaf and I can feel ever bump on the road. I have a pretty bouncy ride most of the time. Any ideas why that's happening? Tires re 285 75 16 toyo open county. I even tried the stock wheels and tires and the ride was the same.
  2. Jul 21, 2013 at 12:47 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    It's the lift......that's what they do, they stiffen up the suspension. Makes it nice offroad but can suck at times on the street. Has the ride quality recently changed? If so, shocks fading/blown or springs are toast. Check your air pressure too. The more air in the tires the firmer the ride. I keep mine in the low 30's......may be time for a better coilover up front and rear shocks?
  3. Jul 21, 2013 at 8:08 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Info says 884 :confused:
    Is ur aal a progressive?
    Spring perch isn't upside down?
    Standard 5100 in the rear?
    U could be topping out if so... They are good for 1.5" supposedly..... But even at stock height the shocks are not long enough and limit droop
  4. Jul 21, 2013 at 10:53 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I had the 884s (same spring rate just a shorter spring) and it was rougher than stock for sure. It honestly took a while to grow on me and I hated it when I had to drive on crappy roads because I felt like I was getting my salad tossed. You're achieving lift through the higher spring rate. I noticed my ride softened after I put a tool box and sliders on because of the extra weight. That being said, i'm sure it'll grow on you as it did me; it's just such a big change from the plush stock ride if you're not expecting it.
  5. Jul 21, 2013 at 10:54 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    What's your tire pressure?
  6. Jul 22, 2013 at 1:20 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 PreRunner TRD V6
    - OME suspension - Custom front/rear tube bumpers - 33x12.5r15 BFG KOs - Deckplate mod + AFE reusable filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - Pioneer stereo and new speakers + 10" sub - camper shell
    it's a truck. they come with crappy rides from the factory. never meant to be nice and comfortable, it was meant to be able go anywhere and everywhere.
    but that being said, I can almost bet it's the combination of your OME coils and Bilstein shocks. they are not meant to be put together and I can attest that my 5100/881 combo isn't the nicest ride ever. I'd try changing your shocks or coils and see where you stand.
  7. Jul 22, 2013 at 5:23 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    Do you have the 5100s set at zero or are they on one of the pre-load settings? With the OME coils you should only have them set to 0.
  8. Jul 22, 2013 at 9:25 AM
    matt1381
    Independence, KY
    05 4x4 SR5 TRD
    I have the 885 as I upgraded from the 884 that had about 50,000 and 7 years on them. I also took out the add-a-leaf and switched the the all pro leaf pack. I have the correct 5100's for the rear and not the stock ride ones. When I had the 884 and add a leaf the ride was better than it is now but I'm not going back to that. I do have the shocks set at 0. My tire pressure is set between 30 and 32 and I check that weekly. The ride just always seems bouncy to me. Guess I just need to get used to it.
  9. Jul 22, 2013 at 9:27 AM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Load range on tires? I just switched from 885s and nitrochargers to icons for the same reason, it rides much smoother now.
  10. Jul 22, 2013 at 9:34 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Same setup as what I had and it sucked. I got rid of the 5100's and got home nitrochargers and it was night and day difference.
  11. Jul 22, 2013 at 9:39 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    :thumbsup:
  12. Jul 23, 2013 at 10:39 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    So, you're saying that Icon Coilovers will have a smoother ride than the Bilstein 5100/OME 885 combo on street?
  13. Jul 23, 2013 at 11:16 PM
    sodoscott
    sodoscott Well-Known Member
    south california
    2006 tacoma trd off road mid-travel
    kingshocks, total chaos
    Yeah check ur tire pressure ! Huge diffrence
  14. Jul 24, 2013 at 3:08 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Yes without question. Smoother on and off road for sure.
  15. Jul 24, 2013 at 3:25 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    No way around it!
  16. Jul 24, 2013 at 8:57 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Gotcha. Thank goodness I didn't order the 5100/885 setup then.
    So, now the question is....King or Icon Coilovers.
    Damn, this is getting too expensive...
  17. Jul 24, 2013 at 1:46 PM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    Icon will have the better on-road ride over the Kings due to their valving specs. If you were a race truck, i would tell you king.
  18. Jul 24, 2013 at 1:54 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    tire pressure??????
    first check.
  19. Jul 24, 2013 at 2:32 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
  20. Jul 24, 2013 at 2:41 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    5100s are still good shocks, and 885s actually have a lighter spring weight than icons/king. But from personal experience Icon has a much nicer feel on road. OME was nice and firm, so my truck handled great and barley had any body roll/brake dive, but i felt every bump. Main difference between icon and king is icon has digressive valving and king has progressive. How i understand it is king is better for high speed stuff, if you are looking for best on road ride and do mostly slow wheeling icon is awesome.
    Progressive vs digressive
    "For example, when the valves open or close, depending on the shock and valving design, the rate at which the damping becomes softer or stiffer per unit of shock velocity increase depends on if the valving is linear, progressive, or digressive. As the name suggests, in linear valving the rate at which the damping changes with the velocity of the shock is constant. If the valving is progressive, the rate of change of stiffness increases as velocity increases; and if the valving is digressive, the rate of change of damping gets less as the shocks velocity increases."
