Crashnburn80's 1st Gen TRD Double Cab Build
Discussion in '1st Gen. Builds (1995-2004)' started by crashnburn80, Apr 16, 2022.
  1. Jul 19, 2023 at 1:00 PM
    #321
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    Thanks for the tip, I may give that a try. It doesn't look as bad at a glance as the photos show, but in direct sunlight it is noticeable.
    6MTPro[QUOTED] likes this.
  2. Jul 19, 2023 at 1:02 PM
    #322
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
  3. Jul 19, 2023 at 11:23 PM
    #323
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Coming back from a bike ride today with my kid, I had a car on the right side of the road at a neighborhood entrance make a left across my lane toward me. Except they did not make the left into their lane, they made it into mine setting up a head on collision and maintained that course. Full on panic stop laying on the horn. But the Tacoma did not stop that fast at all. Fortunately the other vehicle swerved into their own lane at the last minute narrowly avoiding a head on collision. Brakes definitely need to be improved.
  4. Jul 20, 2023 at 2:31 AM
    #324
    Madjik_Man
    Colorado Front Range
    Did you already do your brake upgrade to the 1st gen? Or is it still stock?
  5. Jul 20, 2023 at 4:33 AM
    #325
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    glad you’re all ok. The 1st gen brakes definitely need improving. I had a similar emergency stop with mine when I thought they were ok and I stopped about 1” from impact with the other car. That next day I ordered reman 13wl tundra calipers from Napa and all other parts for the upgrade.
    if you want to “do it right” and not have to come back to it, check out https://adventuretaco.com/guide/step-by-step-tundra-brake-upgrade-on-a-tacoma-or-4runner/ and feel free to substitute in the StopTech cryo rotors and non-OEM pads.
  6. Jul 20, 2023 at 8:29 AM
    #326
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you're upgrading to the Tundra brakes, since you have an 01-04 with ABS and thus the single diaphragm booster and don't like the pedal feel after the brake upgrade, you could check out the SOS Sequoia master cylinder conversion which though made for a 1st gen Tundra, has the same booster bolt pattern as a Taco single booster bolt pattern. The feeback on pedal feel after the Tundra brake install is pretty variable, for instance 3rd gen t4r owners complain of a soft pedal, however after installing them on my wife's t4r and replacing front and rear hoses with ss and thoroughly bleeding the brakes, the pedal feels just as good as my 2nd gen Taco (which uses the same calipers with the brake line port in a slightly different position due to having front steer).
    crashnburn80[OP] and Madjik_Man like this.
  7. Jul 20, 2023 at 9:37 AM
    #327
    JasonLee
    15 TRD OffRoad
    My 2003 with ABS with the tundra 13wl swap felt good on the pedal. I didn’t touch the master cylinder or rear drums.
  8. Jul 20, 2023 at 11:57 AM
    #328
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That’s what the majority of 01-04 owners with ABS and the the single diaphragm booster and the 13/16” MC seem to experience. The non-ABS 01-04 and all 95.5-2000 trucks with the dual diaphragm booster and the 1” MC are apparently the group of people that tend to have a squishy pedal according to what I’ve seen here.
  9. Jul 20, 2023 at 10:26 PM
    #329
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Still stock brakes with whatever was on there when I bought it. I’ve had the fluid flushed and rears adjusted, but that’s it.
    I’ve seen the Tundra swap many times, I'm personally not a huge fan of the inter-vehicle-model brake swaps. Results seem all over the board whether the MC can actually handle the increased caliper capacity. On 2nd Gen this is the 4runner caliper swap, and some seem ok, others have never ending problems of soft pedal, excessive throw, lack of engagement. I looked at that on my 2nd Gen before going with a stoptech BBK instead as it was 100% proven without issue. On the 1st Gens the Tundra swap does seem far more adopted, countless companies offer a "BBK" using the Tundra components. I originally had planned to do just a pad and rotor upgrade, but with the heavy E-load 33s, the Tundra swap may be in order.
  10. Jul 21, 2023 at 5:55 AM
    #330
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Or.... Lighter tires.
    Norton likes this.
  11. Jul 21, 2023 at 6:40 AM
    #331
    JasonLee
    15 TRD OffRoad
    … and …
  12. Jul 21, 2023 at 6:41 AM
    #332
    Madjik_Man
    I have 265/75/16 “c rated” and the fairly light 96-02 T4R 5-spoke alloy wheels.
    I don’t think I’m going to do the Tundra upgrade but have your StopTech brake upgrade thread saved. That’s probably the route I’m going to go.
    Norton likes this.
  13. Jul 21, 2023 at 7:39 AM
    #333
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    What have you done in terms of replacing front and rear hoses?
    Norton likes this.
  14. Jul 21, 2023 at 10:23 AM
    #334
    JasonLee
    15 TRD OffRoad
    Replacing the stock rubber lines may improve performance somewhat, but not fix the sub par performance overall. And that’s with an unloaded, relatively stock truck other than heavy tires. For those 1st gens (over)loaded, stock brakes are unsafe.
  15. Jul 21, 2023 at 11:04 AM
    #335
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    When I replaced the rear hose with a ss one on my 3rd gen t4r which already had the Tundra front calipers and ss front hoses, I noticed a significant increase in performance. On my first gen Taco I have 5th gen t4r calipers and El Dorado rear calipers on a 9" axle with a GM 1 5/16" MC on 35" tires. I wanted to go with a Wilwood, however their bracket for the 2nd / 3rd gen doesn't have the correct inboard/outboard location (although by like 1/8-3/16" IRRC). If they made a correct bracket for a 1st gen you would be able to bolt up their 2nd / 3rd gen option. When going to 5th gen t4r calipers I went off of this table:
    https://www.tacomaworld.com/threads/tacoma-brakes-swaps-and-tech.468271/
    and Erik's 4x4 brake MC bore to caliper surface area graph (unfortunately his site is no longer online) to come up with a MC bore to match the piston surface area in the front.
  16. Jul 24, 2023 at 7:54 AM
    #336
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I've run several iterations and combos of Caliper and MC, Pads make more difference in a 1 off emergency stop than any of the easily available upgrades.
    Now if you are looking for peace of mind when doing (potentially) multiple hard stops with your over weight and larger tire rig, then larger rotor and corresponding caliper would be in order, but pads are still under appreciated in this community imo.
    I'm running 14WA Calipers with 2010 GX470 Rotors and now run Carbotech 1521 pads, now I have not run them with stock rotors/calipers, but the initial bite and ramp up is beyond the stock experience, and massively beyond any of the available Rock auto pads or Stoptech (Z23?) pads also available on rock auto.
    Empty_Lord and unstpible like this.
  17. Aug 7, 2023 at 10:55 PM
    #337
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    if it makes you feel any better about the swap, the 1st gen tundras with the 13WE or WL calipers use the same master cylinder as the 01-04 tacos. and the exact same rear brakes
    JasonLee and Dalandser like this.
  18. Aug 7, 2023 at 11:14 PM
    #338
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Was there ever any more information on the topic of 3 vs 2 relays on the ground switched harness from Headlight Services?
  19. Aug 8, 2023 at 7:16 AM
    #339
    Empty_Lord
    Dan
    My setup continues to work fine. Didn’t really dig into it much
    Madjik_Man and Digiratus[QUOTED] like this.
  20. Aug 8, 2023 at 7:07 PM
    #340
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That actually alleviates my main concerns about mixing and matching parts of the brake system yes.
    I honestly don't recall. I'll ping HS and see.
