Crawler Box Splines keep stripping.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by feesquivel, Nov 13, 2019.
  1. Nov 17, 2019 at 9:55 AM
    #81
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Take a caliper gauge and mic the coupler and the trans output. You might also want to give Wyatt at Rock Solid Toys a call. He's done a lot of these and maybe he's seen something similar before. He hasn't been on the site in a month but I'll page him anyway. @awsumdc
  2. Nov 17, 2019 at 9:56 AM
    #82
    feesquivel
    feesquivel [OP] Well-Known Member
    West Texas
    lol, he built my rig. Going through him just to get to Marlin. We are both stumped.
  3. Nov 17, 2019 at 9:59 AM
    #83
    theesotericone
    Bishop CA
    LOL. No shit? Well if the Marlin and Wyatt can't figure it out I doubt I will. The only ideas I have left are bad tolerances and possible mis-alignment. If it's bolting up tight that should rule out mis-alignment and leaves tolerances.
  4. Nov 17, 2019 at 7:20 PM
    #84
    gearcruncher
    Canadain bumper technician
    Tolerances and possibly missing lube ports in the shafts and gearing . Anytime helical gears are in constant mesh and considering this is a crawl box , you can bet there is a crazy amount of thrust load produced by the gearing . The pictures are saying lack of lube . I beleive the ring you removed is adjustable by the use of shims underneath it . Do you have the end play specs for the crawl box . Should there not be a lubrication hole in the shaft where you removed the ring ? That ring got hot for a reason . Either the crawlbox is assembled to tight or for some reason , you are not getting any lube to the gearing and bearings in that area . Its not uncommon for manufacturers to miss out on lubrication holes on the shafts and gearing . Before you assemble the crawlbox , try pumping some fluid through the holes in the shafts and gearing . You should see the shaft lube up . Wondering if an orifice is missdrilled or possibly plugged . That needle bearing needs lube or more lube than its getting right now . Gear slinging the oil wont lube this area . The oil needs to bleed from the orifices in the shaft . Wondering if Marlin could send you a couple pictures of new parts that are effected here showing the lubrication ports?
    Larzzzz, excorcist and garciav like this.
  5. Nov 20, 2019 at 12:42 PM
    #85
    feesquivel
    West Texas
    Thats what I am thinking, at first it was a tolerance issue but replacing parts doesn't help. So I am thinking maybe too much pressure is being applied on the thrust washer "burnt spacer ring". No shims on the ring, just a solid ring. The only lubrication port I see in the coupler is this small one (you can see me holding it in my hand). But do to centrifugal force when running I don't see how fluid gets in there, specially this being above the oil fill line.
    All coupler's I have received so far have the same weep hole.
  6. Nov 20, 2019 at 12:55 PM
    #86
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Can you post a link as to where you found that manuals have stock 4.10’s? Everything I’ve found states all second gens stock have 3.73’s. Thank you.
  7. Nov 20, 2019 at 1:02 PM
    #87
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    2ng gen 2.7L have 4.10's. All 2nd gen v6 have 3.73's I believe.
  8. Nov 20, 2019 at 2:12 PM
    #88
    QuicksandTaco
    Cody
    Oregon
    Ok that’s what I thought. Thanks
  9. Nov 20, 2019 at 3:15 PM
    #89
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    All the rust still seems weird to me..
    SC4333 likes this.
  10. Nov 20, 2019 at 3:17 PM
    #90
    SR-71A
    Zack
    Southern Maine
    4.10s for the 4x4 models. See page 17 for the full list of options if you're curious.
    BassAckwards likes this.
  11. Nov 20, 2019 at 3:19 PM
    #91
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    4x4 and prerunners got 4.10s all other 2.7s got 3.30s
  12. Nov 20, 2019 at 3:20 PM
    #92
    jowybyo
    Joe
    Baltimore, MD
    Are 5 lugs real Tacomas? :anonymous:
    BassAckwards[QUOTED] likes this.
  13. Nov 20, 2019 at 3:24 PM
    #93
    BassAckwards
    Damn right they are. Best thing they ever offered was a 5 lug v6:D
  14. Nov 20, 2019 at 3:25 PM
    #94
    SR-71A
    Zack
    Southern Maine
    Depends on AT vs MT. Screen shot might be easier
  15. Nov 20, 2019 at 3:27 PM
    #95
    jowybyo
    Joe
    Baltimore, MD
    Ok but surely x-runners aren’t real Tacomas.
  16. Nov 20, 2019 at 3:29 PM
    #96
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
  17. Nov 20, 2019 at 3:33 PM
    #97
    BassAckwards
    Interesting.. so based on this a 2.7L auto prerunner would have 3.58s? This is the first ive read of prerunners with the AT having different gears. Makes me want to do the spin test on my dads 2.7 auto now. I always thought prerunners/4x4 were all 4.10. thanks for pointing that out:fistbump:
    Idk, they look like tacomas to me:p
    SR-71A[QUOTED] likes this.
  18. Nov 20, 2019 at 4:27 PM
    #98
    jowybyo
    Joe
    Baltimore, MD
    Im pretty confident that all 2.7L Prerunners have 4.10s
  19. Nov 20, 2019 at 4:41 PM
    #99
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    Yeah I thought it was the manuals, but I guess its the 2.7 vs the 4.0
    QuicksandTaco[QUOTED] likes this.
  20. Nov 20, 2019 at 4:55 PM
    #100
    feesquivel
    West Texas
    I am not sure if its rust, or splines slowly fretting away. I believe its shavings from the splines going out through daily use.
