Crawler Box Splines keep stripping.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by feesquivel, Nov 13, 2019.
  1. Nov 21, 2019 at 9:25 PM
    #101
    hawaii_dave
    hawaii_dave Well-Known Member
    2017 trd pro
    I have an idea of what is going on with your splines. (Been a Mechanic for over 35 years ) My question for you is this. Are there alignment pins ( dowels pins ) anything other then just the bolts holding the two cases in alignment ? If there are no Pins then that is more then likely is your problem .
  2. Nov 21, 2019 at 9:44 PM
    #102
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
  3. Nov 21, 2019 at 9:48 PM
    #103
    hawaii_dave
    2017 trd pro
    Ok so much for my idea .
  4. Nov 23, 2019 at 4:15 PM
    #104
    feesquivel
    feesquivel [OP] Well-Known Member
    West Texas
    I am all up for ideas, even the simplest thing could be my issue. Right now im leaning towards lack of lubrication, so will probably top fill the crawl box, the question is how much gear oil? According to marlin I need to fill to the fill port level, drive around and re-fill so no precise capacity.
  5. Nov 23, 2019 at 8:04 PM
    #105
    6 gearT444E
    Deep South
    Herculiner Hootus
    I’d put around 3 qts or so in. If it starts puking out the shifters drain a bit out via the fill port. More oil is better in this application. On a R&P, not so much.
  6. Nov 24, 2019 at 4:36 PM
    #106
    gearcruncher
    Canadain bumper technician
    Sorry I am late to the game on this one .
    Is there an air vent on the top of this crawl box that allows this gearbox to vent to atmosphere ? If there is a vent hose , are you sure the tube is clear from obstructions ?
    Got any specifications for the Marlin crawl box we can have a peek at ? I am interested in the end play adjustments and how the end play is adjusted as well as checked ?
  7. Nov 24, 2019 at 5:22 PM
    #107
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    There isn’t any vent on the crawl box. Atleast my doesn’t have one.
    gearcruncher[QUOTED] likes this.
  8. Nov 24, 2019 at 6:10 PM
    #108
    gearcruncher
    There should be a vent to atmosphere .
    If for some reason the crawl box didnt have a vent , there would be no room for expanision and contraction of fluid during heating cycles unless the crawl box uses the factory transfer case vent as its way to vent ? I highly suggest the OP looks at this !!!!!
    Sorry for the stupid questions , but I am diagnosing this problem from an OEM standpoint .
    Having never used an aftermarket crawlbox from Marlin , I go back to the basics of OEM standards for all vehicles .
    All automatic transmissions , all manual transmissions , all transfer cases and all differentials must have a vent to atmosphere in order to function correctly .
    If you Plug a vent to atmosphere on any of the above , you are asking for serious trouble very quickly . :cool:
  9. Nov 24, 2019 at 6:19 PM
    #109
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Let’s assume there is no vent. How would that cause the issue he’s having?
  10. Nov 24, 2019 at 6:40 PM
    #110
    gearcruncher
    OK , Lets assume there is no vent to atmosphere .
    What happens when the fluid inside the Crawl box gets hot ? In most OEM instances , you blow all your seals but it gets much worse .
    The fluid needs to expand but the fluid cant expand because the fluid cant push the hot air out of the crawl box .
    From this point , everything inside the crawl box gets hotter and hotter , the rotating metal parts inside the crawl box expand with heat . Yes guys , we have ourselves a pressure cooker
    If the internal parts inside the crawl box continue to expand with heat , lubrication ports become blinded off and the end play adjustment in the gear assembly diminishes to a zero set point .
    Not saying this is the OP,s issue , but it is such a common problem on OEM 4x4 trucks that play in the mud , I thought I should bring it up .
    For the 4x4 guys who play in the mud and water and take the time to run your OEM atmospheric vents up to your firewall !!! your doing yourself a big favor
    hoverlover and gotoman1969 like this.
  11. Nov 24, 2019 at 6:59 PM
    #111
    6 gearT444E
    Deep South
    Herculiner Hootus
    mine has one on the shifter base
    gearcruncher likes this.
  12. Nov 24, 2019 at 7:02 PM
    #112
    jowybyo
    Joe
    Baltimore, MD
    I can buy that.
  13. Nov 24, 2019 at 7:06 PM
    #113
    wrmathis
    Bonaire, GA
    parts and stuff
    Mine doesn’t. U also got the super duper short shifter that marlin had for like 10 secs they no longer sale.
    This is my shifter base
    With how much these things leak u really don’t need a vent :rofl:
    Torspd, hoverlover and gearcruncher like this.
  14. Nov 24, 2019 at 7:10 PM
    #114
    gearcruncher
    Lot of members here involved in trying to solve this . Great to see :thumbsup: Could it be something as dumb as a plugged vent ? Only time will tell :fingerscrossed:
  15. Nov 24, 2019 at 7:18 PM
    #115
    gearcruncher
    i suggest drilling and tapping a vent into this critter and it wont leak anymore ! :bananadance:
  16. Nov 24, 2019 at 7:32 PM
    #116
    wrmathis
    Bonaire, GA
    parts and stuff
    I’ve actually solved my leaking problems. Gotta be deliberate as fuck when sealing.
    hoverlover likes this.
  17. Nov 24, 2019 at 7:38 PM
    #117
    gearcruncher
    I wish I had two of these Marlin boxes in front of me . One of them built for an automatic and one that Marlin builds for a manual . Op says the one built for the automatic has constant lube . I would love to compare the differences
  18. Nov 24, 2019 at 7:46 PM
    #118
    wrmathis
    Bonaire, GA
    parts and stuff
    Also just looked at a pick I got. Think the crawl box would vent out the transmission tail housing. There is a vent tube off the tranny and pretty sure the crawl box isn’t “sealed” from the tranny tail housing.
  19. Nov 24, 2019 at 7:48 PM
    #119
    wrmathis
    Bonaire, GA
    parts and stuff
    There is no difference in a manual vs auto crawl box other than the spud adapter that fits over the crawl box input shaft going into the manual tranny
  20. Nov 24, 2019 at 7:52 PM
    #120
    gearcruncher
    You are correct . I went back to the OP,s first set of pictures and I can see a vent to atmosphere in picture . Is it plugged up ?
