creak while braking?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thewarriordinghy, Oct 12, 2014.
  1. Oct 12, 2014 at 5:11 PM
    thewarriordinghy
    thewarriordinghy [OP] General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    Recently when I brake, I get this slight creaking noise and feeling and I feel it under the front end of the truck. Time for new rotors? or maybe something else?
  2. Oct 12, 2014 at 5:14 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    A creak, huh? Never heard of a creak, maybe a squeal? I would recommend cleaning everything up and blowing everything out with compressed air. Then see If there is abnormal wear on the components.
    Do you feel a shudder when braking? Might have to turn the rotors if you feel a shudder.
  3. Oct 12, 2014 at 5:15 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    describe a shudder? it seems like a creak like it wants to go forward more when I stop.
  4. Oct 12, 2014 at 5:19 PM
    User Name01
    Bolbi Stroganovsky
    If it wants to keep going when you stop, you might want to check the wear on the pads. Might be time for new brake pads.
    The "shudder" feels like if you are driving down the road and you tap your breaks on and of...on then off.
    Sometimes, you can feel the shudder in the steering wheel also.
  5. Oct 12, 2014 at 5:21 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    the pads have less than a year on them.... Its been maybe 8 months since I put them on... so what all can it be and how do I tell?
  6. Oct 12, 2014 at 5:23 PM
    User Name01
    Bolbi Stroganovsky
    You would have to get someone to check the rotors. Can't really tell by looking at them, unless there is something majorly wrong with them.
  7. Oct 12, 2014 at 5:24 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    im lookin for a diy.... im too broke for a mechanic
  8. Oct 12, 2014 at 5:25 PM
    User Name01
    Bolbi Stroganovsky
    Hopefully someone else chimes in bud.
  9. Oct 12, 2014 at 5:26 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    I know theres a few mechanics... maybe they'll read it
  10. Oct 12, 2014 at 6:22 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Sounds like it may be axle wrap you're experiencing.
  11. Oct 12, 2014 at 6:27 PM
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    That's what I was thinking and the creak was the rear leaf spring shackles.
    But that's just what mine does on occasion.
  12. Oct 12, 2014 at 6:48 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Check your calipers. Sounds like you might have one of the pistons frozen.
  13. Oct 12, 2014 at 7:34 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    what do I do to check all these? for example, like a checklist to rule things out or determine what it is? and I doubt it would be the leafs, as it only does it on the front end?
  14. Oct 15, 2014 at 8:01 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    BUMP EMERGANCY BUMP. While coasting home it sounded like the wheels were goin to fall of the front. When I break everyone around could hear it creak. It also felt like the back brakes made the whole truck brake. Any advice is appreciated. I am putting it on the jacks as soon as my dad gets here.
  15. Oct 15, 2014 at 8:18 AM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    How many miles on the truck?
    You stated you recently did the front pads, have you ever done the rear shoes? Also how does your parking brake feel?
  16. Oct 15, 2014 at 8:23 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    80,000 miles, the adjusted the rears and ebrake is good. (it works like always?) and I heard a pop in the neighborhood and now there are like these rusted metal spots on my plastidip on the drivers front rim.
  17. Oct 15, 2014 at 8:23 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    I drive 500 miles a week and its my DD.....
  18. Oct 15, 2014 at 8:25 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    After the Pop how did the brakes feel? I would definitely get the wheels off the front and do a thorough inspection of the front calipers.
  19. Oct 15, 2014 at 8:27 AM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    like the rear did the work
  20. Oct 15, 2014 at 8:28 AM
    03is300ztk
    Zach
    07 Tacoma 4X4
    sounds like a caliper may have lost a piston.
