Creaking clutch pedal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by toyoder1101, Dec 16, 2019.
  1. Dec 16, 2019 at 7:29 AM
    toyoder1101
    toyoder1101 [OP] New Member
    Steven
    2014 toyota tacoma trd sport double cab
    My 2019 Toyota Tacoma TRD sport double cab four-wheel drive 6-speed manual transmission. the clutch started creaking about 7,000 miles on my brand new truck. I took it to a Toyota dealership close to my house and they said that was the normal why wasn't settling for that so I took it to another dealership close to my house and they told me also it was normal I said what there needs to be a fixed someone needs to check it and they did and they came back with the answer that it fell under Toyota service bulletin T-SB-0122-19. They are replacing the whole clutch pedal assembly. Thank God. The creaking was driving me nuts.
  2. Dec 16, 2019 at 7:32 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Yes a well documented issue had mine done at 22k. The ironic part is I think they are replacing it with the exact same parts so its not an if, but when it happens again.
  3. Dec 16, 2019 at 7:37 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    "Normal" :rofl:
    I didn't know ghetto was normal.
    If I remember correctly guys, there is a post floating somewhere on here which involves regularly greasing the pedal assembly because it dries up. It's not okay and it's not fair but these are the fallacies of the MT Tacomas you guys will have to live with.
  4. Dec 16, 2019 at 7:43 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The problem is regular greases melt off in high temperatures and the old barn door sound returns, getting all the pivot points with High Temperature Disc Brake Grease will take care of it as it won't melt.
    su.b.rat and 12TRDTacoma[QUOTED] like this.
  5. Dec 16, 2019 at 7:46 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yep. High temp grease is the cure for most of these noise issues for sure.
    shakerhood[QUOTED] likes this.
  6. Dec 16, 2019 at 7:51 AM
    Myles G
    Myles G Well-Known Member
    Myles
    You can use brake grease to stop it, but I love the creak. Just toyota things.
  7. Dec 16, 2019 at 8:06 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    shakerhood likes this.
  8. Dec 16, 2019 at 8:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Speedfreak likes this.
  9. Dec 16, 2019 at 9:00 AM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
  10. Dec 16, 2019 at 9:03 AM
    jersey jim
    Jim
    shakerhood and tonered like this.
  11. Dec 16, 2019 at 10:02 AM
    Grossomotto
    2017 4WDV6LB6MT
    tonered[QUOTED] likes this.
  12. Dec 16, 2019 at 10:19 AM
    6MTPro
    HI -> CA
    Were the parts update though or just the new TSB covered more recent years?
  13. Dec 16, 2019 at 10:46 AM
    jersey jim
    Jim
    I believe that there is a sort of bushing where the spring contacts the clutch arm now, I think there's a picture in that thread link. Or maybe I saw it in another thread.
  14. Dec 16, 2019 at 10:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  15. Dec 16, 2019 at 12:51 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    You need to make sure you lube the pivot point of the slave cylinder actuator. It hides in a small bucket that you need to get up into with a spray extender. Look closely and you will see what I am referring to.
  16. Dec 16, 2019 at 12:56 PM
    su.b.rat
    su.b.rat broken truck
    this, and additionally the inside of the coil of the return spring. a good way to apply disk brake grease is to use a couple finger dab with a nitrile glove on and work it into the coil.'s inside helps with the stubborn groaning.
    shakerhood, CdnSldr and tonered like this.
  17. Dec 16, 2019 at 1:37 PM
    CdnSldr
    CdnSldr ______________
    Canada Eh!
    @St.Germain How’s your LC clutch pedal/ linkage conversion coming? My 2020 Pro 6MT should be delivered around end of Feb and I’m already planning the ‘necessary’ mods. Seems like we have a similar mod style, so I’ve appreciated your posts. Cheers
  18. Dec 16, 2019 at 2:08 PM
    1taco2motos
    1taco2motos Well-Known Member
    Colorado
    19 DCSB mgm TRD OR 6MT
    My clutch pedal creaks but I'm not going to subject the truck to dealership mechanics for replacement. If it were some kind of mechanical failure sure but for a creaking clutch, c'mon? I suppose I first heard the creak sometime after 5k miles were clocked on the odometer; precisely when I thought, "how friggin cheap." But hey, for roughly $36k we get a bit of nostalgia included. The creaking sound actually reminds me of early 1900's technology. Guess I'll pick up some high temp grease next time I pass the store.
  19. Dec 16, 2019 at 2:11 PM
    2017 Oregon Tacoma
    2017 Oregon Tacoma Well-Known Member
    Michael
    Oregon
    2021 Tacoma Off-Road
    Just had mine replaced at 40,000 miles. under warranty
  20. Dec 16, 2019 at 2:37 PM
    bigoldbeef
    bigoldbeef Well-Known Member
    18 DCSB OR MT, 22 DCSB OR AUTO
    Mines never done it in 102k, or maybe my radio is always too loud to hear
