Cross Wind front window noise TSB Update.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tow-coma, Jan 25, 2018.
  1. Mar 31, 2022 at 5:59 PM
    #161
    Dan2731
    Dan2731 Well-Known Member
    Dan
    2022 Army Green DCLB Sport
    My 2022 DCLB has a whistle that sounds like its coming from the driver mirror from 30+ with crosswind. Ive driven with the mirror folded in and sound persists. Guess it would have to be the weather stripping then? Only has 1k miles so guess i have to deal for a while or track it down lol.
  2. Sep 23, 2022 at 1:37 PM
    #162
    LifeAngler
    LifeAngler Well-Known Member
    Shane
    2022 Tacoma SR double cab 4x4
    Did you ever find a fix for this? I have added some vent visors (which may have helped a bit) and ordered some weatherstripping today to add around the door. Mine is a 2022SR. Hoping the added weatherstripping minimizes some of the wind noise that I’m hearing. From what I can tell a lot of the wind noise comes around the drivers side mirror. Just today I folded the mirror in and no change in noise. Mine get really bad around 70 plus. From what I gathered it seems to be “normal” for these trucks but when I’m paying premium rates for a truck I’d at least expect it to be as quiet as my 2000 Chevy.
  3. Sep 23, 2022 at 4:43 PM
    #163
    Dan2731
    Dan
    Haven’t looked into it much or tried anything but came across this. I’m kind of used to it at this point but maybe someday soon i’ll give it a try. https://www.tacomaworld.com/threads/solved-howling-noise-between-35-45.410480/
  4. Sep 23, 2022 at 5:06 PM
    #164
    Eaj71
    Eaj71 Well-Known Member
    Eric
    2014 DCOR
    That is a great fix
    this crosswind thing bugged me
  5. Sep 23, 2022 at 5:19 PM
    #165
    LifeAngler
    Shane
    I believe that may be why some newer trucks come with an air dam on the front. I haven’t checked yet but I believe this has been fixed on the newer truck after the year the tsb took place. Installing the vent visor definitely changed the acoustics of the sound and now instead of hearing it at 60 mph I hear it at around 70. That’s when it gets noticeable. I’ve gotten more used to it but every once and a while it’s loud enough to really be annoying.
  6. Sep 23, 2022 at 6:03 PM
    #166
    Dan2731
    Dan
    Yea i never really looked into it, i took my air dam off once i got it. Another guy i talked to said it’s the piece where the mirror bolts to the body but i haven’t looked into it. I also have a whistle at higher speeds 70-80+ that sounds like it’s from the rear weatherstripping but again i haven’t looked into it much
  7. Aug 8, 2023 at 3:59 PM
    #167
    Dennday67
    Dennday67 Well-Known Member
    Nathan
    Otwell, IN
    2020 Tacoma SR5 4x4 DCLB
    None
    I thought it was caused by the seat belts.
  8. Aug 26, 2023 at 9:17 PM
    #168
    habaneroTrd
    habaneroTrd Well-Known Member
    2018 Tacoma Trd OR DCSB
    ive noticed this noise recently coming from my passenger side, windshield/pass side mirror area. usualy at highway speeds around 75-80 mph. Have not really had the time to troubleshoot the issue, but I want to say ive noticed it more since I have installed a new front bumper and had to trim the fenders and fender flares as well as the splash guards in the wheel well. wondering if its just forced air through, but it really does seem to come from the pass. side mirror area in that corner by the tweeter.
  9. Sep 6, 2023 at 8:54 AM
    #169
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    This may help but what I have always done to my vehicles is put die-electric grease on my door seals once a year. I have no wind noise on my 2022 Limited. By the way the manual says to use die-electric grease on the door seals. It keeps them soft and seems to seal well. Have always done it to my 2002 Yukon and it’s still quiet as a 747.
    Rabby likes this.
  10. Nov 2, 2023 at 9:18 AM
    #170
    Rabby
    Rabby Well-Known Member
    2010 Tacoma 4x4
    OME Hvy Kit, ARB Bumper
    I've read about the TSB before I bought my 2023 TRD 4DR and that was the first thing I checked for. at 7 miles off the showroom floor I could hear it.
    I have recently added an ARB Summit bumper, did the cutting and what not. It is defiantly not the bumper in my case. But my MPG has left the building
  11. Dec 22, 2024 at 1:59 AM
    #171
    Anomalous-Being
    Anomalous-Being Member
    Rough County CAI, Bull-Bar, Side-Steps, Vent Visors, Bug Deflector, Upgraded sound system.
    I might know exactly what is causing the issue, which might sound a little weird but it's 100% accurate!~
    When I got my 21 TRD Sport Taco 4x4 in April this yr 2024, the drivers side mirror did not have the little airflow thing underneath the side mirror thus showing the wires, and the sound was never present.
    Got the side mirror replaced with one that had the little ripples underneath the side mirror, and all of a sudden this noise started, it is being caused by the airflow things underneath the side mirror some how.
