Crossover Mounting Location
Discussion in 'Mr Marv' started by RAMZAK, Oct 25, 2009.
  1. Oct 25, 2009 at 11:52 PM
    RAMZAK
    RAMZAK [OP] Well-Known Member
    Mark
    Houston
    2008 Tacoma TRD 4-DR PreRunner
    Marv,
    I see you mounted the crossovers for the Front speakers close to the amps on the amp rack/sub box.
    Is this the best location for them? If so why?
    I have seen them mounted within the doors many times. This also alows for using about half as much speaker wire ($$$) because you only have to run 1 wire from the amp to the doors?
  2. Oct 26, 2009 at 9:51 AM
    Mr Marv
    Mr Marv 1-831-383-0308 7am-10pm pst Vendor
    Marv
    Monterey Bay California
    Custom Built Enclosures/speaker adapters etc
    I prefer not to mount them in the doors due to possible issues created by moisture/constant shock from door closing (I've replaced many with loose components on the boards as well as corrosion) etc and although it might cost you 4-5 bucks extra in speaker wire that's a lot less than the cost of a new crossover!
  3. Oct 26, 2009 at 11:02 AM
    RAMZAK
    Mark
    Houston
    Good Call!
