Cruise Control doesnt work
Discussion in 'Technical Chat' started by s2kvtak, Jan 4, 2010.
  1. Jan 4, 2010 at 3:49 PM
    s2kvtak
    s2kvtak [OP] Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    well suddenly the cruise control on my truck just stopped working. i can turn it on and the dash light comes on, but it wont "set". i have a haynes manual and have tried to research online but cant seem to come up with any answers. the manual says that there is a motor and a cable attaching to the trottle body. at the front of the throttle body is the throttle cable but nothin else. any and all help is appreciated!!!
  2. Jan 4, 2010 at 3:53 PM
    Brunes
    Brunes abides.
    Rotorhead
    A little more info about your truck would be cool- Like year and mileage.
  3. Jan 4, 2010 at 3:55 PM
    toyotadude5
    toyotadude5 Breazeale- Pronounced Brazil
    chris
    Flagstaff, az
    2006 Subaru wrx sti (white)
    subscribed. my dad has an 01 taco and he said his cruise light comes on but does not work, Id like to see if anyone has a fix
  4. Jan 4, 2010 at 4:32 PM
    ccs368
    ccs368 Well-Known Member
    MA
    05 Access Cab SR5 4x4
    In my experience, there's a switch almost like a theaded plunger that can be adjusted in and out to make full contact with the actual clutch pedal. I'm assuming you have a manual transmission too. If it's just out of contact where upon full clutch pedal return and the switch is not engaged, you will not be able to "set". Check it out underneath.
    Nbrannon92 and wilcam47 like this.
  5. Jan 4, 2010 at 7:12 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    damn....im sorry guys i was on my way out the door when i wrote this earlier. its an 04 xtra cab V6 auto SR5 4X4
  6. Jan 5, 2010 at 2:11 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    bump for some help
  7. Jan 5, 2010 at 2:14 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    check the brake light switch and its adjustment first
    wilcam47 likes this.
  8. Jan 5, 2010 at 2:24 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    would this be inside the cab? little descriptions are nice
  9. Jan 5, 2010 at 2:26 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    also how does it adjust?
  10. Jan 5, 2010 at 4:36 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    The brake light switch is under the dash, on the brake pedal. It's a threaded adjuster. 99% of the time, the little rubber stopper is worn out, on the brake pedal itself.
    I'm assuming you checked fuses, haven't recently had the intake off, and made sure everything is plugged in, right? It's probably something simple, as Toyota cruise systems rarely, if ever fail.
  11. Jan 6, 2010 at 2:48 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    well i got under there and saw the treaded adjuster and it has a little plastic button coming off of the end that when the brake pedal was at "rest" the button was depressed and with the pedal pushed it was out. is this the correct adjuster or is there one im missing. it was kinda dark when i looked.
    i havent had the intake off but i did just recently clean my k&n filter. im not sure how this would have anything to do with the CC but i have done it.
    as far as fuses go i couldnt find one the was labeled cruise, but im assuming the fuse is fine since i get the dash light to come on. it just wont set at a speed.
    one thing i though of last night was the speed sensor. anyone know where that is? i did go play in the snow we got so maybe it could have come unplugged or something?? just an idea
  12. Jan 6, 2010 at 4:21 PM
    kevhogaz
    SR5 PreRunner
    Here's what I found, on the basic operation of the CC system. It's extremely hard to diagnose the problem, over the internet. Check all these systems/operations first.
    AUTO CANCEL OPERATION
    If any of the following conditions are detected, the set speed is erased and the control is canceled.
    1. Disconnection and/or short in the stop light SW
    2. Malfunction in the vehicle speed signal
    3. Malfunction in the electronic throttle parts
    4. Malfunction in the stop light SW input circuit
    5. Malfunction in the cancel circuit
    6. The actual vehicle speed becomes slower than the minimum speed limit
    7. The actual vehicle speed becomes -16 km/h (10 mph) slower than the set speed
  13. Jan 7, 2010 at 3:52 PM
    s2kvtak
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    okay well the latest update is that i found that the cruise control system will work properly if the headlights are off. it sets and maintains speed and as soon as i flip them on, even the parking lights, it cancels. im lost...i know its probably a short, but how and where
  14. Jan 7, 2010 at 4:16 PM
    kevhogaz
    SR5 PreRunner
    Holy moly, man, you got yourself in to a jam now!
    I'd look at the cruise switch, itself. The one in the steering wheel. I'd test it, and go from there. Unless you pinched a wire at some time, I'd start with the easy stuff, start.
  15. Jan 10, 2010 at 6:39 AM
    Twisted99
    Twisted99 Active Member
    San Tan Valley, AZ
    I also have this problem. 01 Double cab 4x4 auto.
  16. Jan 19, 2016 at 7:39 AM
    neatoneto
    neatoneto Well-Known Member
    Neto
    04 Tacoma 4x4 Ext. Cab
    Same boat with an 04 extra cab manual 4x4
  17. Feb 8, 2016 at 12:04 PM
    wilcam47
    wilcam47 Well-Known Member
    North Idaho
    2000 Toyota Tacoma
    4 inch lift
    This is what was initially wrong with mine and later it turned out to be the cable that engages the CC came off the bracket. I repositioned the cable to the right spot and tightened it up CC works on mine now.
  18. Feb 8, 2016 at 12:09 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    Clock spring
  19. May 26, 2017 at 4:14 PM
    Nbrannon92
    Nbrannon92 Well-Known Member
    Nick
    Houston, TX
    97 Tacoma 4x4
    When mine went out, I also noticed that my clutch got a little "floppy" around the time my cruise went out. Is this switch located in the cabin near the actual clutch pedal?
  20. May 26, 2017 at 4:18 PM
    Nbrannon92
    Nick
    Houston, TX
    97 Tacoma 4x4
    This happened to mine a while ago. Nice easy fix. My cruise stopped working in the middle of a long drive recently, and now I've got no idea what's wrong with it.
