Cruise Control Fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BakoTruck, Nov 26, 2018.
  1. Nov 26, 2018 at 12:52 PM
    BakoTruck
    BakoTruck [OP] Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Hello, could anyone tell me which is the Cruise Control fuse or fuses? I've tried looking in the owners manual on pages 386-387 in the fuse section, could not find. My CC works half the time, and goes out. I would like to replace the fuse before I spend the time replacing the CC assembly. Thanks guys.
    2005 Toyota Tacoma PreRunner V6, Auto.
    wilcam47 likes this.
  2. Nov 26, 2018 at 12:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    A bad fuse won't work 'sometimes'. It's either working or not.
    Spiral cable under the steering wheel (literally) is a much more likely suspect. Especially if the horn is intermittent as well as the CC.
  3. Nov 26, 2018 at 1:09 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah, I have thought of that. The horn seems to work just fine and I had the spiral cable replaced under recall back in 2013.
  4. Nov 26, 2018 at 2:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Even still... It is the most likely culprit. Spiral Cable.
    balljoint likes this.
  5. Nov 26, 2018 at 9:36 PM
    Zuba987
    Zuba987 Well-Known Member
    Enola PA
    2006 ACLB V6 auto 4x4
    Fully armored, STT Pros and Methods.
    Yes, my truck had this issue and I replaced the spiral cable (clock spring) and it fixed the problem. Just beware a good oem one is pricy. $300ish or so. If you had the recal done back in 2013 see if there is any extended warranty and if they can fix it for you. If not your out of luck. My horn worked fine but my cc would only turn on intermittently.
  6. Nov 26, 2018 at 9:37 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    is it standard or auto?
  7. Nov 27, 2018 at 2:15 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Good point.
    OP if it is a manual transmission there is a switch on the clutch that will kick off the CC. And for either the brake switch will do the same.
  8. Nov 27, 2018 at 2:39 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    ...or a bad ground somewhere.
  9. Nov 27, 2018 at 11:02 AM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    It's an auto.
    Well crap, yeah I hooked up a cheapo scan tool and it showed nothing. Do you guys think it could be the Cruise Control Switch Assembly? https://www.amazon.com/dp/B00IEJFJQ4/ref=nav_timeline_asin?_encoding=UTF8&psc=1
  10. Nov 27, 2018 at 12:41 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    My cruise control did that for awhile before stopping working completely.
    While idling turn your wheel all the way to the left and try cruise control, then all the way to the right and try again. Bet it works better in one or both of those conditions because the spiral cable is failing.
    Marc70 likes this.
  11. Nov 27, 2018 at 12:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is going to sound out there, and even now it is out there to me, but definitely on one of my "top 10 strangest things I've seen in automotive." Fuses do sometimes not work, but are whole, and a simple matter of pulling it then reinstalling it restores functionality to the circuit again barring that the fuse is physically not blown. I have noticed it to be something that affects micro fuse equipped fuse boxes like the ones we have. It has definitely happened on my own truck before.
    So to say they won't work sometimes and that it either works or not is simply not true. At least not true in all the years of my experience.
  12. Nov 28, 2018 at 8:42 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    I think you are mistaken either a fuse is blown or it is not blown. If it is, blown it will not conduct current. If it is NOT blown, it will conduct current . This is not a sometimes thing.
    That being said if it is not blown and not plugged in correctly then that could explain why you thought what you did. And when you unplugged it and re-plugged it back correctly it fixed the problem of not being plugged in all the way.
    Reinhardtius likes this.
  13. Nov 28, 2018 at 8:45 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  14. Nov 28, 2018 at 8:48 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    Devil's advocate here,
    **what if** there is some corrosion or oxidation on the leads, and by pulling and re-installing you are making a new contact.
    Food for thought.
    12TRDTacoma likes this.
  15. Nov 28, 2018 at 8:50 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Another possibilty...
  16. Nov 28, 2018 at 9:00 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Awe common, show some imagination. While a fuse is either blown or not, mechanical contact failure is not unknown so why not at least check all the inexpensive possiblities before forking over a roll. I'm not saying how likely it is but it hurts nothing to see. Also, I read in another post how improperly plugging in the spiral cable resulted in a bent pin and malfunctioning CC so try an RI of the cable checking the connector for obvious problems, could be a bad crimp on one of the wires or the tech just didn't push the connector all the way in. CC isnt a critical system so you have the time to get forensic. In the mean time start saving up for the more likely eventuality.
    Marc70 and 12TRDTacoma like this.
  17. Nov 28, 2018 at 9:14 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    A lot of possibilities here really. Sometimes things aren't so cut and dry.
  18. Nov 28, 2018 at 1:29 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Possible bad brake light switch as well
  19. Nov 28, 2018 at 4:57 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Alright, so I agree with all above conversations. If I knew where that fuse was for the CC, I would replace with a new one. Can anyone tell me where it's at? Bad Brake Light switch? I don't know what that is, my brake lights seem to be working fine to me. Anyone want to tell me what to check for this?
  20. Nov 28, 2018 at 5:00 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    As mentioned above it has been going in and out, I was able to use it on the highway after 30-40 mins of driving. Damn thing wouldn't turn off, had to slam on the brakes. Kinda makes me think it's the CC switch assembly that's messed up.
