Cruise Control Fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BakoTruck, Nov 26, 2018.
  1. Nov 28, 2018 at 6:09 PM
    Muddinfun
    Muddinfun Well-Known Member
    There is no dedicated fuse for the cruise control. The cruise control switches all send a different resistance to ground through 1 wire, through the clock spring. If the cruise wouldn't shut off from the stalk, that sounds like the clock spring to me, but that's strictly an opinion. IMG_1727.jpg
    Jimmyh likes this.
  2. Nov 28, 2018 at 7:59 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The brake switch is down on the brake pedal assembly under the dash. If your brake lights are not getting stuck on then that isn't the issue.
    As stated earlier the Cruise Control is a function of the Engine Control Module ( ECU ) and has no dedicated fuse. If one of the fuses for the ECU were defective you would be having many other issues.
    Muddinfun likes this.
  3. Dec 3, 2018 at 1:22 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    My 06 has similar issues. I confess I don't know what a "clock spring" is in this context - or if the spiral cable IS somehow the clock spring or just related to it. I'm going to continue searching, but if anyone knows a thread that spells this out - do tell.
    Thanks
    TL
  4. Dec 3, 2018 at 3:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Clock Spring = Spiral Cable.
    It is the same device.
    Clock spring is misleading as it is not a spring at all.
    It is a ribbon cable ( or two depending on the radio controls or not ) wound up in a spiral format inside of a case. That is what allows you to turn the steering wheel and maintain the circuit connection between the Horn, Airbag, Radio Controls and factory Cruise Control.
    Marc70 likes this.
  5. Dec 5, 2018 at 1:34 PM
    BakoTruck
    BakoTruck [OP] Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Thanks everyone.
    Muddinfun[QUOTED] likes this.
  6. Dec 5, 2018 at 7:36 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you get it fixed?
  7. Feb 9, 2019 at 5:57 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yeah! Finally got around to replacing the Spiral Cable, used a company from RockAuto.com. Speed Control came right back on during test drive, seems to work fine! Thanks everyone! Oh, and FYI for anyone thinking of replacing the (Spiral Cable/Clock Spring) on their own, it's a fairly easy task, don't be afraid. Just make sure to watch all the different Youtube videos, make sure you have all the tools on hand before you start, and make sure to disconnect the battery for at least 30 mins before you begin work. Have a good one.
    I like this Video: https://www.youtube.com/watch?v=VblczY9PzMc&t=313s
    Marc70 likes this.
  8. Feb 10, 2019 at 6:37 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  9. Oct 4, 2019 at 10:59 PM
    yosemitemtb
    yosemitemtb Member
    Central California
    2022 TRD Offroad. 2002 WRX wagon. 2005 Outback XT.
    Tacoma is mostly stock, the WRX isn't.
    Good info about the clock spring. Mine went out before the recall,lighting my airbag warning light, bought a new OEM part and self installed. A couple of years later, I got a refund for the $300 part! Had to write a letter and send a copy of my receipt, had to have the dealer inspect it, and got a check! The real reason I wanted to bump this old thread is to weigh in on the "partially blown fuse" debate. I work lift and vehicle maintenance at a small ski area that had a Trackless brand tractor/snowblower thing that was near the end of it's useful life. Great machine, it moved a lot of snow, but the wiring in it was really bad. Between the amateur wiring and the effects of time and corrosion, it would heat up some of the fusebox terminals so much that the solder inside the ends of the glass fuses would melt. The fuses would look fine and sometimes test fine but eventually fail .
    06Tacooo likes this.
  10. Aug 15, 2020 at 5:26 PM
    BSC_808
    BSC_808 Active Member
    Brennen
    ‘07 Tacoma V6 4x4
    Bilstein leveling kit
    CC won’t work If brake lights are out. I’m having the same problem with an aftermarket CC assembly I installed.
    it only turns on when I turn the wheel left or right (which is useless on the freeway)... so I’m assuming it’s the clock spring. But horn works fine.
    the fuse associated with the CC as well as passenger airbag is the 7.5 amp ECU-2 fuse under the hood. Mine was blown which threw a passenger airbag sensor code.
    if unplug that fuse and plug it back in the CC works for about 2 drives. So I’m in the camp of conductivity causing a fuse to “sometimes” work, although, it is not the fuse itself.
