cruise control
Discussion in '4 Cylinder' started by bill357, Aug 20, 2013.
  1. Aug 20, 2013 at 4:13 PM
    bill357
    bill357 [OP] Member
    2011 4x4 extcab 2.7
    I have a 2011 excab with a 2.7 liter motor and 4 speed transmission.
    when I use the cruise it accelerates wildly at the slightest incline. Is this normal?
  2. Aug 20, 2013 at 4:49 PM
    chunt5
    chunt5 Senior Citizen Member
    chuck
    Cumming, Georgia
    2015 DCSB, Prerunner, SR5, 4.0
    Mine maintains the set speed just fine. It accelerates on inclines but just enough to maintain the set speed.
  3. Aug 21, 2013 at 4:35 AM
    bill357
    bill357 [OP] Member
    2011 4x4 extcab 2.7
    when mine accelerates it climbs to 3000 -5000 rpm.
  4. Aug 21, 2013 at 5:55 AM
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    It will first unlock the torque convertor, then downshift to 3rd if it needs more power to maintain speed up an incline. That causes the RPM's to go up, but the speed should remain fairly constant. That's how mine works anyway.
    I will usually kick off the cruise control when I sense it is about to downshift and let it lose a couple mph rather downshift to help mileage.
  5. Aug 21, 2013 at 9:37 AM
    bill357
    bill357 [OP] Member
    2011 4x4 extcab 2.7
    so the rapid climb in rpm is normal?
  6. Aug 21, 2013 at 9:40 AM
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    Yea that happens to me too. When I climb hills I turn off cruise control.
  7. Aug 21, 2013 at 1:44 PM
    Mr. Pick
    Middle TN
    Yes, it is downshifting from 4th to 3rd.
  8. Aug 22, 2013 at 5:11 AM
    bill357
    bill357 [OP] Member
    2011 4x4 extcab 2.7
    will this harm the engine? It maintains speed just fine but the rpm surge scares ya.
  9. Aug 22, 2013 at 5:44 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    wont hurt, other than gas mileage
  10. Aug 22, 2013 at 9:17 AM
    adriancast
    Adrian
    Ontario, Ca
    same here. That's why I just turn off the cruise control when going up a hill then turn it back on when on top of the hill or back to flat grounds.
  11. Aug 31, 2013 at 1:46 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    '07 base taco. Sold. Now Taco-less
    Factory cruise added, wood storage box in bed, wood center console/armrest, charcoal air filter delete.
    Mine's the same. The issue is that the CC doesn't 'try' hard enough early enough when starting up a hill. Many times the truck can climb in high, but the cruise waits so long while loosing speed that it then has to down shift. Then it over speeds, lets way off the throttle, upshifts and starts all over again with the cycle. I will usually start pressing the accelerator as the hill starts and let up slowly so the speed will stabilize then it's cool and stays in high with the converter locked. If I suspect the hill to be too much for that I'll manually put it in 3 then the converter stays locked and the CC can manage better. The other option I've found is to give a few taps on the accelerate button as it starts up a hill to force it early and once I feel the load, speed, and throttle is stabilized I tap it back down.
    The easy fix is to turn it off as previously stated, but I'm a CC junkie so I learn how to help it work instead so it can proceed with the hill and the rest of the drive. I'd drive by button full time if I could get everyone else on the road to drive a steady damn speed.
  12. Sep 11, 2013 at 1:34 PM
    1goindiesel
    1goindiesel New Member
    Cen TX
    06 base
    My "cruise" is attached to my right hip:D. Love my simple little Taco but Cruise and pause wipers would be great.
  13. Sep 11, 2013 at 1:50 PM
    Winker
    Winker Well-Known Member
    Paul
    Kentucky
    2019 Subaru WRX
    I paid quite a bit extra to have it added in when I bought my little 5 speed base Taco. I had them put it in when I bought it at the dealership because I'm not the best researcher. Definitely look into adding it, if you're smart, you'll spend a lot less money on it than I did.
  14. Sep 11, 2013 at 2:13 PM
    1goindiesel
    Cen TX
    06 base
    You have my attention. Literally, all this little rig needs is cruise and delay wipers. It is perfect for what I use it for. Coming out of two competitors vehicles immediately before it, I have a great appreciation for its basic goodness.
    Pray tell what the dealer charged you...???
  15. Sep 12, 2013 at 5:55 AM
    Winker
    Paul
    Kentucky
    2019 Subaru WRX
    I saw somewhere here some one had put cruise control in their truck for under $200 and that it's fairly simple. I can't remember the exact amount the dealership charged me but it was under $1,000 but over $500.
  16. Sep 12, 2013 at 6:04 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The power of the I4 is frightening for sure. :eek:
  17. Sep 12, 2013 at 6:12 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    My 6 cyl. is fine but a Camery I had would come close to matting it climbing hills when it got to speed it leveled out never went more then a couple MPH over the set but it was hell bent to climb the hills maybe being a 4 they put more throttle to it. Both were stick shift.
  18. Sep 12, 2013 at 7:02 AM
    camojared
    camojared Well-Known Member
    Jared
    SE Ohio
    07 4x4 SR5 2.7L 5spd
    I have the 2.7 spd manual and I didnt know it could accelerate on an incline ;)... But to answer your question I dont have that problem but mines a manual.
  19. Sep 12, 2013 at 3:05 PM
    DonziGT230
    DonziGT230 Gearhead
    Oscar
    Hacienda Hts, Ca.
    Cruise is easy to add and probably just over $100 if you shop online. I bought the stuff from the dealer at about $130 (not including the new cover) because I was in a hurry. You need the switch, a wire, two screws, and a new plastic cover for the right side of the steering wheel with a hole in it for the switch. First--Take the two side covers off. They were hard to figure out at first, this'll help. The covers are kinda D shaped and where you wanna pop it is right in the center of the flat part which is toward the rear of the truck. Use a thin tipped screwdriver and push it in the center of the flat portion of the cover and pry off, the cover will now pull out and off. Once you see the little locking tab you'll get why you start there. Do the one on the right first so you can practice on the one you're tossing out. There's a torx T30 under each of those covers, remove them and that lets the horn pad/airbag unit pull right off. Remove the existing wire that's in there and replace it with the new one. Install the switch with the two screws you bought (phillips head I think) and plug in the wire. Reinstall the horn pad and side covers. Turn the key on and press the cruise power button and you should see the green light on the dash light up.
    I didn't get the new cover and just plan to drill mine, but since I can't see it from the driver's seat I always forget, I'll go scope it out now that it's on my mind. I think I spent all of 5 minutes working on it, but I'm a seasoned mechanic. I'd guess 10-15 minutes for an average weekend wrencher and maybe 20 for a total novice. Beats the heck out of $500+ to have a dealer do it!!
