Cs144 Alternator Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinmtb, Nov 29, 2020.
  1. Nov 29, 2020 at 8:03 PM
    austinmtb
    austinmtb [OP] Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    I'm thinking about doing the CS144 alternator upgrade soon.
    First of all to those of you that are running the cs144, are you happy with it?
    Also, does anyone know if this alternator will fit with total chaos coil bucket gussets? My factory alternator already doesn't leave a whole lot of room between it and the gusset.
  2. Nov 29, 2020 at 9:46 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I love mine. Great upgrade. As far as fitting, don't know. I can post a pic of mine tomorrow.
    austinmtb[OP] likes this.
  3. Nov 30, 2020 at 5:41 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    This is the Cadillac Seville alternator, yes?
  4. Nov 30, 2020 at 6:35 PM
    austinmtb
    Austin
    Southern Oregon
    I'm not sure what vehicles it came in, I just know it as the cs144 alternator.
  5. Nov 30, 2020 at 10:51 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I had to buy the correct pulley separate on ebay. You'll need the type on the right.20180419_201514.jpg 20180415_214758.jpg 20180418_233039.jpg
    Arctic Taco likes this.
  6. Nov 30, 2020 at 10:52 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Also needed a longer belt to give oil cooler lines more room. The power steering belt is the correct length.
  7. Dec 1, 2020 at 8:35 PM
    austinmtb
    Austin
    Southern Oregon
  8. Dec 1, 2020 at 8:56 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    gm made multiple pulleys for different combos. If you look at the pic of my belt and pulley you'll see why it has to be the 6 groove pulley. 4 groove wont work.
  9. Dec 1, 2020 at 8:59 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  10. Dec 1, 2020 at 9:01 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  11. Dec 2, 2020 at 8:52 AM
    austinmtb
    Austin
    Southern Oregon
    Oh I see, it rides on the outer portion of the pulley so the 4 groove wouldn't put the belt in line with the other pulleys. Thanks for pointing that out.
    otis24 and mechanicjon[QUOTED] like this.
  12. Dec 2, 2020 at 11:51 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Only thing I would do different from below would be leave the oil cooler coolant hose alone and use the longer PS belt.
    https://www.tacomaworld.com/threads/upgraded-alternator-3-4.362979/page-3#post-20158250
    My spacer is a fair bit wider than the 1/4" most folks use.
    The bushing below needs to be flush to the rear surface of the front mount ear (to start).
    It ends up protruding out the front a bit (yellow arrow).
    Prototype BINFORD BUSHING PUSHER kept in the glove box. The OE alt will fit in an excab pass side cubby.
    Only shot I have showing clearance.
  13. Dec 2, 2020 at 1:09 PM
    austinmtb
    Austin
    Southern Oregon
    Thanks!
    Can you explain why it is that the oil cooler line sometimes needs to be modified?
    I don't think I'll have belt issues because I'm supercharged and have the dynamic tensioner. In other words, I have a ton of belt adjustability.
  14. Dec 2, 2020 at 1:11 PM
    austinmtb
    Austin
    Southern Oregon
    Can someone link a cs144 they bought that worked without needing to swap out the pulley? I'd like to just buy the right one and not have to figure out if mine has the correct pulley or not.
  15. Dec 2, 2020 at 1:35 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I was just about to ask about this alternator and supercharger with the dynamic tensioner.
    I was thinking the same...I don't think it would need a new belt.
  16. Dec 2, 2020 at 2:16 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    The larger over all diameter gets real close to the hose.
    I used the same one @mechanicjon used, Delco #335-1048 and the pulley it came with. This was on my 99 and two 98's. He/you have 04's. I am not at all convinced that the mount brackets (Toyota) are the same for all years.
    The thing is, the factory alt is "located" by the rear ear of the bracket and the Delco wants to be up against the front. Sooooo as far as Toyota is concerned the machining of the rear ear is critical and the front only needs to be far enough forward to allow the alt to fit in between. There may be a fairly large range in the spec when they machine the front and it may vary. This is pure speculation. Also note my spacer is around 3/8" while most folks use an off the shelf 1/4". It was machined wide enough to provide a snug fit.
    This alt is used in many GM applications. If searching a junk yard or a parts house (without a Delco pt# reference) "1996 Buick Roadmaster V8" can be used as an application.
    I can't help with the blower vs belt fit. I would however give some thought to the fact that with the blower, the belt has less of a "wrap" on the alt pulley. Under a full amp load the potential for belt slippage would increase. A while back a fellow (with blower) mentioned having slippage issues but he was using some super high output alt.
    @mechanicjon has a blower/04 and seems happy so he might chime back in.
  17. Dec 3, 2020 at 7:27 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    No problems with belt slip running the bigger alt and the blower.
  18. Dec 3, 2020 at 9:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I am using a reman'd cs144 from Advance Auto. Their part # is: 8112-5A
    https://shop.advanceautoparts.com/p...factured-8112-5a/5210879-P?searchTerm=8112-5a
    It is a very tight fit with the TC tower gussets, but does fit and no issues. Also running the pulley that it came with using a power steering drive belt.
  19. Dec 3, 2020 at 10:11 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    DAMN! @Dirty Pool That baby is like new clean under that hood....
  20. Dec 4, 2020 at 9:57 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Here's how I came up with using the thicker pulley.
    Arctic Taco and austinmtb[OP] like this.
