Cs144 Alternator Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinmtb, Nov 29, 2020.
  1. Dec 4, 2020 at 10:00 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Same belt for supercharger
    otis24[QUOTED] likes this.
  2. Dec 5, 2020 at 4:18 PM
    austinmtb
    austinmtb [OP] Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    Digiratus[QUOTED] likes this.
  3. Dec 7, 2020 at 11:18 AM
    austinmtb
    Austin
    Southern Oregon
    I got the alternator and harness adapter ordered so I should be able to get this project going sometime next week.
    What did you guys do for a fuse? I believe the factory one in the fuse block is capable of handling 80 amps so that will of course not work.
  4. Dec 7, 2020 at 11:24 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I am running a 150 amp circuit breaker in line between the alt and the battery.
    austinmtb[QUOTED][OP] likes this.
  5. Dec 7, 2020 at 3:06 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    That and 3 washers. Been running almost 3 years, 0 issues... except that one time I shorted my multimeter probes on the back of it. Didn't change the fuse, and it's never blown.....then again I also ran 1/0 gauge audio wire in parallel the original wire to it and didn't fuse/breaker it
  6. Dec 14, 2020 at 10:41 AM
    austinmtb
    Austin
    Southern Oregon
    Thanks for all the info guys. The install went smoothly and the alternator is working great.
  7. May 11, 2021 at 2:38 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    What did you use for a spacer?
  8. May 11, 2021 at 5:07 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Other than size and it being a little noisier than the stock one, my CS144 has been working great for a few years now.
    Dan8906 likes this.
  9. May 11, 2021 at 5:37 PM
    det107
    det107 Well-Known Member
    I used a thick aluminum washer instead of 3 or 4 washers, still in place-
    Dan8906[QUOTED] likes this.
  10. May 11, 2021 at 11:12 PM
    austinmtb
    Austin
    Southern Oregon
    I machined a spacer on a lathe.
  11. May 12, 2021 at 5:13 AM
    Dan8906
    Daniel
    Concord, California
    Wanna make another one ?! :D
  12. May 12, 2021 at 8:21 AM
    austinmtb
    Austin
    Southern Oregon
    From what I understand, the gap between the alternator and mounting bracket can vary quite a bit. I could make another off of my measurements but there would be no guarantees it would fit right. Although, if you measured your gap with a micrometer I could make one for you.
    Dirty Pool and Dan8906[QUOTED] like this.
  13. Apr 23, 2022 at 12:23 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Can anyone explain why some wired a CS144 with just a simple jumper harness and through the fuse box and others wired directly to the battery with a fuse?
    And why people are running the sensor cable to the spot on the alternator that is directly wired to the battery?
  14. Apr 23, 2022 at 7:30 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    It's just a simple GM to Toyota harness adapter.
    Some people may just want to wire it themselves without using the (easier) adapter.
  15. May 1, 2022 at 3:31 PM
    #35
    Shortman5
    Supercharged TRD
    So nobody has really mentioned much about running this through the stock wiring. I can’t seem to find a fuse that will go into the stock spot that higher amps.
    I’m just so confused.
    I guess this is what so confusing to me. @Blackdawg bypassed the fuse box all together and is running a breaker.
    And I also found a thread where OP had issues running it this way (sense wire to pole / pole to battery)
    The alternator shop in town said it does not matter how you hook it up. 1 wire vs 3 wire it’s the same because it’s internally regulated.
    Then I see a article from Painless that says it’s not the same and 3 wire is better.
  16. May 1, 2022 at 3:32 PM
    #36
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    That's cheatin'.
  17. May 1, 2022 at 4:14 PM
    #37
    Digiratus
    Roaming the PNW
    The RedHead
    I don't think it matters. Mine is copied from Monte's setup. Been running that way for a long, long time without problems.
  18. May 1, 2022 at 7:18 PM
    #38
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Sounds like I may have had a one-off issue with wiring directly between alternator and battery
    I did a big 3 with 1/0 (likely overkill) at the same time I was setting up for a dual battery setup and bypassed the factory fuse box and ended up overcharging an Odyssey pc1200.
    I went out to show a coworker my “handiwork” and noticed the battery was hot and swelling, really scary, luckily had a second battery waiting to be part of the dual battery setup.
    I’d run the CS-144 with stock wiring for a couple of years with no issue but kept running down my battery with a fridge every time we’d sit in one place for too long.
    I ended up upgrading the factory wiring with 4 awg from the alternator to the factory fuse box and from the fuse box to the battery, no issues after several years.
  19. May 1, 2022 at 7:49 PM
    #39
    Shortman5
    Supercharged TRD
    And that’s what I really would want to do. Seems like it would be much cleaner and I spent way too much time trying to find a place for that $40 breaker and still haven’t found a suitable place that won’t trigger my ADD.
    But what I don’t understand is the fusing for a 140 alt with a 120 stock fuse. Unless I’m missing something most people are running it like that?
    From what I’ve seen those fuses are a missive PITA to change out and since I don’t fully understand 12v systems I think it’s best to go with the breaker or maybe a high amp, in line blade fuse in the end
  20. May 1, 2022 at 7:57 PM
    #40
    Digiratus
    Roaming the PNW
    The RedHead
    Remember, the purpose of the fuse/circuit breaker is to protect the wire. Base the size on the gauge and length of the run.
    Laxtoy likes this.
