Cs144 Alternator Questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinmtb, Nov 29, 2020.
  1. May 1, 2022 at 9:10 PM
    #41
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
  2. May 2, 2022 at 10:13 AM
    #42
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    My latest spacer, hair under half an inch. Long story for another day.
  3. May 16, 2022 at 7:23 AM
    #43
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Alright, so I got it all going.
    is anyone watching voltages in cab while driving?
    700 idle rpm (~1600 alternator rpm) voltages are fine
    500 in gear idle (~1200 alternator RPM) voltages drop through the floor. Way worse than stock Denso with an electric fan and AC.
    so I spoke to a expert that says GM specs these things for ~1800-2000 rpm at idle. Said that even 1500rpm is too slow. This correlates the the 80-100 amps people always refer to when talking about cs144s
    I’ve ordered a 2” pulley but at 500rpm in gear rpm it’s still under 1500rpm alternator.
    This all makes sense when you look at charts.
    I guess this isn’t a hugely popular mod but Its just kind strange this hasn’t been mentioned.
    EDIT: I guess it’s also worth mentioning that my pulley on the alternator is at least 2.44” in dia. I believe that’s what I have but I haven’t measured it. I think whatever pulley mechanicjohn is running is even larger than that.
  4. May 16, 2022 at 8:27 AM
    #44
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I watch my voltage. It’s at 14.2ish at idle and 14.7 while driving
  5. May 16, 2022 at 7:44 PM
    #45
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What are you using to measure voltages in cab?
    I have seen differences/discrepancies between measuring devices. Do you have a dual battery setup?
  6. May 16, 2022 at 8:39 PM
    #46
    Shortman5
    Supercharged TRD
    Just a single battery.
    The thing is, the only real reason I did this was because I added an electric fan (just can’t stop fucking with things) and started watching voltages on my UltraGauge. With the Denso I was seeing drops to lower 13s. With the summer heat coming I went ahead and took it to a alternator shop for advise ant they hooked everything up to a portable rig for testing.
    At idle with everything going full tilt I was drawing 85 amps. So I figured I’d burn the little Denso up if I didn’t do anything.
    now my voltages drop like a rock below 700rpm. Like it’s showing 12.7 and below. the Denso did way better even though I was drawing more than its rated for just sitting at idle. When I say drop off like 700rpm it’s 14v and 650rpm it’s 12.7v.
    it’s worth mentioning the denso has a 2.1” pulley and the CS144 has a 2.44” pulley. Ive ordered a pulley to get the RPMs back up. From what I understand it needs to be running near 1800rpm for charging.
    but I am quite confused as to why I seem to have this issue with the same setup other people are running.
    Add to the fact that speaking with some alternator guys they all pretty much said it needs 18000 at the very least to output. This is despite the fact that I can’t seem to find any reputable source that states that as a fact. So yeah, don’t know what to think.
  7. May 17, 2022 at 11:45 AM
    #47
    Dirty Pool
    99 XCAB V6 MT TRD
    @Shortman5
    14.7V at 750RPM, that's cold with fully charged battery less the discharge from one start. Really cold it can hit 15V for a few mins. Trickles down to around 14.2V as battery charge is restored and things warm up. No drop at idle from headlights, fan etc.
    Alternator is a "new" Delco #335-1048, made in Mexico for and sold by Delco. Has 56mm pulley measured at "tips" of the grooves.
    Kind of tough to measure the crank pulley with the belts on but I make it out to 150mm for a ratio of 2.68 alt to crank. That equates to 2010 alt rpm at 750 engine (man trans).
    Handy available pulley source (17mm bore)
    https://store.alternatorparts.com/17mm.aspx
  8. May 17, 2022 at 11:53 AM
    #48
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, 12.7VDC at less than 700 RPMs is not normal. Something isn't right.
  9. May 17, 2022 at 1:13 PM
    #49
    Shortman5
    Supercharged TRD
    I’m getting around ~14+ at park/ neutral 700 idle. It’s when I’m in gear at idle and idle drops to to 600 +/- that it stops charging.
    Considering I have an auto and I can’t find anything to support that anything less than 1800rpm at idle is sufficient for charging on a CS144 I’m thinking it’s playing a role.
    Also, I could have also sworn that I’ve seen lower rpm in gear idle in the summer months before. Maybe I’m just misremembering though.
    I ended up wiring the sense wire back into the OEM harness. Im now only bypassing the fuse box with a 4ga wire directly through a breaker then to the battery. Instead of the sense wire being wired directly in line with the charging wire. Seems to have helped some but I not convinced that’s going to solve it.
    Im still wondering if having the factory wiring all hooked up is important for the regulator operating property for a low EFI rpm application. Ive read some material that’s seems to support the fact that sense directly to the charging wire only allows the regulator to operate based on RPM. It Depends on who you ask. Seems like the only sources of information that support the 1wire vs 2 wire being no different are also selling alternators.
    Crank is 5.9” and the pulley on my CS144 is 2.44”. So 1450rpm in gear at idle.
    stock pulley on the 80A Denso is 2.1 so That’s 1675rpm in gear at idle.
    So I’m going to try a smaller pulley to get close to the recommendation of 3:1
  10. May 17, 2022 at 8:10 PM
    #50
    Shortman5
    Supercharged TRD
    B12F209C-020C-4798-9FB0-7F7E6B915767.jpg Well,
    I got it figured out. It was the alternator pulley. With a 2” pulley I’m getting just over 14v in gear and at idle with no AC.
    With a automatic idle drops to the mid 500s while in gear without the AC clutch on.
    Skibber and ToyotaDriver like this.
  11. Dec 21, 2024 at 12:04 PM
    #51
    Skibber
    Skibber New Member
    2001 Toyota 4Runner 4wd Limited
    I'm a T4R.org member that stumbled across this thread while having the exact same issues. Did the CS144 mod this summer after my OG alt crapped out right around 200k miles. All seemed well until the outdoor temps here in Chicago started dropping recently. Was monitoring the voltage and noticed the same exact thing. I got mine from DB Electrical and that too came with a 62mm (2.44") pulley. I'm planning to order a 53mm pulley from Metro Auto Inc (http://www.metroautoinc.com/new/ind...63_66_68&product_id=1120&filter=1349,951,1026) to resolve the issue. See attached test report from the alt that I have. Also attached a couple pics of the numbers while warming up the rig this morning in 20 degF.
    Thanks again for the info in this thread...great stuff!!! Screenshot_20241220_183903_Gallery.jpg 20241221_102808.jpg 20241221_101735.jpg
    cruiserguy likes this.
  12. Dec 22, 2024 at 9:44 AM
    #52
    Dirty Pool
    99 XCAB V6 MT TRD
