CS144 Alternator Swap into 3rz
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Jan 7, 2014.
  1. Jan 7, 2014 at 2:35 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So my alternator is beginning to go out on me, charges fine while driving until i put any kind of electrical load on it it beings to loose voltage and the truck starts to struggle.
    I have read about the GM CS144 swap in the 3.4l and i was wondering if anyone had information on a 3rz swap. Below is really the only helpful link i found, looking to see if anyone has more information before i begin this project.
    http://www.customtacos.com/forum/showthread.php?t=112540
  2. Jan 7, 2014 at 3:13 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    i tried to do research on the same thing and came up with a bunch of stuff for the v6's and nothing for the 2.7's... when i roll my windows up while idling my truck starts to vibrate little. when i keep holding the switch even after the window is up is when the vibration gets more intense.
    Stout890 likes this.
  3. Jan 8, 2014 at 4:56 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    So i have discovered the GM alternator has a 6 rib pulley and Toyota only has 4. Can i get a belt that works with both? can the Toyota pulley fit on the GM alternator? (Some one with a 3.4l that has done the swap?)
    Also figure i would do the big three upgrade at the same time
    I will add a 120amp fuse
    Also while reading about a 3.4l swap i see only 2 wires (actually wires no listed) we used???
    EDIT: from custom tacos
    "The larger wire, closest to the BAT+ stud is the sense wire, it tells the voltage regulator what the voltage in the system is. Just solder on an eye connector and route back to the BAT+ stud.
    The other wire is the excite wire (what turns the alternator on). This is the 3rd wire in the harness (from the stud) and needs to have a 100 ohm 1/4 watt resistor put in it. This is because GM routed this wire through the charge light which put a fair amount of resistance on it. If you don't put this resistor in you will burn out the voltage regulator in short order."
  4. Sep 5, 2014 at 9:45 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Did you guys go thru with this? I am looking at upgrading mine for a winch, did this work?
  5. Sep 5, 2014 at 10:23 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    I posted my post before i found Bamatoy's electrical system upgrade.
    http://www.tacomaworld.com/forum/ma...coming-2nd-gen-electrical-system-upgrade.html
    Stage 2 kit = upgraded alternator. He has a few different options i believe. 140 amps, 200 amps, 240 amps. Stock alternator puts out 70 amps i think?
  6. Sep 5, 2014 at 10:26 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
  7. Sep 5, 2014 at 12:34 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I've read that the 3RZ alternators put out 70 amps for 95-99 models. Then it jumped to 80 amps for 2000 models
  8. Sep 5, 2014 at 12:57 PM
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Interesting because all that Napa shows for the 95 is 60 amps. Maybe that differs from factory though. :notsure:
