Cs144 swap strange issue (solved)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kens04Taco, Oct 21, 2018.
  1. Oct 21, 2018 at 12:59 AM
    Kens04Taco
    Kens04Taco [OP] Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    hey guys so I finished my cs144 swap today and everything seemed fine. I got in the truck to take my girlfriend to the movies and on the way to pick her up I noticed the voltage dropping slightly when I let off the throttle. Which isn’t normal for me. So for example on the gas I’m at 14.3 then it would drop to 13.6.
    Parked the truck at the movie theater and got back in and now if I let off the gas the voltage drops in a hurry to 12volts and starts to sputter and want to die. The Rpms drop a lot during this. If I tap the throttle the volts Almost instantly jump to back to 14.3
    Now here’s the deal. I wired the large red wire with a ring terminal to the positive post on the back of the alternator like other right ups said. The only other wire I used was connecting the brown wire from the GM pigtail to my yellow wire which is the alt warning light.
    I’m thinking it’s either the belt slipping at low rpm and I need to tighten it. Or I noticed similar symtoms like this before after leaving my battery out of my truck for prolonged periods of time. Can any of you please chime in as to what your guesses could be?
  2. Oct 21, 2018 at 1:01 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You only hooked up 2 wires? Usually you hook up all three wires. I used an adapter plug available from Amazon or ebay and it works fine.
  3. Oct 21, 2018 at 1:03 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    The write up I saw said you hook up the large positive red wire to the back of the alt and the brown to the yellow (idiot light): now I’m feeling like I missed something or this was for a earlier Tacoma. ><
  4. Oct 21, 2018 at 1:05 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Here's the diagram. It shows the white to battery and the red to a ign switched power source and yellow to the light.
    cruiserguy likes this.
  5. Oct 21, 2018 at 1:07 AM
    mechanicjon
    Jon
    Scottsdale Arizona
  6. Oct 21, 2018 at 1:11 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Coming out of my factory connector was a pinkish wire (assuming red) a yellow and white wire.
    The GM pigtail has red black and brown.
    Maybe I can just see the alignment from that adaptor so I can just line them up that way
  7. Oct 21, 2018 at 1:22 AM
    mechanicjon
    Jon
    Scottsdale Arizona
  8. Oct 21, 2018 at 1:22 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Ugh I hope I didn’t fuck this alternator up. I’m gonna rewire the connection tomorrow and hopefully fix it
  9. Oct 21, 2018 at 1:23 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    They're pretty tuff alternators.
  10. Oct 21, 2018 at 1:24 AM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Thank you for pulling that for me I’m gonna rewire it tomorrow. I just hope I didn’t burn something internally. I didn’t get any reason to think I did besides the voltage drops but I bet u it’s because I don’t have the sense wire hoked up
    mechanicjon[QUOTED] likes this.
  11. Oct 21, 2018 at 6:43 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    SAW 2.0 Coilovers Wheeler's 5 Leaf + 3 AAL Bilstein 5100s LCE long tube header Flowmaster Delta 50 Muffler FJ Trail Team Wheels 255/85/16 Cooper ST Maxx 4Runner overhead sunglass console 4Runner leather seats All LED lights Red/Clear Tail Light Tundra Brakes HID Projector Retrofits 4Runner Auto Up/Down Windows Bullet Liner Cargo tie down system E-locker axle swap w/4.56 Gears ARE MX Cap Prinsu Toprac Custom heated turn signal/puddle light mirrors Volant Intake Tube
    The red wire is the "sense" wire that tells the alternator how much "power" to put out. Without that hooked up, it was probably just putting out voltages based on rpm. That would explain the symptoms you were experiencing.
  12. Oct 21, 2018 at 2:51 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Welp I changed the wires and everything seemed fine. Went for a drive and the alternator light started to flicker and volts we’re jumping around. Pulled over and climbed under the truck.
    The alternator post/stud on the rear of the alternator has basically pulled out and is just wobbling in there. I called orileys and they won’t have a replacement till Tuesday. So I basically patched it so it’ll run but I’m not thrilled about all this. But hey w/e shit happens
  13. Oct 21, 2018 at 8:41 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    after some research I've determined that the battery post is bolted to the bridge rectifier with a nut. Well it would seem that the guy who rebuilt my alt decided fuck it when it came to tightening the nut. So anyways...just thought Id add this to the thread for info purposes.
  14. Oct 22, 2018 at 2:07 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Glad you got the wiring straightened out.:thumbsup: Now just need to give the monkeys more bananas that rebuilt the alternator. :rofl:
  15. Oct 23, 2018 at 12:49 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    So I got the alternator swapped on warranty and the second alternator was a much better alternator. I guess they rebuild Delphi and ac Delco. The ac Delco has much better hardware and components it looks like. Mounted it and tightened up the belt.
    She’s purrn like a kitten now. Consistent voltage and no issues. Happy I got it all together :) thanks for the help guys
    @nzbrock
  16. Oct 23, 2018 at 1:12 PM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    That's great!
    Last time I saw an alternator post loose it was at a race track when the driver complained of loss of power. I tested the alternator and noticed the post was loose and while I was moving it it blew the Main 50amp fuse for the entire car. Glad it didn't happen to you. Apparently the guy before me tightened up the nut on the alternator using he-man strength and the metal strap on the inside broke and finally disconnected on the track. The battery died over time on the track and when I messed with the wire the piece of broken strap shorted on the inside of the casing.
    Lesson: Don't over tighten the nut on the alternator.
  17. Oct 23, 2018 at 1:15 PM
    Kens04Taco
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Yeah I can see that happening and that sucks on a track day. I don’t think I over tightened the first one but hey I’m human I could have fucked up. That’s good info though thanks for it
    Russianman92[QUOTED] likes this.
