CSF All Aluminum Performance Radiator For our trucks FINALLY!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Roostfactor, Mar 16, 2018.
  1. Feb 20, 2019 at 10:58 AM
    #1281
    dnpbakon
    dnpbakon Well-Known Member
    Kevin
    Jacksonville beach, FL
    2015 MGM TRD Sport Taco
    I’m just trying to diagnose I have the 170 and not the 160 without tearing out the thermostat again.
  2. Feb 20, 2019 at 11:21 AM
    #1282
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I understand.
    dnpbakon[QUOTED] likes this.
  3. Feb 21, 2019 at 3:19 AM
    #1283
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have the 160* thermostat and my truck runs in the 175*-180* range. The highest I’ve seen is 183*.
    Roostfactor[OP] and Torspd like this.
  4. Feb 21, 2019 at 4:47 AM
    #1284
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I have the 170 thermo, my truck runs at 190....
  5. Feb 21, 2019 at 5:12 AM
    #1285
    dnpbakon
    Kevin
    That’s what I’m seeing on my end too. I’m now positive I have the 170 degree. Gadget wants me to tear it apart again to confirm before he sends me a 160, but that’s some work, including another $40 in coolant. So I’m just gunna settle with it
  6. Feb 21, 2019 at 5:15 AM
    #1286
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I’m sure you’ll be fine. During the hottest part of the summer here which for a few days were very comparable to FL weather, it stayed right at 190....
  7. Feb 21, 2019 at 5:31 AM
    #1287
    ThomasMore66
    Dallas/Fort Worth & Durango
    I have the 170 and seem to run 186 all the time. In 100 degF weather, under boost I can get it to 195, but it cools right back off if I drive like a citizen. Awesome radiator.
    Roostfactor[OP] and dnpbakon like this.
  8. Feb 21, 2019 at 5:34 AM
    #1288
    dnpbakon
    Kevin
    Yea it was almost 90 degrees here yesterday and I never passed 190. Just bugs me I oidnthe extra money for the 160 and a recievedbthe wrong one. Other than that. Great product!
  9. Feb 21, 2019 at 5:50 AM
    #1289
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The coolant is easily caught in a clean Rubbermaid bin and can be reused.
  10. Feb 21, 2019 at 6:03 AM
    #1290
    dnpbakon
    Kevin
    Yea I understand that and that was my plan. But with my other daily ( 96 civic hatch) having a few issues. I can’t be without the truck :/. If I pull the thermostat, and it’s the wrong one, waiting for another one would be atleast 2 days. Again it’s all good. The truck is running great and as it should.
  11. Feb 21, 2019 at 6:07 AM
    #1291
    Sandman614
    Tim
    '06 SR5 Off Road
    I get that but you keep saying how it's another $40 in coolant. There's plenty of data here to suggest what you have and what it should run like in other temps. If you're not happy with that then you have a solution available.
    Damn I can't wait til I can get one of these for my truck!
  12. Feb 21, 2019 at 6:11 AM
    #1292
    dnpbakon
    Kevin
    :cheers: I understand and when I have time I’ll end uomdoing what you suggested into a clean bucket for re-use! You’ll love the radiator. Great upgrade.
    JuanitoBonito likes this.
  13. Feb 21, 2019 at 11:51 AM
    #1293
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    If you paid Gadget extra for the 160 then you should get the correct part.
    I would order the one I sent you via PM so you have it available, then when you get the old one out maybe Gadget will give you a credit or something.
    The 160 tstat is mostly for the boosted folks to try to keep detonation down.
  14. Feb 21, 2019 at 11:57 AM
    #1294
    dnpbakon
    Kevin
    So that’s the point I brought up to gadget and ordered the 160. So he said when I receive it, pull mine out, and then send it back for a refund.
  15. Feb 21, 2019 at 3:37 PM
    #1295
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    .....good ol gadget!!
  16. Feb 21, 2019 at 3:42 PM
    #1296
    dnpbakon
    Kevin
    Lol I will admit, he didn’t seem happy with me. And just kind of had an “attitude”? Almost like I was blaming him for sending the wrong part even though he was super cool about tending me the thermostat if indeed it is wrong. Just still, hard guy to read over the phone haha
  17. Feb 21, 2019 at 4:01 PM
    #1297
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Bump @BillDaCat8
  18. Feb 22, 2019 at 8:34 AM
    #1298
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
  19. Feb 22, 2019 at 8:34 AM
    #1299
    BillDaCat8
    Jake
    PHX
    Here's an interesting TSB.
    Looks like they're adding the condenser fan for Mexico spec trucks and then operating it based on refrigerant pressures.
    They also add quite a bit of sealing to the core support as well to help prevent hot air from sneaking around.
    Seals:
    #1 36869-04020 COVER, P $6.87
    #2 36869-04010 COVER, P $8.25
    #3 36869-04030 COVER, P $8.25
    #4 36869-04040 COVER, P $7.61
    #5 53286-04010 SEAL, RA $7.64
    #6 53285-04010 SEAL, RA $6.03
    #7 53398-04010 SEAL, RA $47.87
    #8 36867-04040 SEAL, PA $10.89
    Pressure switch stuff:
    88645-04070 Pressure switch
    90301-A0010 Pressure switch O-ring
    90980-10943 Connector Housing
    82998-12440 Wires (You'll need two)
    SilverSurfer and TireFire like this.
  20. Feb 22, 2019 at 8:37 AM
    #1300
    dnpbakon
    Kevin
    Any info on the tsb and how to tell if you need it
